Technical Fuel line for new Edelbrock carb
Discussion in 'The Hokey Ass Message Board' started by Eth727, Nov 4, 2025.
  1. Eth727
    Eth727
    IMG_8718.jpeg IMG_8717.jpeg Hey guys I’m installing a new Edelbrock carb to my stock ‘63 Impala. The fuel line is a threaded metal line. What do I need to install it into the new carb since it doesn’t have threads on the inlet?
  2. jaracer
    jaracer
    It looks like you need to take the large fitting out of the old carb and install it in place of the hose fitting on the new carb.
    chryslerfan55 and Budget36 like this.
  3. 19Eddy30
    19Eddy30
    from VA
    If two main threads are different
    & no adapter around with the inverted female for new carb , you can take ****** fitting out
    Cut off ****** get a Inverted female fitting with pipe male threads Tap ,
    Or solder the inverted fitting to the one that you cut ****** off.
    Or use rubber hose from ******
    To inverted fitting just slide the tube nut up on hard line towards the radiator
    Have 2 - 4 clamps
  4. Rubber hose from metal line to fitting. Put a fuel filter in between
    Tickety Boo likes this.
  5. Would almost have to make an entirely new line to do metal line pump to carb
  6. Tickety Boo
    Tickety Boo
    from Wisconsin
    Original Rochester line enters to the front of the carburetor while the Edelbrock feeds on the side, you could buy a female inverted flair to 3/8 hose fitting to come off the original line, then add a rubber fuel line hose and filter like The Chevy Pope suggested.
    If you ever want to back to original, you haven't cut it up ;)
    The Chevy Pope and Jagmech like this.
  7. Eth727
    Eth727
    The new carb has the fuel going into the right side vs the front for the old carb. The metal line isn’t long enough
  8. rockable
    rockable
    You could use the Edelbrock banjo fitting, which will give you a close 90 degree turn towards the front of the engine and connect it to the existing metal tubing with 2 hose clamps.
  9. dalesnyder
    dalesnyder
    Screenshot_20251104_184820_Gallery.jpg this is how I ran mine, an inverted flare fitting to 5/16 line.
