Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Feeling empowered by my coil wire experience, I spent today's bus ride to and from work shopping for the rest of my wiring. By November 1, I'll have a wide range of 12, 14, and 16-gauge wire to chose from, along with my heavy-duty battery cables that I already installed and surplus materials from Version 1.0.
    I spend most of my night buying a MCM coffee table in Berkeley, but I did manage to get the ignition coil wiring sorted out. My phone died before I could take a picture, so here's another snapshot from the driveway.
    That's all for tonight. Thanks for sticking with me!
  2. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Oh, and one more thing: does anyone have a rec for a speedometer cable? I accidentally ordered the wrong one. I need one that connects an early Ford turtle to a 1962 SW 160mph speedometer. Any help is greatly appreciated!
  3. Tim
    Tim
    from KCMO
    Any idea what thread sizes each of those are?
    J.Ukrop likes this.
  4. wheeltramp brian
    wheeltramp brian
    The cable ends should be regular GM sizes and I think a ca3002? cable would work, unless the speedometer needs the male thread on that side of the cable. They are pretty cheap at the local parts stores. I'll check the part numbers when I get to work in a little while.
  5. 51504bat
    51504bat
    Check with Rusty @e1956v at Speedometer Service. He will handle the cable issue. Plus he is an Alliance Vendor. And regarding the wire, make sure it's all copper not aluminum clad copper. Don't ask me how I know.
    Speedometer, Generator And Alternator Repair In Colorado Springs
    Edit: make that copper clad aluminum not aluminum clad copper. Brain fart before the morning coffee.:cool:
  6. e1956v
    e1956v
    Alliance Vendor
    I can definitely get you going on that cable, I'd be happy to be a part of your build Joey. Just need an overall length.
    Thanks for the mention as always @51504bat
    dwollam, USMercUte, warbird1 and 13 others like this.
  7. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you guys! @e1956v, I'll get you dimensions this weekend. Love the look of your old building. o.jpg
    (I lifted this shot from Yelp! but too good not to share.)
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Good mail day. The Raybestos master cylinder seems substantially better than the one I have in the car now. Once I get my Raybestos wheel cylinder, I'll start planning my overhaul. All copper washers will be annealed—I'm going to give this system a fighting chance.
    When I went to set these parts in the garage for the picture, I noticed my right front wheel cylinder leaking worse than ever from the copper washer area. I'm thinking the RF may have to come apart too. We'll see.
  9. Tim
    Tim
    from KCMO
    **** hard to like that.
    where did your existing cylinders come from? I’d be curious to see where they are leaking from once you pull the hub/drum and can see what’s happening
  10. Outback
    Outback
    from NE Vic, Oz
    Dang man, good on you for pushing on, I imagine “mech brakes don’t leak” has run though your head lately!
    41 GMC K-18, winduptoy and J.Ukrop like this.
  11. Brand new washers don’t need annealing, only already crushed ones do so they soften back up after being work hardened. I am surprised that the brakes are giving you so much trouble, you have done everything meticulously. I wonder if when putting the return spring on that the shoe web is cutting into the dust boot or forcing the piston seal to get damaged some how. The spring is heavy but care must be taken when clipping it in place
    Outback likes this.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you. I did say that at least once this weekend.
    Okay good info on the annealing. Very frustrating indeed. Fingers crossed that these new parts will help.
  13. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    IMG_3120.jpg Speaking of new parts, we now have the Raybestos wheel cylinder. I'm pretty sure it's identical to the one I got from Napa for half the price. I'm going to try this one first, then the Third-Gen. I have a busy week and won't be able to get to it until early November.
  14. RodStRace
    RodStRace
    Joey, that looks like it's spot faced for a washer, but maybe hold it against a gl*** slide or similar small flat surface to check. Also finger tighten the hose and make sure it threads deep enough to have a smaller gap than the washer.
    41 GMC K-18, Six Ball and Outback like this.
  15. Hitchhiker
    Hitchhiker
    I'll chime in on the wheel cylinder issues.
    First off, the issue is that the castings are not machined correctly on a lot of the reproduction wheel cylinders. You can find more info on this if you search. But the major issue seems to be the port where the fluid enters the cylinder.
    I have used just about every cylinder on the market.
    Raybestos is what I use. Never had an issue with one. Period. Napa I do believe is the same. But more $$$.
    I do have a set of customer supplied third gens that are holding. But have not been driven on yet. And I'll be honest, I was not super impressed when I opened them. They look like the same that you get from any early ford parts supplier.(I've installed thousands of wheel cylinders, so my standards may be high) But as long as they hold. I'll be happy.
    Centric is another brand I've had good success with.
  16. Six Ball
    Six Ball
    from Nevada
    Like almost all "vintage" parts today there are a lot more sellers than makers. Easy example Dura- Bond in Carson City makes more than 90% of the cam bearings sold in the US no matter what name is on the box. Even your favorite old brands. With cast parts it is more likely that one company supplies rough castings to several places that do the machining. It is also possible that like the vintage firearms import business some lower priced companies get seconds.
  17. 57tailgater
    57tailgater
    from Georgia
    I am ***uming the surface where the plug is is where you're connecting your brake line end. While it looks like a "flat" surface, to me it doesn't look like it's been spotfaced for the washer. This is going by what I have seen on disc brake calipers. Most of the time you can see annular grooves from the machining. Interesting for something this old it's a fitting sealed at the hose end fitting body vs inverted flare but I am by no means an expert.
    Ragged Edge, Six Ball and winduptoy like this.
  18. Hitchhiker
    Hitchhiker
    I think there are at least 4 if not 5 different manufacturers of early ford wheel cylinders
    41 GMC K-18, Six Ball and Ragged Edge like this.
  19. Tim
    Tim
    from KCMO
    Wonder if there is an easy way to check that spot for flatness and if it’s if off spot fix it by hand.
    Six Ball likes this.
  20. Dick Stevens
    Dick Stevens
    It not only needs to be flat, it has to be 90* to the threads for the banjo bolt, so I don't think that is a job that can be done by hand!
  21. patsurf
    patsurf
    just loosen the banjo a bit and jam a feeler gauge around a couple spots
    Six Ball and Tim like this.
  22. Six Ball
    Six Ball
    from Nevada
    Anything that can be fixed can be fixed by hand. It depends on whose hands.
    41 GMC K-18, J.Ukrop, Outback and 5 others like this.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    This afternoon, I headed down to the garage to finally pull apart the left front brake. I knew it was going to be ugly, but I didn't know how bad.
    The answer? Pretty bad.
    Stuck shoes and brake fluid everywhere. Here you can see the fluid actually dripping off the rear of the wheel cylinder. It felt good to get a visual and start cleaning up the components.
  24. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    With the backing plate gutted, I re-installed the LF drum and wheel so I could get the car back on all fours. IMG_3243.jpg
    Tonight's other task was to switch the amp and volt gauges so that plumbing and wiring them would make more sense. I'm always happy to have a quick-release cowl top.
  25. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last thing for tonight—we now have wire. I can't tell you how excited I am to work on something that's not brakes.
    That's all for tonight. More tomorrow!
  26. RodStRace
    RodStRace
    If you can, put each wire in, route it, make your bundles and leave a bit extra for each end. Once satisfied, then terminate the ends and connect. If you do one end then start from that hard point, you fight things a bit more and can easily end up with a slightly short wire. This can't always be done, but just keep in mind a little extra wire is easier to fix than one that's a little short.
  27. Tim
    Tim
    from KCMO
    Man thats one collapsed wheel cylinder. At least the problem was obvious. Still pretty ****ty :/
  28. Beanscoot
    Beanscoot
    As an aside, brake fluid washes off with water. I like to take the garden hose, a big brush and some soap to the wheel after getting a drum off and wash most of the fluid away before proceeding further.
    Of course this is best done outside on a warm day!
  29. winduptoy
    winduptoy
    Certainly discouraging but a whole lot better now than on the road somewhere in Hong Kong, Switzerland.... I believe a critical post mortem, dis***embled look at that wheel cylinder is in order along with a good look at the new ones prior to installation....
    stay strong
  30. RodStRace
    RodStRace
    A smooth, round bore and a rubber lipped seal. Pretty simple, almost every one is going to be the seal is not good since it's not a huge leak (seal lip folded). Bore could have issues or junk in there, but those tend to leak more too.
