Technical Parts for 56 Chevy v8 swap
Discussion in 'The Hokey Ass Message Board' started by VANDENPLAS, Nov 6, 2025.
    looking at the above brake kit , manifolds and engine / cross member
    along with front and rear swap bars .
    Nay or yay ? Is their better out there ?
    stuffing a 383 with a T5
    shifter will need to be modified , drive shaft made and exhaust along with other odds and ends.
    just don’t want to have to buy the wrong stuff and reorder , if there’s better out there let me know .
    Sharpone, Butler 32, Butch M and 4 others like this.
  2. I bought a speedway garage sale trans crossmember for $50 I think
    Some $60 -70 engine mounts
    Ecklers had vette rams horns for $99 on sale a while back. Also have some freebie used regular rams horns.
    Bought drop spindles on sale. Uses off the shelf rotors purchased from my local parts place
    Probably got around $700 in everything
  3. 51504bat
    51504bat
    Won't work. It's not a F*N Dodge:cool:
    427 sleeper, Sharpone and VANDENPLAS like this.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I really like and have used this set up. No having to drop the engine over then down onto mounts. Frame portion mounts are far forward on the cross member making for lot of side clearance even though it’s a side mount kit.
    Speed Way does make a copy cat version. Never purchased one just because. IMG_4886.jpeg IMG_4887.jpeg IMG_4888.jpeg
  5. I used trans-dapt engine mounts. Wouldn’t recommend em
  6. squirrel
    but it has those ****py early Ford mount pads. Ugh.
    What are you doing for clutch linkage? Are you going to try to find an original 55-57 bellhousing? or make a bracket to mount the Z bar to the block? Looks like the transmission is tilted like they did in 83-92 Camaros, eh?
    Lots of things to think about here...
  7. Car is a 3speed with original clutch linkage .
    Sharpone likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    Yup, I agree with @squirrel ... and That giant (ugly) Hei distributor won't fit in a 56 chevy and that long water pump and serpentine belt setup won't work either unless you maybe leave the radiator in the 6 cyl location but I am not sure if there would still be enough room. These are best with a short water pump and v belts with the generator or alternator mounted on the exhaust manifold on the drivers side, and it does not look like the manifolds you chose above have the provision for that
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Now wait a minute. You didn’t give me **** at the Duct Tape meet up in Irwindale last year. :) IMG_3116.jpeg
  10. squirrel
    it was too late, so I didn't bother :)
  11. while Gm hei is probably the most reliable and simple electronic ignition to use , it’s the damn ugliest on the planet !!
    going to use a points distributor .
    the water pump and that mess of serpentine and v-belt pullies is going , and going to use a short water pump and standard pulleys .
    keeping the Rad in the inline 6 position
    also planning on using the hydraulic clutch slave/master that’s on the ****** already , seems easier to set up then a mechanical clutch .
    if I need different exhaust manifolds what should I be looking for ?
    lots of different center dump and rear dumping rams horn for sale locally to me and all are slightly different .
    would like to use something that makes tune ups easy and fit the car, seen a lot of trifives with rams horns and they fit just nice . .
  12. squirrel
    Original rams horns 57-late 60s. Figure out what you want for the charging system, first. There were a couple different designs of alternator mounts on rams horns, both on a separate bracket, and with bolt holes in the front of the manifold instead of on the side. Some of the manifolds for mid 60s and later cars/trucks angle back at the bottom, they are probably not what you want.
  13. Stock 55/56 V8 manifolds are a favorite of mine
  14. You’ll see 2 different styles of side mount. One moves the engine foward to clear an HEI
    The other keeps it in the same spot as the original front mounts
  15. Mr48chev
    With the V8 engine in stock position in any tri 5 Chevy distibutor clearance is tight with the early no window distributors let alone any later larger distributor. My buddy used to break rotors on his 57 on a regular basis but there was a screw coming though the firewall that the distributor cap would hit on hard acceleraton.
    Personally I like those flathead Ford motormount biscuits and have Ch***is Engineering Inc. mounts for the 292 going in my 48.
  16. what mounts are these ? Where to get them ?
    I’ve read with the rad in the 6 cyl location you can use hei
    even if I go with points if I can gave more clearance to the back of the engine why not
  17. My trans dapt ones kept the engine in the stock location.
    these do as well
    https://www.ebay.com/itm/191342640211
  18. Look for mounts that are listed as 3/4" forward. Those will give you HEI room, will definitely need to use rad in 6 cylinder position then. Not an issue.
  19. 325w
    325w
    The screw behind the distributor holds the defroster duct. Change to shorter screw it’s good
  20. Mr48chev
    If Mike had known that a lot earler he wouldn't have been at the parts house buying 57 Chevy rotors by the pack. I did hold the flash light while he changed the rotor a couple of times and then he swapped the 57 for a 69 Impala 348 4 speed and it was never an issue.
