Technical How can Edelbrock carb fit 63 Impala w/327 manifold?
Discussion in 'The Hokey Ass Message Board' started by Eth727, Nov 6, 2025.
  1. 2OLD2FAST
    2OLD2FAST
    from illinois
    The " how hard can it be " statement ...LOL well , when you don't know what you don't know , it can get pretty confusing , even when you do know , righteous information can be hard to come by ... Be glad it's not a Ford they have multiple engine families with little or no conformity between them ..
    427 sleeper, 19Eddy30 and Algoma56 like this.
  2. carbking
    carbking
    I can understand your frustration.
    Understand that when you post a question on the internet, you will probably get a number of different answers that often do not agree with each other. This because there is often more than one way to accomplish something.
    Understand that virtually all of these answers are from folks who are genuinely attempting to help.
    Some folks are going to offer information of a different path; generally because of personal experience, and the desire to help. As an example, some folks, including myself DETEST the adapters because they rob engine efficiency thus power and / or economy. Without going into fluid mechanics; just consider the water velocity in the straight stretch of a river versus a curvy stretch. Liquid does NOT like corners.
    As to your comment about "plug and play", just consider that Chevrolet made 327 engines in a variety of stages of tune. If you had a 327 / 340 HP then I think the clone would be plug and play. Chevrolet used different intake / carburetor combinations depending on the stage of the tune:
    Chevrolet 1963 327 / 250 HP used Carter WCFB or Rochester 4GC. The Carter rated at 400 CFM
    Chevrolet 1963 327 / 340 HP used Carter AFB rated 625 CFM (actually 650 CFM - marketing)
    As a suggestion, if you still have the original WCFB or 4GC, keep it, and in your spare time, rebuild it. At worst, you will learn something about the design and function of a carburetor.
    As a further suggestion, should you do the above; with a buddy and a good stop watch, run 3 timed zero to the speed limit in your area runs with the clone and adapter, and record and average the times. Then temporarily ? remove the clone and adapter and install the original rebuilt carb and repeat the timed runs. Compare the results. Then you will have first-hand proof about some of the information given to you. Testing is ALWAYS useful !
    Have fun !
    Jon
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Jon @carbking as an FYI, does the Carter WCFB and Rochester 4GC share the same base plate dimensions?
    Sharpone, 427 sleeper and Moriarity like this.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    yeah, I suggested the adapter above before I knew what carb he has. He should read the descriptions in the ads and measure his manifolds bolt pattern to make darned sure that he is getting what he needs
  5. carbking
    carbking
    Sometimes, not always.
    Also, even though the mounting dimensions may be same, the sealing area often differs, requiring a number of different mounting gaskets.
    This question should ALWAYS be asked about a SPECIFIC model, e.g. 3697s WCFB. General questions, generally get incorrect results.
    In the case of the 1963 Chevrolet 327 - yes.
    Jon
    Sharpone and mkubacak like this.
  6. jimmy six
    jimmy six
    Yes a 250 hp was extremely common. The 300 hp with a stock AFB were mostly on 4 speed cars…..
    Sharpone and 427 sleeper like this.
  7. 1biggun
    1biggun
    Spe
    Its up to you to decide if your 62 year old car is worth spending $350 or $420 on .
    The adapter is about a 1/4 of the cost of a cheap intake .
    The swap meets are full of cheap SBC intakes. There are 1000's of factory intakes around used as well.
    you could have rebuilt or had rebuilt the original .
    No the Edelbrock does not fit every old car that had some other 4BBL on it directly .
    Thats why they make addapters
    Personally aside from keeping it original I'd buy the Performar intake and be fine with it . It will run about as good as your going to get with out a lot of carb tuning knowledge.
    The next thing is your likely going to want a fuel pressure regulator on that Edelbrock carb.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
    if he puts that manifold on his car there will be no place to add oil also there will be no place to put the needed breather for the road draft tube
    Squablow, BJR, 427 sleeper and 2 others like this.
  9. 1biggun
    1biggun
    All valid points.
    OP its not going to work with out more adaptation .
    That said some cool new valve covers and a PCV going to the new carb would not hurt.
    Id run the addapter if $$$ and time/ work are the biggest obstacle.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    I know that the OP is trying to learn about cars and that everyone needs to start somewhere. I honestly think that if people talk him into changing the manifold the next posts we will see from him will be "how do I get my car back in time?" or "why is my engine leaking oil from the back of the intake manifold?" ... Let's just let him run the adapter, It will be fine....
    bowie, Squablow, BJR and 9 others like this.
  11. gimpyshotrods
    gimpyshotrods
    And the adapter is $22, plus two gaskets.
    My mistake, it comes with the gaskets.
    Squablow, 4274SPEED, twenty8 and 4 others like this.
  12. Budget36
    Budget36
    I’d bet it’s been asked, but @Eth727 , do you really need a new carburetor, or just want a new one?
  13. blue 49
    blue 49
    from Iowa
    I had a 305 in my '36 for a while with an SP2P4V with a 570 CFM Holley Street Avenger. Worked OK but was ****ing oil past the gasket. Warped flange. I put on a '61 283 4BBL manifold with this home made adapter I made from 1/2" aluminum. I plugged the exhaust holes with 7/16" frost plugs in the manifold and used a thick, insulting gasket on top, under the same carb. It ran OK also. Good off idle but ran out of steam pretty quickly.
    Gary
  14. carbking
    carbking
    In this case, I would concur. It won't be perfect, but it should function until he wishes to do something else.
    Jon
  15. Eth727
    Eth727
    So I got the adapter and it worked. Carb is all hooked up but idle is too high. I started another thread for that issue. IMG_8735.jpeg
    Squablow likes this.
