Projects Heat and AC to backseat
Discussion in 'The Hokey Ass Message Board' started by AldeanFan, Nov 2, 2025.
  1. AldeanFan
    AldeanFan
    Has anyone run a duct to the back seat for heat and/or AC?
    I’m installing vintage air in my ‘54 wagon this winter and it would be really nice to heat and cool the back seat.
    My modern cars have ductwork under the carpet and ducts under the front seat blowing to the rear. Has anyone done something like this in a 50’s car?
  2. BJR
    BJR
    You could just mount a fan under the seat blowing towards the back.
  3. gene-koning
    gene-koning
    A lot of modern SUVs have rear heat/AC. Most of them have a unit complete with a heater core and AC condenser with an adjustable fan speed. Those units have a pair of 3/4" diameter hard lines attached to the vehicle's AC lines (the hard lines I've seen are all mostly aluminum tubing with an insulation cover), and a pair of 3/4" diameter hard lines from the heater hoses that run to the back under the car.
    It would be easier and more effective to run the hard lines under the car to a rear mounted unit then trying to run duct work. By the time the fan forced the air to the back seat, it is no longer hot nor cold, especially in a wagon. There is a lot of air back there that would need to change the temps, and just duct work won't work very well.
    Ned Ludd likes this.
  4. AldeanFan
    AldeanFan
    This is a great idea
  5. Have a look at 12v equipment cooling fans - like they use on computers. They are available in various sizes, and you can fit them inside ducting, whatever size you chose.
    willymakeit and alanp561 like this.
  6. Ziggster
    Ziggster
    Trying to cob up a stand alone rear HVAC unit is probably approaching a level of difficulty beyond the average DIY. You just can’t “add” an AC evaporator to a system designed for a single evap. You’ll need a larger compressor, and larger condenser to begin with.
    Simplest would be to add a fan(s) to direct air rearwards. Working in mobile HVAC for over 10 yrs designing systems, the one rule I learned the hard way so to speak is that hot air rises and cold air sinks. Just understanding and taking advantage of this fact can pay dividends.
    Next would be teeing somehow into the HVAC unit and running ducts under the floor along the trans tunnel and coming up like in modern vehicles at the rear of a centre console. Might need a stronger main blower, or a booster blower for that duct(s) run. Still lots of work.
  7. HOTRODPRIMER
    HOTRODPRIMER
    I have heat/air in our '54 Ranch Wagon and it does a great job in the front seat but the p***angers in the backseats do complain on extreemely hot days but to be honest we rarely have anyone in the back.
    I mounted the 4 vents in the lower part of the dash, I can turn the middle vents up and the back set p***angers can feel the air. HRP
    guthriesmith likes this.
  8. Oneball
    Oneball
    What is your 54? Olds, Cadillac and Lincoln all used boot mounted AC in the 1950s. I think Olds and possibly Cadillac had ducts that mounted on the inside of the roof. The usual option nowadays is to have a centre console on the transmission tunnel that feed air to the rear.
    51 mercules likes this.
  9. Oneball
    Oneball
  10. BJR
    BJR
    That was back in the late 40's and first half of the 50's. When GM, Ford, and Chrysler, used trunk mounted AC units. Now a days everyone mounts the units under the dash.
    Oneball likes this.
  11. AldeanFan
    AldeanFan
    this is almost exactly what I was planning except I’d like to route a vent to the back seat of my kids.
  12. AldeanFan
    AldeanFan
    1954 Country Squire
  13. AldeanFan
    AldeanFan
    Thanks for all the great suggestions.
    The plan is to put the biggest vintage air under dash kit at the front and try to route some of the air to the back seat for my kids.
    The kit I’m looking at has 4 cold air vents. My thought is I could have 3 dash vents and one along the tunnel under the front seat to the rear seat area.
    however a fan to circulate air to the back of the car would probably accomplish this easier and cleaner than trying to create custom duct work.
    A separate rear AC isn’t practical for me.
  14. stuart in mn
    stuart in mn
    Modern cars that do it have a duct running under the carpet to the rear, I think the hardest part would just be coming up with a suitable flat duct. Maybe you could scavenge something from a late model car at the salvage yard, or get a piece of PVC pipe, heat it up and squash it. If you have a console it could be run inside that.
  15. I believe a simple fan would move the air around the p***enger compartment, that the back seat p***engers will feel the effect. The other thing to do, i install a "drop" behind the rear seat, so that you are not trying to condition the air in the storage area. I have plans to make up a clear plastic curtain that would hang from the coat hooks, and isolate the back seat and cargo areas in our wagon.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Look at some of the mini vans, most of them have vents in the back, find a wreck or junk one and dig into the system and try to copy what the manufacture did.
    Our shop van has some cooling vents in the ceiling for the rear p***angers.HRP
  17. Gotgas
    Gotgas
    from DFW USA
    Maybe vacuum attachments would have the desired shape outlet and a slip-fit connector to a hose? Just thinking out loud.
    Whatever you decide, be sure to follow the guidance Ziggster gave. Dumping cold air out at the floor is going to do a great job of cooling off your kids' feet. :D Those cool transparent '50s rear A/C tubes served the purpose of putting the cold air where it's needed.
  18. pprather
    pprather
  19. I have a pair of flat ducts I'd sell. If interested let me know.
    lostn51 likes this.
  20. Bandit Billy
    Bandit Billy
    Wait. Backseat?
    greasemonkey54 and jaracer like this.
  21. lostn51
    lostn51
    from Tennessee
    My wife’s GMC has the vents for the second row seating in the back of the console. I’m thinking if you want bucket seats then build a console and run the a/c ductwork through it and have vents on the back like the GMC has.
    X-cpe likes this.
  22. Flathead Dave
    Flathead Dave
    from So. Cal.
    Run some ducting to the back seat area from the a/c ducting using a T and a damper to shut the rear area off when it's not needed.
    Figure out where to mount the rear air ducts.
    Or have someone sit in the back with a folding fan and a cup of ice.
  23. jnaki
    jnaki
    Hello,
    Our 327 powered 40 Ford Sedan Delivery had A/C. The center under dash mount unit blasted the whole interior. The two bucket seats were freezing if the vents were angled toward the folks sitting there. If the vents were left straight, they went right between the bucket seats into the back cave. Which was kind of a waste as no one rode back there. So, we never had to run the A/C at anything other than low speeds.
    upload_2025-11-6_4-36-6.png Summer time visits to see our mom in the Westside of Long Beach called for A/C. It was hot there and despite the West winds that constantly blew in from the ocean nearby, still, a hot, long "hour and a half" drive from our own house.
    But, as our station wagons grew in different models over the years, bucket seats were standard. We had A/C in some of the early models. No rear seat A/C outlets. The units were similar, even when they were in-dash, the vents shot straight back to the rear seat occupants between the bucket seats. Most of the time it cooled the rear seat kids, friends and dog.
    Jnaki
    One thing we noticed was since the luxury models of cars had center consoles that went all the way back, they began to incorporate venting for the A/C to the rear in station wagons. Minimal outlets are ok as it still blasts with the angles coming from the circular venting rings. So, make sure you have rotating vent openings that angle the direction of A/C. Your back seat folks will be thankful. YRMV
