Oh lord I bought another Ford
Discussion in 'Off Topic Hot Rods & Customs' started by Lloyd's paint & glass, Nov 1, 2025.
  1. SBCs are made for flathead compartments
    283 hooked to my merc trans. $50 swap meet adapter. Came with this pilot bushing adapter
    this GM flywheel came from a 64-66 c10 with a straight 6. Correct Borg and Beck pattern IMG_9516.jpeg
  2. Built these simple side mounts
    55/56 manifolds should clear your steering box IMG_9518.jpeg
    mvee33, lumpy 63, bobss396 and 15 others like this.
  3. The flathead is unstuck lol. And with a little instruction from Tim @51504bat , the starter now works. Engine is cranking good. Pulled the distributor to clean points and bam, one of the breaker points has a broken spring :mad: where is the best place to buy this stuff?
    osage orange, porkshop, enloe and 8 others like this.
  4. 51504bat
    51504bat
  5. Nope, all of those parts houses are gone around here. Seen a set on Bob drakes sight, but i know Nothing about this stuff. Hate like hell to buy points so that I can find out that the coil is bad lol. Seen the electronic setup, but everything is 2 bolt, mine is 3 bolt, and they're outrageous. I just wanna hear it run lol.
    porkshop, bchctybob, Sharpone and 2 others like this.
  6. porkshop, Sharpone and anthony myrick like this.
  7. 51504bat
    51504bat
    Michael at 3rd Gen can probably point (no pun intended) you in the right direction
    844-327-5988
  8. oldiron 440
    oldiron 440
    I’d rather buy it with a stuck flathead than a sbc..
  9. Thanks Tim, I'll call them tmrw
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Who needs 2 sets of points? Try it with 1 set where the secondary points would be located.
    Sharpone, porkshop and chryslerfan55 like this.
  11. Who needs points when there's HEI?
  12. Hey, Bro, that's my line!:D:D
    Ben
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
  14. DDDenny
  15. I bought a distributor from the auction site. Figured I'd be better off with buying a complete setup rather than buying points, then need something else lol. Fingers crossed
  16. 51504bat
    51504bat
    Careful. Next you'll have one of these stickers:cool:
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Just WTF are these then? What covers them? :rolleyes: IMG_4897.jpeg
  18. BJR
    BJR
  19. enloe
    enloe
    from east , tn.
    Lloyd
    You are going to have to go back to fighting fires so you don’t keep buying projects
  20. tubman
    tubman
    Yeah, on a flathead Ford, the official name for the intake manifold is "valve cover".
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    On a SBC Canadians call them rocker covers. :)
    osage orange, porkshop, enloe and 2 others like this.
  22. Sharpone
    Sharpone
    I still think Lloyd is closet Ford guy:rolleyes:
    Dan
  23. Can't make it if you don't spend it! Lmao :D
  24. rust&patina
    rust&patina
  25. 427 sleeper
    427 sleeper
    6 outta 8 ain't too bad! Might need a valve job tho! :p
    osage orange, SS327 and Sharpone like this.
  26. I'll push it in a lake before I put that much effort into making 85hp. :p
  27. Moriarity
    Moriarity
    SUPER MODERATOR
    I think valves can stick open after sitting a long time. If you can figure out which cylinders you can spray some lube at the stuck valves and carefully try to push them down thru the plug holes... might take several tries to get em moving... you may get to experience 85 hp yet!!
  28. It has good compression on every cylinder. I put a different distributor in it, it's close, but I'm positive it's still out of time. Wires are junk, and if course the carb was froze up solid with a half inch of crud in the bowl. I've got a carb ordered, supposed to be here this week sometime. See if I can figure out how to make run any better.
