Projects 41 Ford pickup finally got it home and pictures pictures
Discussion in 'Traditional Hot Rods' started by joel, Jul 19, 2017.
  1. joel
    joel
    I ordered the wiper kit today; they said it would take a couple of weeks to get it. I also took the bed off the frame so I could do a test fit on the cab.
    Bandit Billy and warhorseracing like this.
  2. joel
    joel
    Here aree a couple of pix of the firewall patch and a test fit on the accelerator pedal.
    I had to make a piece( call it a 'foot" ) that supports the pedal end of the ***embly It's under the cover on the pedal end of the ***embly. I know it belongs there because it was on the truck when I got it; I just couldn't find it now. SOS
  3. Bandit Billy
    Bandit Billy
    Ugh! I remember so many evenings in the garage, plugging, welding and grinding all those firewall holes closed. I am a fanatic when it comes to tidy bulkheads. When they are all done, it will have been worth every ounce of wire. Stay on it.
    Okie Pete, MMM1693, Thor1 and 2 others like this.
  4. joel
    joel
    Thanks BB; will do.
  5. TomT
    TomT
    I remember as well - it’s all good and lookin’good!
    Outback, joel and Bandit Billy like this.
  6. joel
    joel
    I got the cab sitting on the frame today; now I have to get the wood blocks under the cab and bolt it down. My winter plan is to lay out the wiring, install the seat riser and build a seat. I also plan to repair the bottom hinge on both doors.
  7. joel
    joel
    New pic of the cab on the wood risers and very close to mounting holes lining up. First thing is to rework the trans cover with a raised section for the fat section of the shift tower. cab located on frame.jpg
    Hi-HO HI-HO it's off to work we go.
  8. joel
    joel
    Here are some pix of the trans cover mods to cover the shift tower on the TOD T170. transcoovermod..jpg
    The little red thing is either a back-up light switch or a neutral safety switch. I plan on using the stock ignition switch (on the column) and push ****on start with the Ford solenoid on the firewall. I hope.
  9. ActionYobbo
    ActionYobbo
    Red thing is reverse light switch. Also to critique your wall around the shifter. If you leave off the wall the stock boot covers most of that area you just need to clear the reverse switch. Just plateau the top of the cover (see red line) to give clearance for the switch and wiring.
    Kelly Burns, Thor1 and warhorseracing like this.
  10. joel
    joel
    I was planning on "flat topping" on the vertical walls, which should expose the just the cap that screws on the tower. Thanks for your comments; I think we're on the same page.
    The 39 guy likes this.
  11. joel
    joel
    Small progress on the trans cover.
    One more piece to add and then finish weld the corners. Trans cover mod2.jpg
    You can see the opening to the right of the shift lever.
    Okie Pete, loudbang, TomT and 6 others like this.
  12. The 39 guy
    The 39 guy
    Nice fab work Joel!
  13. TomT
    TomT
    Lookin good!
  14. joel
    joel
    Thanks Sam and Tom and all the guys that have followed this project.
    On another note, I wondered why the water pumps have elongated holes where the pumps bolt to the crossmember; my p***enger side aluminum head is resting against the firewall. I'll need to move the engine about 1/8" toward the radiator which requires the trans mount to be elongated also. Opportunities!
  15. dln1949
    dln1949
    54 holes welded up on my 40pu firewall. I didn’t know you could mount that many heaters, regulators and **** on s firewall. On a good note I’m with bandit on Newport wipers, absolutely bolt in, plug in and that’s it. Sure you have to drill a few holes, but they are one of the few things I have bought that fit and worked as advertised. Keep on truckin Joel.
  16. MMM1693
    MMM1693
    If your getting overwhelmed just send me a PM:cool::cool::cool:
  17. 38bill
    38bill
    from Minnesota
    If the '40 is like my '38 many of the holes in the firewall were for the mounting clips holding the insulating pad that was on the interior side.
    ActionYobbo likes this.
  18. joel
    joel
    Yeah, I think I welded one of them by mistake; I have to mount the fuse box yet and I'm looking at the p***. side. I have to string out the harness and make sure there is enough to reach everything. The center inside of the firewall is for the heater and I am waiting on the wiper kit.
    Thor1 and Bandit Billy like this.
  19. Bandit Billy
    Bandit Billy
    I welded all those little clip holes closed since I was going to use adhesive sound deadener on the truck. You are doing nice work!
    Outback likes this.
  20. joel
    joel
    Thanks, BB. I spent a couple of hours today on the internet looking for a boot to cover and seal the ch***is noise and heat from the driver. I'd like to cover the lower part of the stick to improve aesthetics below the round part of the stick. modified shifter.jpg
    I need one about 6 1/2 in. tall and 4 1/2 in. dia. or 4 1/2 x 5 rectangle base. Most listings I found didn't give any dimensions. I' like to hide the square part.
    Thor1 and Okie Pete like this.
  21. Bandit Billy
    Bandit Billy
  22. Great work Joel. For my '32, I made my own (similar to the Lokar version).
    Thor1, loudbang and Bandit Billy like this.
  23. joel
    joel
    I looked at them and I am going to call . I hope to find something off the shelf, in stock. It's a little "street rody " but that stick is **** ugly.:)
    I can't sew for ****; wife has to fix my jeans.
  24. ActionYobbo
    ActionYobbo
    The one I used was from a kenworth or similar big rig. Put this number in Google #91021804
  25. Bandit Billy
    Bandit Billy
    I have to say the material is ****, thin vinyl, not even that nice hyde from a naga. But they make excellent templates for anyone with a sewing machine that can sew leather. As for the SS ring, scuff it and paint it black if you like. Its difficult when you need to hide the lower part of that stick.
    Outback likes this.
  26. joel
    joel
    I've been slowed down by a knee replacement surgery, but I thought I'd show s couple of pix for my shift boot solution.
    This is the base of the shifter that slides down over the stub sticking out of the transmission. The slot is machined to slide over the square stub and the slot will have a "plug" in it that contains 2 set screws that will tighten against the stub. It's the same concept as the original Ford coupler but better looking I think and will not require much of a boot. Maybe a stock looking rubber one.
    looking back from the firewall approx.
    A waste of time; probably. I didn't want to lose the ability to remove the shifter handle to remove the trans out with the engine.
  27. The 39 guy
    The 39 guy
    I can't tell exactly how this shifter thingy works.... Hoping you will show an installed picture.
  28. ronzmtrwrx
    ronzmtrwrx
    Yes. I’d like to see that as well. I’m setting up the 39 with a T170.
  29. joel
    joel
    I will for sure show results; especially if they are as I hope. If I still had access to an EDM machine this would be simple. I could burn the required rectangular form from the bottom end to a finished size and drill one side for the set screws. The rest is all lathe work. Stay tuned.
    loudbang, Thor1, The 39 guy and 2 others like this.
  30. joel
    joel
    All of the pieces are made. If the test fit goes well; I'll be thrilled.
    the first pic is the key that I intend to weld into the slot in the base piece. I used the vice to keep the key from tilting until I tack it. shifter key lock.jpeg tacking set up 2.jpeg test fit shifter key.jpeg
    There are spacers under the key to maintain the size and shape of the space underneath . I'll have to cut about 5/8 in. off the top of the stub so the shifter will go down far enough. Fingers crossed.
