2800 Ford V6 build progress report 11-8-25
Discussion in 'Off Topic Hot Rods & Customs' started by Mummert, Nov 8, 2025.
  1. Mummert
    Mummert
  2. T. Turtle
    T. Turtle
    Is this a German (Cologne) V6 or some US version?
  3. RMR&C
    RMR&C
    from NW Montana
    Thanks for the update. What vehicle will this be going into?
  4. Mummert
    Mummert
    The plan is to put it in my 69' mgb gt
    RMR&C likes this.
  5. Pontmerc
    Pontmerc
    from Finland
    Let me quess...with ford type9 gearbox?
  6. Mummert
    Mummert
    This is the U.S version, 3 exhaust ports, built in Germany. All 2.6, 2.8, 2.9 4.0L were made in Germany.
  7. Mummert
    Mummert
    T-5 ******. What is a type 9?
  8. mustangsix
    mustangsix
    I was once looking at the 4.0 version. Any pitfalls with that one?
    The type nine is a five speed available on several British and German models. It a pretty compact unit that is popular for five speed conversions on a number of British sports cars.
  9. Mummert
    Mummert
    The 4.0 runs well. None of the thinwall casting engines do well if they get hot, but if you keep it cool I've heard they are very reliable.
  10. T. Turtle
    T. Turtle
    Right. Ours - I'm talking about the UK 30 years ago - all had siamized ports and thought of as inferior to the local Es***. But the Es*** was HEAVY:eek:
  11. Mummert
    Mummert
    Seems like siamese heads run good modified up. I tried to find some here before I worked on the U.S. versions to make my headers easier.
  12. Mummert
    Mummert
    Thats funny the Cologne engines are known for being kind a tank in the U.S.
  13. T. Turtle
    T. Turtle
    Dave Williams' well-known chart gives 305 (Cologne) vs 379 (Es***) but what he shows for other Ford V6s is heavier, and that I presume includes "your" Colognes...
  14. Mummert
    Mummert
    I'm sure it has much to do with the dress of the engine. Cologne engine with a pretty full dress I've heard quoted at 370's lb.
    What Dave say about an MGB engine?
  15. T. Turtle
    T. Turtle
    He does not list it but from my days in the UK I remember it being something like 360 lbs. Generally a popular swap was the Buick/Rover all-ali V8 which was much lighter so improved the handling, plus was done by Costello and then the factory back in the day so all the bits were available, not so with the Ford V6s. A bigger "US" Cologne should weigh more than the "Euro/UK" version I ***ume...
  16. Mummert
    Mummert
    What does an Aluminum 215 Buick weigh?
