Technical Supercharging my early Pontiac V8.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Aug 16, 2025.
  1. wheeltramp brian
    wheeltramp brian
    It's gonna be a 2 inch Gilmer Drive belt with 1V belt for the generator.
    bchctybob and SS327 like this.
  2. swade41
    swade41
    from Buffalo,NY
    Can you get 2 inch idler and drive pulleys
    bchctybob likes this.
  3. wheeltramp brian
    wheeltramp brian
    Yes if you go to the dyers website they make all of it.
    bchctybob and swade41 like this.
  4. wheeltramp brian
    wheeltramp brian
    Got an email back l and they said they're gonna send me some pictures on Friday, so I'm guessing they've already started making stuff. Exciting!
  5. wheeltramp brian
    wheeltramp brian
    We've got some pictures back and some information. On my setup I use the pulley closest to the engine and he says it will not work with the balancer he was going to use. Says that the belt will be too far forward. But I think I can use the outside pulley and I can use the 2 groove water pump pulley. Then I have and figure out the generator later. Seems he's using a later Pontiac balancer. 3689.jpg 3686.jpg 3688.jpg 3687.jpg
  6. wheeltramp brian
    wheeltramp brian
    He has made the pulley/spacer and I've got to take some measurements once I get it 3992.jpg
    bchctybob, GuyW, jet996 and 3 others like this.
  7. wheeltramp brian
    wheeltramp brian
    I took all the measurements he asked for and took pictures and just received all the parts today. I definitely stated that I wanted a 2 inch drive. And ended up getting a 3 inch. Went to mock it up just to make sure it all fits and it does not. The pulleys do not lineup, and the belt barely fits onto the top and bottom pulley. This ****s. I sent an email with pictures as they don't answer the phone. And they only work a couple days a week. 20251031_112443.jpg 20251031_112450.jpg 20251031_112458.jpg 20251031_112511.jpg 20251031_112518.jpg
    swade41, bchctybob and loudbang like this.
  8. flamedabone
    flamedabone
    They sell pulley spacers in lots of increments. Looks like you need an inch on the top pulley. The idler, you can space out with a few flat washers. Once you have the alignment right, you can order the right belt. You are gonna be fine as long as you have the room for the 3 inch belt. If not, have a buddy with a lathe machine the pulleys to two inch.
    -Abone.
  9. wheeltramp brian
    wheeltramp brian
    I shouldn't have to do any of that, As I ordered a 2 inch drive kit and gave all the proper measurements. I'm waiting to hear back from dyers.
    Paul, bchctybob and Tim like this.
  10. 19Eddy30
    19Eddy30
    from VA
    @wheeltramp brian ,
    Do not know your Conversation with Dyers , the 3 inch pulley No big deal to cut down , I understand you specified
    2 inch ,Under stand / can relate to your frustration Especially when you pay someone to do the job or make!!
    No problem to cut better with the Lathe but can be done with other tools Hack saw / band ect.
    Even with measurements it's kind of hard to get exactly what you need without having the project sitting in front of you, can get close ,,
    I ran /use many blower combinations
    4, 6 8 . Centrifugal and roots.
    Spacer/ shims expected.
    Idler , top & bottom pulley
    & shim / spacer for V 's
    Crank , water & Alt .
    One question I do have did they supply the blower belt ? " If So"
    That someting That should of "NOT" been " Wrong length"
    Unless Dyer was thinking you where going to run the toddler pushing against the belt,
    In future myself if I'm going to run a 2 inch wide set up I order a 4 inch belt cut it so I have a spare its like $20 more for the 4 inch belt , then One 2 inch belt .
    There Not to many Bolt On's that end
    Up bolt On's with out modification and adjustments
  11. wheeltramp brian
    wheeltramp brian
    I understand that custom stuff takes adjustments and usually doesn't fit LOL. And yesterday belt was supplied.
  12. wheeltramp brian
    wheeltramp brian
    He told me to send it all back, and he will correct it. I've got to go to the shop today anyways, so I will pack it back up and ship it out.
  13. bchctybob
    bchctybob
    Be sure to send lots of pictures from every angle so he can clearly see the problems.
  14. wheeltramp brian
    wheeltramp brian
    I did .just shipped it out earlier. I wish they were closer within a couple hours, I'd bring them the engine
  15. swade41
    swade41
    from Buffalo,NY
    Looks like nothing was right
    Paul likes this.
  16. Paul
    Paul
    Editor
    if nothing else you have/had something to measure
    you'll get it done, just keep at it.
    ran into one or two of those hiccups with every blower I set up.
  17. There is no better look than a blower and scoop!
    bchctybob and Paul like this.
  18. wheeltramp brian
    wheeltramp brian
    I got all the parts back yesterday and installed and it all lines up nicely. Even got two free hats and a t-shirt! Gotta fab a new bracket for the driver's side for the generator mount. As right now it's on the p***enger side. 20251113_112247.jpg 20251113_112255.jpg 20251113_112302.jpg 20251113_113145.jpg 20251113_113149.jpg 20251113_113156.jpg 20251113_113201.jpg 20251113_113329.jpg
    fauj, loudbang, Paul and 3 others like this.
  19. bchctybob
    bchctybob
    Oh yeah, now that looks great!
    Bird man likes this.
