Technical Chevrolet 283 build for fuel economy
Discussion in 'Traditional Customs' started by Hillbillytrucker, Nov 2, 2025.
  1. Budget36
    Budget36
    ‘57 Chevy PU and fuel economy is a mismatch.
    Write down your average use per day, miles, etc.
    Figure your fuel bill getting 14 MPG and having some fun with the old girl, vs 17 MPG.
    Maybe 1 less trip through the drive through for a #5 in a week.
    get a clapped out import on the cheap for a commute car, enjoy the ‘57.
    jet996 and kadillackid like this.
  2. 283john
    283john
    Comp XE250H cam. Find a T5 transmission to stick behind it. 3.42-3.73 rear gear.
    rod1, 1Nimrod and Sharpone like this.
  3. Tickety Boo
    Tickety Boo
    from Wisconsin
    During the first gas shortage, Hot Rod Magazine modified a Chevy station wagon for a mpg article in the mid 70s,
    I think they claimed something like 20 mpg with their station wagon :rolleyes:
    So, did their modifications to my 307 ci sbc C-10 pickup and had a lot of fun, got really good results.
    Been a while but this is what I remember,
    A single plain intake manifold, with a Rochester 2 jet carburetor mounted forward on an adaptor plate to locate it at
    same place the primary 4-barrel plates resideo_O
    I know this don't sound good; the theory was that at part throttle, partial open blades would dump the fuel in the center of the open plenum manifold giving all 8 cylinders equal opportunity.
    Headers with an H pipe to dual exhaust
    I also put a set of 283 heads on to increase compression, I remember about 18 mpg, it was a truck and was a stone in the wind
    Maybe someone can find this issue, I'm sure I forgot some stuff :oops:
    Deutscher, rod1, 1Nimrod and 2 others like this.
  4. rockable
    rockable
    Nobody has mentioned the distributor. After you've done the things you decided to reap from all the previous suggestions, you need to do some distributor tuning. If you don't get the vacuum advance and mechanical advance curves right, you won't have the economy you are tying to achieve. The vacuum advance has a lot to do with fuel economy and takes some experimenting to get right.
  5. jet996
    jet996
    from WY
    Just my .02 cents instead of changing both rear end and transmission, put a 4L60 behind it. The 283 will be way more fun with the short gears and in O/D you're still at about a 3:1 effective top gear. Set up a Qjet. The old Edelbrock SP2P is a good torque/mileage intake. Like @rockable said, a good set up distributor pays big time. A Jacobs system or some kind of dealy like that works good. . Cam choice is whatever you want. I've had good luck with Schneider cams.
  6. krylon32
    krylon32
    from Nebraska
    I drive my deuce pickup year round except during salt season. The motor is a 55 265 Chevy with a mild cam and performer manifold, 350 trans and a 3.00 9 inch rear. When I traded for it 12-13 was tops. After a lot of trial and error we finally got the distributor set right, took off the old Edelbrock and put on a new Edelbrock 500 cfm AVS2, bought the carb tuning kit. and after several adjustments we got up to between 20-22 depending how deep you plant your foot. If I keep it at about 70 on a good day I can squeeze 22 but I'd say 20 is closer. If I get on the freeway and run with traffic (80 ish) it'll drop to 17-18.
    jimmy six, swade41, choptop4 and 10 others like this.
  7. poco
    poco
    from oklahoma
    I have a chevy engine that was made 3 years only that was made for a thrifty engine, i have that is complete and ready to install if any is interested. Will sell at a bargain price. Also have a 283 that complete except sone of the accessories.
    Sharpone likes this.
  8. 6sally6
    6sally6
    Use thinner/lo-tension rings in the build.
    6sally6
  9. twenty8
    twenty8
    First gear in a 700r4/4L60 is quite a bit lower than a TH350.
    3.06 first gear ratio x 3.36 rear end ratio = 10.2816 overall ratio in low gear. This is right at the sweet spot for a street car. It will get up and boogie when you want it to, and will have lower highway cruising revs in overdrive than the TH350.
    This will help fuel economy, and at the same time put a smile on your face...:D
    @ekimneirbo , where are you getting 700r4's or 4L60's with a 5th gear...??? Let us in on the secret. I want one....:p
  10. Clydesdale
    Clydesdale
    How much fuel does one have to go through before you get a pay off from all this additional expense to make it 'economical'?
    I appreciate you're building a fresh motor here so you gotta buy stuff anyways, but all this additional stuff of transmissions and rear gears etc is really going to add up.
    Personally, I'd build a nice solid mild motor, get it in the truck and enjoy it, life is too short to be mired in projects forever.
    If you want to save money, go easy on the right foot and perhaps cut back on other small expenses in life and you'll be surprised.
    My 2c
    427 sleeper, Budget36 and GuyW like this.
  11. twenty8
    twenty8
    You won't save the planet with an at***ude like that......:rolleyes:
    jet996 and firstinsteele like this.
  12. Hillbilly Werewolf
    Hillbilly Werewolf
    I am also a big proponent of "drive it, dont make it an unnecessary project "
    But, I also think overdrive transmissions, and adding extra gears is a great thing for old customs and hot rods. Sure, he is asking specifically about fuel economy, but a lot of that can be gained with making things efficient. Stuff like getting the quench right can really help gas mileage, but it also will make more power across the board, and help with drivability. Win win.
    Having a automatic OD and the right rear gears are the same: the cost is balanced out between gas savings, and better performance and pleasant highway cruising sound (and engine wear) reduction.
    So is the cost worth the MPG savings? Probably not. But having a truck with near modern power, range, and drivability? That starts spreading the "worth it" out.
    jet996, GuyW, ekimneirbo and 3 others like this.
  13. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    @Clydesdale Not having to Know or find the next gas station before that needle falls,
    can make for a happier ride.
  14. cfmvw
    cfmvw
    Years ago I had a 455 in a Pontiac LeMans. Q-jet, recurved HEI, MSD, mild cam, headers, SP TH400, and a Ford 9" with a 2.75 ge****t. I was able to get 19 mpg on the highway out of it.
    GuyW likes this.
  15. Sharpone
    Sharpone
    Exactly, anyone who has rode a motorcycle with a small tank understands this, continuously stopping for gas is a pain in the ***. Plus this is a hot rod site, so being logical or making financial sense goes out the window as soon as you walk through the door. :)
    Dan
    427 sleeper, jet996, X-cpe and 4 others like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Bigger fuel tank. Done
    427 sleeper and Sharpone like this.
  17. oldolds
    oldolds
    A lot of talk about overdrive set ups behind this 283. You need to be careful with that. An economy built 283 will not overcome steep gearing and tall tires. It will need to turn about 2200 - 2400 rpm at the desired speed so it is not lugging. My father had a 67 Chevy pickup he bought new. 283, 4:10 rear with overdrive. He did a run of 200 miles, 3 times a week. He put the tallest 15" tires on it he could find for gas mileage. He only did one trip like that. It got about half the mileage and had no power compared to previous trips.
  18. krylon32
    krylon32
    from Nebraska
    Just rolled into the garage after about 250 road miles today with the 32 pickup. Took 2 lane 90% of the time, checked it twice and was getting about 19-20. Also quite windy. I'm happy.
    Tim, anothercarguy, Sharpone and 3 others like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’ll have to check the red 56 to be sure. 283 TH350 3:08 rear. Pretty sure it’s 18-20 range.
  20. A th350c sounds like a fun choice.
    700r? If you have one laying around.
    I’m a run what ya got person
    You can buy a lot of gas to build something you don’t have.
    Budget36 and X-cpe like this.
  21. swade41
    swade41
    from Buffalo,NY
    How about a streetmaster intake with a 500 cfm Edelbrock carb or if it's spread bore intake (they come either or) and a quadrajet or spread bore holley, wth this cam
    Summit Racing SUM-K1101 Summit Racing™ Cl***ic Cam and Lifter Kits | Summit Racing https://share.google/nprQsOdupmdd19SDd
    Of course some headers and dual exhaust.
    Let's see a photo of the truck, I'm currently doing a 57 pickup myself.
    Edit, I believe this was a streetmaster I had on my t-bucket at first, with a 650 dp spreadbore, thing had the best "kick it in the guts" out of all the intake carb combos on it.
  22. chevy57dude
    chevy57dude
    What are the specifics of this engine?
  23. Only cost $50-70 more to build my 283.
    same hp as a 350? Nope
    Cheaper? Yes,overall. I had a freebie 283.
    And I didn’t want a 350.
    It’s not rocket surgery. Just a simple stock rebuild Maybe a very mild cam.
    Enjoy
    Sharpone and Moriarity like this.
  24. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The TH350 was on the garage floor. 3:08’s were already in the car when we got it. The 283 replaced the 235:
  25. carbking
    carbking
    A number of members have mentioned that a 283 is NOT a torque-monster, and actually do better at somewhat higher RPM.
    Some have mentioned that an overdrive manual transmission would be better on fuel economy than the automatic.
    As far as carburetor selection is concerned, consider the following facts:
    In 1957, the Rochester 2-barrel used on the 283 was rated at 278 CFM.
    In 1957, Chevrolet offered a 283 in the Corvette with a "special race cam". This engine came with a special Carter WCFB four-barrel number 2493s that was rated 380 CFM.
    In 1957, Carter offered production 4 barrel carburetors from 295 CFM to 675 CFM. Chevrolet thought the 380 CFM was sufficient for the racing engine.
    So given the above for a racing engine, what about an economy build?
    How about rebuilding the original 2-barrel, which I am ***uming you have, and use the original Chevrolet intake manifold, which I am ***uming you have ?
    I personally believe there is more fuel economy available in the choice of transmissions, and, when needed, a set of radial tires, than is available in any carburetor / intake manifold swap.
    And rebuilding what you have is certainly going to be less expensive than the purchase of any different carb or intake. Sometimes it is best to admit the factory engineers knew what they were doing !
    Jon
    GuyW, rod1, twenty8 and 4 others like this.
  26. Don’t over think it
    Use what you have. That 283 was born with everything you need to enjoy it.
    Stock rams horns, intake, distributor and carbs
    pick out a stock or mild cam. just buy quality lifters.
    use whatever trans you have
    Emjoy
  27. Pav8427
    Pav8427
    I ***ume he is talking about a 262 V8.
    Used in Monza's.
    3.1 stroke x 3.761 bore.
    Always thought the crank put into a 400 block would make a fun short stroke/big bore 336 cube combo.
    chevy57dude and jet996 like this.
  28. Joe H
    Joe H
    Just some simple math,
    $1000 in gas at $2.82 per gallon will go 6380 miles @ 18 miles per gallon ( 355 gallons )
    $1300 in gas at $2.82 per gallon will go 6454 miles @ 14 miles per gallon ( 456 gallons )
    You save 101 gallons of gas for every 6400 miles at 18mpg over 14 mpg.
    Whats the cost of carburetor, intake, transmission, and gear ratio? How far will you need to drive to break even for what you spend?
    Use what you have and optimize every part of it, a '57 truck is not anything like a modern truck aerodynamically, so a comparing to one is not accurate.
    2OLD2FAST and Sharpone like this.
  29. fastcar1953
    fastcar1953
    So for most that would be about $300 savings a year.
    Overdrives cost around $1800.
  30. DDDenny
    Good gas mileage is overrated and makes for a boring drive!
