Hot Rods 1940 Ford Steering Box
Discussion in 'The Hokey Ass Message Board' started by Joe Mac, Nov 9, 2025.
  1. Joe Mac
    Joe Mac
    I have a 40 Ford Standard Coupe, with what I believe is a 1940 steering box, anybody know what the reason the black wire is going into the bottom side of the steering box. The other end goes to the silver relay?
    Thank You
  2. big duece
    big duece
    from kansas
    Cut it and see if your horn works...
    LOU WELLS and chryslerfan55 like this.
  3. piker
    piker
    Horn ****on.
  4. Joe Mac
    Joe Mac
    Is the fluid in the steering box separate of the wire, as I plan on checking and adding some type of grease if it needs it. Haven’t determined which type yet.
  5. big duece
    big duece
    from kansas
    The 4 bolt cover on the end that covers the worm bearing, it has a br*** or steel tube that houses the wire. The tube is long enough to go through the oiling cavity. No need to worry about adding more fluid. Leave a little room, for when the grease expands from heat. John Deer cornhead grease is used a lot.[​IMG]
    warbird1, LOU WELLS, Budget36 and 2 others like this.
  6. Joe Mac
    Joe Mac
  7. Mr cheater
    Mr cheater
    Rare Ford option Electric steering ***ist
    325w, LOU WELLS and big duece like this.
  8. poco
    poco
    from oklahoma
    corn head grease is very hard to get in steering box,but works very good
  9. dwollam
    dwollam
    I just pull the pipe plug on old steering boxes and install a zerk fiting. Corn head grease works great.
    Dave
    1946caddy and warbird1 like this.
  10. Paul Radford
    Paul Radford
    What about the horn?
  11. 325w
    325w
    Horns don’t need grease. . Have 525 box in a 32. Was NOS when installed 30 years ago. Will it have grease are heavy oil in it?
  12. Paul Radford
    Paul Radford
