Featured Technical Chopped windshield help
Discussion in 'Traditional Customs' started by Fred Pinckard, Nov 1, 2025.
  1. Fred Pinckard
    Fred Pinckard
    Hey guys, I need a little help here. I just finished the shop on my 54 bel air and need to cut my windshield down. I've already been through the original and a second one without any luck. I've watched all the YouTube videos, tried the gl*** cutter method, order some gl*** cutting discs for an angle grinder (those seem to work on the test gl***) but I'd rather not have to keep buying windshields, haha.
    Any help would be greatly appreciated
    dana barlow likes this.
  2. Joe Blow
    Joe Blow
    Make a template of the cut you want.....take it with another windshield to an auto gl*** shop.
  3. twenty8
    twenty8
    .... and they will attempt the cutting, but will most likely not take any responsibility for failures.
  4. Joe Blow
    Joe Blow
    Guess that's a possibility.....but if I'd went through the original and a spare myself, I'd sure check on having it done at a shop. I would have no hesitation with my gl*** guy.
    twenty8 likes this.
  5. BJR
    BJR
    Cut the gl*** first then fit the metal to the gl***.
    302GMC, bobss396, jet996 and 4 others like this.
  6. fastcar1953
    fastcar1953
  7. Memphis T.
    Memphis T.
    from New York
    There’s a sandblasting alternative to cutting. I believe you duct tape what you’re keeping and cut the exposed with the sandblaster.
    bobss396 and 3quarter32 like this.
  8. Bandit Billy
    Bandit Billy
    I have a buddy that chopped his car and “Sunk” the gl*** into the dash/firewall. That way he could get a replacement gl*** installed should the windscreen be broken. It may not work in all situations but it’s did on his square body Chevy pu.
    Tow Truck Tom, ramblin dan and jet996 like this.
  9. Adriatic Machine
    Adriatic Machine
    Like @BJR said, the gl*** should have been cut first, then you build the metal around it.
    Do you have any pics to share so we get get a better idea of exactly what is not working out?
  10. twenty8
    twenty8
    I agree totally with your suggestion to take it to a professional. That is really good advice.
    I also think that most "gl*** guys" will not cover the cost of a failure while doing this sort of job.
    How do I know this...??? I am one of them-there gl*** guys you speak of.:)
  11. twenty8
    twenty8
    I don't think this would be a good method. Maybe an abrasive water-jet would be a better idea....
    And all of this is ***uming it is laminated annealed gl***. If it is toughened or tempered gl***, forget it.
  12. HOTRODPRIMER
    HOTRODPRIMER
    I watched the local gl*** guy cut the originl windshield for a 1950 Mercury, it came out perfect, a few weeks later he was cutting a windshield for a 52 Chevy custom, he broke the original windshield he also broke the second & third, he finally succeeded with the forth one and yes the customer had to pay for all of them, that was made clear before he cut the first one. HRP
    Okie Pete and twenty8 like this.
  13. Joe Blow
    Joe Blow
    Yeah, agree.....experienced shop. My guy specializes in customs and hot rods....I'm spoiled.;)
  14. HOTRODPRIMER
    HOTRODPRIMER
    BTW, I was in the picture frame business for more than 40 years and cut plate gl***,mirror and automotive flat gl*** for friends, one of the guys that I cut flat automotive gl*** for was replacing his curved windshield and gave me his old one to see if I could cut it, I didn't have anything to lose so I tried my luck, my first and second cut went better than I expected but the third cut the gl*** cracked when I tried to snap the excess. HRP
  15. twenty8
    twenty8
    Gl*** can be a fickle mistress, especially older gl***. It gets more and more brittle with age.
    Okie Pete and Andy like this.
  16. lilCowboy
    lilCowboy
    I’ve cut several doing the cut off wheel method, use plenty of lubricantion like pb blaster or something similar. , bump the cit off wheel. If you hold it to long or two fast the gl*** will glow orange then it will crack, if it starts to glow though. Stop. ,keep flipping it over back and forth. Be patient it’s time me consuming. , but it works
    Okie Pete likes this.
  17. banditomerc
    banditomerc
    save yourself grief! cause ur not gonna save urself $$$ and take the job to a gl***man.
  18. Zuffen
    Zuffen
    from Sydney
    This is from a post on All Metal Shapers Forum from Jim Slabe who had to cut an MGB windscreen.
    I found a gl*** guy in Vista (about 20 miles away) who cuts windshields for chopped cars all the time, he has been doing it since 1965. Just the kind of experience I was looking for. I took the windshield in to him at lunch today and he had the needed 3/8" sanded off in less than 10 minutes and I was on my way. He had a big 4" wide vertical belt sander that ran in water with rollers in front so he could roll gl*** back and forth and keep control. I wish I had my camera with me. When I got home it was really hot but I wanted to see it in the frame and in the car. I installed the rubber on the gl*** and then mixed up a batch of Dawn and water. Once everything was nice and slippery I could gently press the frame over the gl***. When I tried the bottom rail I discovered that it didn't want to go on in a couple places. I measured the width of the slot and found it to be too narrow in a few areas and I will have to m***age them out. Not tonight though, did I mention it was hot.
    Doesn't sound too hard to replicate.
  19. Fred Pinckard
    Fred Pinckard
    Thanks for all of the opinions and advice. I would happily take it to a gl*** guy if there was one who was willing to cut it, that's not an option here, none of them cut curved gl*** anymore. My attempts to cut it were not to cut cost but out of necessity.
    Thanks for the help and please keep it coming.
    Okie Pete and Besty34 like this.
  20. twenty8
    twenty8
    Linishing (or sanding) versus cutting............... big difference.
  21. banditomerc
    banditomerc
    what neck of the woods are you in..? I'm sure someone on here knows of a gl***man that can cut your curved windshield...
  22. Fred Pinckard
    Fred Pinckard
    I'm in Virginia and so far the closest I've found is out in Riverside hahah
  23. krylon32
    krylon32
    from Nebraska
    Try contacting **** Rodwell in Salt Lake who makes the Wanless laid back windshield for a 32 Ford. If I remember he has a gl*** shop that makes 2 of his windshield gl***'s out of 1 early 50's Chevy windshield. Maybe his gl*** cutter could give you a few pointers?
    Fred Pinckard likes this.
  24. Joe Blow
    Joe Blow
    Might be worth contacting......it's a little less than 200 miles from Richmond. My guy is 160 miles. Good luck on whichever way you go.
    Tow Truck Tom and 1934coupe like this.
  25. Fred Pinckard
    Fred Pinckard
    I've talked to these guys and they were the closest I've gotten. I'll have to circle back to them
    Joe Blow likes this.
  26. Hellfish
    Hellfish
    Where in Virginia are you?
  27. Sgt. John
    Sgt. John
    from Virginia
    Good evening. Just got my windshield and side gl***es done..56 Mercury Monterey 4dr sedan..3 windshields cracked..The corners are the hardest because that's where the stress is. My buddy in Smithfield Virginia did mine 20251107_162413.jpg 20251107_162354.jpg 20251107_162400.jpg
    Okie Pete, Rocket88NZ and Budget36 like this.
  28. Fred Pinckard
    Fred Pinckard
    Richmond
  29. OZCAST
    OZCAST
    Try bobs cl***ic auto gl***. I bet he’ll make you one instead of you buying and cutting. I’ve been to his place and ordered cl***. The set up is no joke and the fit was perfect. Really nice guy too.
    https://bobscl***icautogl***.com/contact-us/
  30. BJR
    BJR
    On Bobs web site it states that they do not cut curved gl***, just flat gl***.
