Technical Fender bumping advice
Discussion in 'Traditional Hot Rods' started by spillaneswillys, Nov 2, 2025.
  1. I am not sure how to take these bumps out of my 39 Plymouth fender. I do ok indents but the array of tiny bumps has me stumped. Thanks for the help
  2. I like using a shrink disc
  3. manyolcars
    manyolcars
    in 1978 a body man named Juan, who lived in Mexico,, told me, Bring everything up then work down the bumps
    jet996, 34 5W Paul, Just Gary and 2 others like this.
  4. Yep. Bump it all up
    Use the shrink disc and cool.
    Repeat
    Ball peen hammer and shrink disc
  5. I am going to order a shrink disc!
    anthony myrick likes this.
  6. Watch videos
    They help a lot
  7. I did and it still takes practice
  8. Mr48chev
    It all takes practice and sometimes we don't actually get enough or steady enough to get great at it.
    I gave this fender to a kid who showed up on the Hamb a few years ago when he smashed his fender the first day he had the truck. Before I sent it I ground the bondo out of it, knocked the dents out and probably spent an hour sitting in a chair with a hammer and dolly working the fender that had 3/8 inch bondo in it in one area and turned it into a mud free fender that just needed finish metal work to be really nice. No shrinking disk though. Screenshot (49).png
  9. Metal has its on language
    You have to listen to it. it will tell you what to do.
    An old guy once told me “bump up the lows, knock down the highs”
    Sounds simple. It kinda is.
    The shrink disc isn’t magic, just another tool.
    before I ever used a disc, I turned grinding discs backwards to heat up sheet metal. Didn’t have a torch. It worked or at least a young me thought it did.
    The fender I posted took several hours after roughing out on a frame bench.
    Someone previously tried to fix that fender with a large hammer only. Stretched the **** out of it.
    The disc method works for me. I use a small and medium size ball peen. Both can act as a hammer and a dolly. The metal need to be bare. Bump up the lows, tap down obvious highs and use the disc. Cool as shown in the videos. Then tap up the areas not touched by the disc. Repeat with the disc.
    You don’t have to work the entire area at one time.
  10. 49ratfink
    49ratfink
    looks like one of those easy dents to fix where someone "fixed it" with a pointy hammer so now there are 50 tiny dents to fix instead of one crease. it did not get that damage from an accident.
    how much are shrinking discs these days? if I did not have one I'd just hammer and dolly it out.
    surprised we have not heard of anyone slicing the heck out of themselves. I think new ones have a curved edge to avoid bleeding out all over the shop floor.
    Squablow and Deutscher like this.
  11. RodStRace
    RodStRace
    The channel I like is Carter's Auto Restyling. His most recent one is an Auburn he worked the fenders on. He's also done his Chevy truck fenders and the Chicken Truck. I'm sure there are others that show their own process. Try a few different ones and find the one that works for you.
    Patience and willingness to keep at it is more important than any single tool.
    chevyfordman, Deutscher and Algoma56 like this.
  12. larry k
    larry k
    Use a wide black magic marker to show your low spots !!!
    Just Gary likes this.
  13. tb33anda3rd
    tb33anda3rd
    tire chain damage?
    jet996 likes this.
  14. HOTRODNORSKIE
    HOTRODNORSKIE
    Hamer and dolly use black guide coat on the bear steel then sand with 80 grit on a long block will show your high and low spots I have a shrinking disk and it dose work I dont know how a guy could get his hand in the disk.
    jet996 likes this.
  15. 49ratfink
    49ratfink
    if you don't how a shrinking disc can hurt you you should not be using one. mine is a 9" rippled disc with a pretty sharp edge. I could use it to cut a persons head off if I had a good reason to do so.
    I said nothing about your hand, but if you slice your inner thigh and hit the femoral artery you will be dead in less than a minute.
    Toms Dogs, GuyW and Just Gary like this.
  16. M C Empson
    M C Empson
    No doubt the wavy disc is dangerous, the newer style with the turned up edge is much safer. Of course a person wants to have their wits about them when using anything on a big angle grinder. I think both Wolf Fabrication and Pro Shaper sell this style.
    49ratfink likes this.
  17. stuart in mn
    stuart in mn
    Kyle is one of the best instructors you're going to find for free. Go back and look at his older videos on straightening out dents, this one is a good example.
  18. 34 5W Paul
    34 5W Paul
    from Fresno CA
    I don't have a lot of body work experience but a little. I've also had success with "bumping up the lows and knocking down the highs". Once you realize that bending the metal stretches it and once you shrink it the correct amount, a lot of the adjacent area issues are solved. Torch quench, off dolly or shrinking disk all work. I have a relatively flat hood that looked like it was tire chained or similar. brought the lows up, did some off dolly work to shrink the worst stuff, then did some shrink disk work. Found more low areas to bump up, then shrink disk. Got it really pretty good in a few hours. This is just one of many areas. Not great pics, but indicative.
  19. Dan Hay
    Dan Hay
    Please help me understand the science behind the shrink disc..
    Does it heat the metal and cause it to shrink because the dents stretch the metal?
  20. A mist of Guide Coat and a shrink disc will work wonders.
  21. K13
    K13
    Essentially yes. It uses friction to heat the metal which will then shrink once it cools. The nice thing about them compared to other methods is they only heat the high spots because it only rubs on those.
    49ratfink and anthony myrick like this.
  22. It does shrink the highs. It also creates a great visual for working up lows
    roughed out dent from a previous repair that just filled it up with filler. IMG_9499.jpeg a couple p***es with the disc. Shiny areas are low. Bump those up. Then more disc
    Clean up with a DA
    the heavy grinding marks was from the previous repair
  23. RodStRace
    RodStRace
    I think you mean DARK areas (not hit with disc) are low.
  24. The heat from the friction changes color on the high spots. They get darker
    RodStRace and down-the-road like this.
  25. Curt Wilson
    Curt Wilson
    Wray schelin videos on YouTube taught me a lot about working out dents/ripples including how to use a shrinking disc.
    rockable likes this.
  26. RodStRace
    RodStRace
    Gotcha, Thanks!
  27. hotrodA
    hotrodA
    WOW! Thanks for the tutorial!
    anthony myrick and Budget36 like this.
  28. 34 5W Paul
    34 5W Paul
    from Fresno CA
    Great save on that shoebox fender Ant Knee. It was ragged and you (and your students presumably) brought it all the way back. Hell yeah.
  29. Happydaze
    Happydaze
    20220524_160003.jpg Hands held pneumatic plannishing hammer will make short work of that. But they're pricey things. Mine is a butchered Harbour Freight item. Works great. Can't find a pic of if right now!!
    Edit. Found it!
    Chris
    jet996 and anthony myrick like this.
