Technical Who Sells this Door Glass Molding ?
Discussion in 'The Hokey Ass Message Board' started by Brians53vicky, Nov 4, 2025.
  1. Brians53vicky
    Brians53vicky
    from Monroe, MI
    Just bought a project 35 Chevy. Please let me know a parts vendor who sells the long molding that helps keep the gl*** aligned. I'll post a photo of it below. It needs to be 1 continuous piece that is 6' long.
    Thanks !
    Brian
  2. HOTRODPRIMER
    HOTRODPRIMER
    You can most likely go to your local auto gl*** shop and they will have it in stock. HRP
    Brians53vicky likes this.
  3. Fat47
    Fat47
    Or, there is usually a vendor at swap meets selling six foot strips of various sizes.
  4. MMM1693
    MMM1693
    I believe this pretty much a universal part. You will need thickness of gl*** and also the window channel. Gl*** outfit that cuts automotive gl*** or parts store should be able to steer you in the right direction.
  5. woodiewagon46
    woodiewagon46
    from New York
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    bill gruendeman and RICH B like this.
  7. squirrel
    I've noticed over the past few decades, that now I need to get into my time machine, before I try to visit my local auto gl*** shop for anything that might fit old cars.
    sad
  8. 51504bat
    51504bat
  9. stuart in mn
    stuart in mn
    Have you checked with the usual sources for that sort of thing - Steele Rubber, Metro Moulded Parts, Chevs of the 40s?
    rattlecanrods likes this.
  10. HOTRODPRIMER
    HOTRODPRIMER
    Strange, I know of 2 gl*** shops that carry the channel, I know it's getting harder to find them with the lack of phone books now a days. HRP
    squirrel likes this.
  11. Mr48chev
    You have to go over to the old been in the same family for several generations full service gl*** shop in the same old building that it has been in for decades. A good friend of mine runs a shop that does autogl*** but they just replace gl*** and don't cut flat gl*** or have anything for older rigs but he can put a new windshield in your wife's 4 year old daily driver in short order and do a perfect job of it.
  12. Mr48chev
    Bob's cl***ic Autogl*** shows it for a 35 Business coupe. It shows the body style number it fits. Screenshot (1592).png
    5window likes this.
  13. My brother ordered some for his 35' Olds from Rock Auto fairly reasonable. I believe it was Steele Rubber brand
  14. 325w
    325w
    Local upholstery supply
    50chevytx likes this.
  15. bobss396
    bobss396
    Looks like a Y619 or Y620. The rigid one should work. Most sites have measurements, this is how I matched mine up
    5window likes this.
  16. 5window
    5window
    bobss396 and SS327 like this.
  17. bobss396
    bobss396
    I went with Restoration Specialties for mine. At the time few sold the channel in 8' long pieces.
    If you find a part number that looks good, do a search using that. I needed 2 of the bendable and 1 of the rigid, IIRC. Of the bendable, I had something like 8" leftover at the end.
  18. Paint
    Paint
    A little tip, when you bend it to make a curve make sure that the stainless bead edge slides on the fuzzy part, if it doesn't it will kink. You will have to trim off the ends that will be sticking out after you get the shape you want.
    bobss396, 5window and Ken Smith like this.
  19. bobss396
    bobss396
    The bendable type makes a decent curve without kinking.
    On the rigid stuff. I needed to make 90 degree angles for the doors. There was nothing to go by, I just intersected them and it looks good.
    I made the cuts on my mill with s**** molding in the channel to hold it open.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    They ship parts every day....
    5window likes this.
  21. 5window
    5window
    I like to buy local,if I can
