Projects 1935 Ford 5W Coupe Project NZ - The Sows Ear.
Discussion in 'Traditional Hot Rods' started by Fairlane500, Oct 31, 2025.
  1. SO... I picked up a 1935 Ford 5W Coupe, I like a good project, a blank canvas to create your own outcome. This one is an ideal candidate, as anything from here in will improve the vehicle. (read I dont think I can **** it up anymore) If you are not familiar with my 1934 Tudor project it is here Projects - 1934 Ford Tudor - Bonnie | The H.A.M.B. this build thread will be along the same lines, so welcome back and to first time watchers, Hello from New Zealand. 01 35 Coupe Mrs Whitfields  (2).jpg
    emil, RMR&C, Bandit Billy and 17 others like this.
  2. SS327
    SS327
    Not a bad looking starting point at all!
    Tow Truck Tom likes this.
  3. A quick walk around the Sows Ear and you will see there is plenty to do, but prewar V8 coupes are hard to come by here in New Zealand and most who own them are not in a hurry to part with them, Fair enough to. I don't know a lot about this vehicles history yet as I bought it from an estate. I am sure as time goes on, some more details will come about.
    So my initial plan is to get this thing mechanically mobile as soon as possible so it can be moved about, I am too out of shape to be pushing dead weights around, It has got a locked solid stock 21 stud engine in it with a head missing, unlikely to grace its engine bay in running form again, a 1936 trans with stock looking 1935-36 rear in it, a 1937-39 Steering box, a stock 1936 front end and half mechanical (front) half hydraulic (rear) brakes. I haven't really explored it in full yet, I have it in storage whilst I create a bay space for it in the garage.
    For now, the old 24 stud C51A engine from the 1934 Tudor will see active duty again with either the current trans that is in the vehicle if its any good or a rebuilt 39 trans will be put together, a run through the steering box, front axle, rear axle and add hydraulic brakes, a little bit of lowering, some spring therapy or replacement, a complete rewire as there is no wiring whatsoever in the vehicle and then some sheet metal work as needed. This car will need a complete floor replacement and other rust repairs 35/6 coupes are prone to and a Interior of some description (seat) as it has no interior whatsoever.
    Longer term goal will be a re-built engine, and a similar build spec to my other cars, LZ gears in Transmission, Lincoln Brakes, 9 inch axle conversion, 3:54 rear, Posies Super Sliders reverse eye springs, Sway bars front and rear and Gemmer 3 steering, Stewart Warner Gauges, Strengthened Radiator tanks and pressurised cooling system.
  4. SS327
    SS327
    You need to move the steering wheel to the correct side of the car too. :D
    Yes we are Right hand drive here in New Zealand and Australia, Our cars in 1935 were Canadian Sourced CKD and some models were ***embled here by Colonial Motor Compoany and many imported fully built up, 1936 was the first year NZ cars were ***embled in the Ford Factory Owned Plant in Seaview, Wellington.
    mvee33, Outback and Chris L. like this.
  6. So 37-39 axles and wheels?
  7. THE AXLES - Front axle is 35/36 type with 36 Spindles and drums by the look of it and the rear axle 35/36 with 36 Drums and a non-stock, funky mechanical backing plate that has had a hydraulic cylinder grafted into the top of the backing plates. The Serial number of the ch***is is *C18JF- **** which denotes its a Canadian Built (C) V8 (18) 1935 (J) RHD (F) Ch***is.
  8. @Fairlane500 great looking project! Good luck with it and I'll be following!!
  9. Grumpy ole A
    Grumpy ole A
    This looks very interesting. I am watching this one.
    Fairlane500 likes this.
  10. DASH: Had some spare time today, so pulled a dash I picked up recently and added the 35 Waterfall I had and some Stewart Warner Wings Gauges, The Volt gauge will be swapped with Temperature in due course and will fit the Voltmeter and Fuel Gauge in the header panel later, keeping an eye peeled for an ashtray to fill the hole in waterfall. The gauge adapters are Phoenix Machine items and work really well. 575627863_1124291786135023_1406550578182015315_n (1).jpg Dash Gauge Adapters.jpg
  11. PARTS RESEARCH: Theres always a lot of research that goes into a project and that is one of the allures of the hobby, learning what parts goes with what and what interchanges can occur and what combinations ultimately give the best performance and overall results. Things I have found over time is you never stop learning, there is always someone who knows something you don't, and in the grand scheme of things you don't know ****. every day is a school day, and you can learn something new every day if you are open to it.
    1935 and 1936 Spindles, after a chat with my local weekend car crew I was talking about the 35 Coupes front end options and installing 39 spindles and 40 hubs with Lincoln backing plates and drums. We got talking about differences form 35 -40 and what to be aware of with changes between the years, I am going to run a 37-39 steering box with same pitman arm, there are differences in the drag links early having different rod ends being fixed and not adjustable, and then we got talking about 35 36 spindles, anyway I though I would share this as I found it interesting and once learnt very easy to identify the difference in 35 and 36 spindles. The 35 Spindles being 5 5/8 long and 36 being 5 3/8 long. 577303180_1163911502538826_732848824474204931_n.jpg 578568904_771213092632856_1684552774817609453_n.jpg
  12. Martinbuilt
    Martinbuilt
    I thought '36 was the long one (spindle).
    Not an expert, but i have a set of '36 drums here that don't fit anything else.
    Hopefully, someone will jump in and confirm your measurements.
    Outback likes this.
  13. Outback
    Outback
    from NE Vic, Oz
    Will follow along, from another down under fulla
  14. 35/36 backing plates are dished like Model A and B backing plates. So the brake surface is biased to the centre of the car compared to the hydraulic backing plates which are flat. '36 drums are pretty much the same as Ford Pilot ones.
    Outback, Fairlane500 and Martinbuilt like this.
  15. So question for all you Coupe owners out there, do you have some photos of an Original 35/6 coupe seat with the lift up rear swab? Any and all photos requested from bare frames to fully upholstered. And does your coupe possibly have a different factory seat arrangement? Below pic stolen from another HAMB Thread, I was told the steel base is the same on all models, anyone know if this is correct or incorrect? [​IMG]
    Outback and Deutscher like this.
  16. Lucky to have the sparewheel cover as well. :cool: btw, two 1935 Ford Coupe threads together today,
    emil and Fairlane500 like this.
  17. 35cab
    35cab
    I had a 35 coupe seat in my 35 cabriolet, really liked the fact that the backrest could be lifted as I could house the battery out of the way plus room to carry a toolbox etc. Having a rumble seat this space was useful. The steel base looked like the one in your photo. Good luck with the coupe.
  18. Thats a super nice cabriolet, thanks for the reply much appreciated. What does a original cabriolet seat look like? does it have a fixed back? or ????
  19. 35cab
    35cab
    When I got the car (nearly 30 years ago!) it came with a home made base and the backrest(s) which split and folded forward for access, a bit like a 40 Tudor set up. This was obviously not original. Cabriolet seat was a fixed back. Good info available from the Early Ford V8 Club"s book on 35/36 Fords.
    It took me a while to round up a base, runners and a pattern for the side panels, repro spring set etc.
    I have since sold the car and the guy that bought it replaced the base springs with foam to allow him to sit lower which I think is something to consider, depending on how tall you are.
    I was ok with the springs but felt the base was a bit high particularly for getting in and out negotiating the steering wheel.
  20. Bandit Billy
    Bandit Billy
    My first pre war car was a 36 five window coupe. Always had a soft spot for these cars. I'll be following along.
  21. Kiwi 4d
    Kiwi 4d
    A little OT , but we are required to crack test stub axles down here. Just as well, didn’t expect this mess. They must have had an interesting past.
    Deutscher, Fairlane500 and Outback like this.
  22. Outback
    Outback
    from NE Vic, Oz
  23. So learning quite a lot about the 35 as I go and starting to notice variations and reading, learning about variants. To date I have learnt there are early and late, lower grill pans, early plain and later louvered inner guards, early front and later center inner door handles, early and late radiators and I am sure I don't yet know it all,
    What knowledge of early / late 35 differences are you aware of?
  24. Very nice interior!!And functional :cool:!!
  25. lo-buk
    lo-buk
    from kcmo
    I have heard that the headlight lens and bezels are also different.
