Technical How can Edelbrock carb fit 63 Impala w/327 manifold?
Discussion in 'The Hokey Ass Message Board' started by Eth727, Nov 6, 2025.
  1. Eth727
    Eth727
    IMG_8722.jpeg IMG_8721.jpeg Hey guys I’m installing a Edelbrock carb onto my 63 impala with a stock 327 manifold. It doesn’t look right. What do I need to get to make it fit properly? Thanks
    bchctybob and chryslerfan55 like this.
  2. Budget36
    Budget36
    Edelbrock performer intake. Or the RPM Performer.
    I don’t think I’d want to run an adapter, even if ones made.
    Edit: If not corroded up, a used intake will work as good as a new one. Just won’t be a clean.
  3. jimmy six
    jimmy six
    Taper adapters are made and reasonable. Off shore manifolds new are also. Used (take your pick) are on many sites. My choice would be a stock Rochester 4 GC.
    Mark Yac, bchctybob, alanp561 and 5 others like this.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ....or it would work without an adapter on a factory 327/300 HP intake manifold. If you do that, be sure to run the stainless steel heat plate under the carb, or the raw exhaust that comes out of the two heat riser holes will warp it.
    tractorguy and chryslerfan55 like this.
  5. saltracer219
    saltracer219
    There are 1/2" thick adapter plates made to do this, it was very commonly done in the 60's and 70's. I have several if you need one.
    Packrat, bchctybob, 2OLD2FAST and 3 others like this.
  6. Eth727
    Eth727
    Is this what I need?
  7. If you use an older manifold make sure to use a 2732 flat plate adapter, even old Edelbrock intakes have problems with Edelbrock carbs.
  8. Eth727
    Eth727
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
  10. DDDenny
    Four jet carb not Quadrajet.
  11. 19Eddy30
    19Eddy30
    from VA
    If you have this spacer, & needing in tight Fix low On Funds Need to drive
    This adapter would work,
    Also needing sheet of aluminum
    Road sign or 1/8 plate
    Need cardboard for template and drill holes.
    Bolts & stud's
    My self in p*** I have taken
    & added threaded to 5/16 bolt holes
    To 3/8 's & 7/16 & used step stud's .
    Not perfect solution and IF Not looking for max power being under 300 hp it would work,
    One correct gasket for intake ,
    Then One heat shield
    Then another Gasket later Q Jet or
    holley gasket ,
    Then Spacer
    Then Edelbrock gasket
    Then Carb ,,,
    Yes a Frankenstein !!!
    Road Kill engineering
  12. Eth727
    Eth727
    What’s the difference? Which is the correct one then?
  13. 19Eddy30
    19Eddy30
    from VA
    first 2 pic typical Q-Jet two small ****erflies and two large ****er ****erflies
    secound 2 is a 4 -Jet
    bchctybob and Budget36 like this.
  14. Bob Lowry
    Bob Lowry
    Correct GM intake for a Carter AFB or Edelbrock is 3844459. I bought one last year for $10 in
    good condition on CL. Or, use your current intake with a Rochester 4GC, as shown above.
    Here is a couple of pics:
    bchctybob, 427 sleeper and Mimilan like this.
  15. Moriarity
    Moriarity
    SUPER MODERATOR
  16. Eth727
    Eth727
    I have a new Edelbrock 1403 carb. Im not getting a different carb. The old carb was a Carter WCFB. This is a pic of the stock intake IMG_8724.jpeg
    gimpyshotrods and bchctybob like this.
  17. Eth727
    Eth727
    Is there anyway I can use a 1403 Edelbrock on this intake?
    gimpyshotrods likes this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
  19. DDDenny
    Is it running yet?
    gimpyshotrods and Johnny Gee like this.
  20. Eth727
    Eth727
    Forget the old carb or any other carb. I will be using a brand new Edelbrock 1403 with the exhisting intake. Is the speedway adapter going to fit for sure because I’m going to buy it?
    bchctybob likes this.
  21. Eth727
    Eth727
    Okay the intake will have to be changed out. There’s no way it’ll work. Okay gm 3844459 intake is what I need. I haven’t gotten to the choke yet. Just trying to get this god damn thing to fit.
  22. UpNorthGreg
    UpNorthGreg
    There's a bunch of those intakes on eBay.
  23. Eth727
    Eth727
    Is Edelbrock aluminum going to be better?
  24. riv63
    riv63
    from Texas
    You seem to be a likeable guy so I will try to be nice.
    The answer to your questions have been answered about 6 times above. Please read them carefully and you will find the information that you need. Do you have a reading comprehension issue?
    The aluminum verses the cast iron will not make any difference in your power level.
    Good luck with your Impala.
  25. Joe H
    Joe H
    Under normal, everyday driving conditions, the carb and adaptor will work. If you have the carb, use it with the adaptors listed from Speedway Motors. Yes in race conditions, the carb may not be right and adaptors do impede air flow, but for normal driving, you probably won't notice.
    Just be sure when you install the adaptor, there are no obvious sharp edges or protrusions that don't need to be there. You may need to do some carb tuning with jets and rods, but until you get some drive time, run as is.
    F&J and bchctybob like this.
  26. F&J
    F&J
    He wants to use the new carb and intake manifold he has.. . and .. he's not competing at Daytona looking for the last ounce of horsepower at 9000 rpms.
    He's never going to notice any difference. Golden boys or is it girls?
    Like a two barrel? That's pure nonsense. I can't believe anyone would say that.
    And you want to overcomplicate things further with a relay on the choke? Geezus , someone has to call out bs when a person needs basic help.
  27. bchctybob
    bchctybob
    The short answer is YES, the simple adapter from Speedway will get your Edelbrock 1403 bolted onto your existing manifold. Be careful with the gaskets, make sure there aren’t any air leaks like those in your first picture with the open gasket. The correct gaskets should be included if you buy the kit shown from Speedway.
    After driving it for a while you might need to make mixture adjustments. Consult the Edelbrock book that came with the carb for simple changes. I think the book is online if you didn’t get one.
    A better intake manifold will help you get the most out of the new carb but it’s not absolutely necessary. Your car will be fine with the carb and adapter.
    I understand your frustration, answers online can offer so much extra info that it gets confusing. Everyone is just trying to help.
    Good luck
  28. Eth727
    Eth727
    I really appreciate all the help even if some people add more information. I’m just ignorant and thought a new Edelbrock was plug and play. Isn’t a 63 impala w/327 one of the most common cars? There should be an adapter but why do they sell them if they’re only going to get the car running? Doesn’t make sense. Then there’s the intake. Want aftermarket carb ? Yeah you’ll have to spend $200 on another intake to make $300 carb work. I’m going to try the adapter because it’s a cheaper and easier route. If it doesn’t work then I’ll change the intake.
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Keep in mind the two adapters posted by Moriarity and myself. Meaning, Moriarity post is based on experience and what I posted is based on your wording as to what factory carb you took off. Read all the tech specs (bolt patterns) for both adapters as well as all the Q&A’s provided from Speedway. Doing such will be of great importance in educating one’s self.
  30. Squablow
    Squablow
    For what it's worth, I have an Edelbrock on an adapter in my 57 Chevy and it works fine, no issues after 5 years and 20k miles of driving. I'm using a different intake so I required a different adapter but if you get the Speedway one mentioned above it'll work, just make sure your gaskets seal and your linkages line up and have clearance, you'll be good.
