Technical 390 upgrade question
Discussion in 'Traditional Customs' started by 57Buick, Nov 10, 2025.
  1. Jeff Norwell
    Jeff Norwell
    MODERATOR
  2. lostn51
    lostn51
    from Tennessee
    I’d listen to Jeff and talk to the feller that knows the FE motors like the back of his hands. But it sounds like you just want something that makes a little noise and you can play in a bit.
    If it was me I’d call Comp Cams and have them build me a “Mutha Thumper” cam, get the appropriate intake/carb and then port and polish the heads with a good set of headers, put a 4 speed in it and have some fun.
    57Buick likes this.
  3. stuart in mn
    stuart in mn
    57Buick likes this.
  4. 57Buick
    57Buick
    from Alabama
    Good info. Thanks !
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    When I put a camshaft in my big block chevelle a few years back, I was worried about cam and lifter failures too. I ended buying an ISKY cam and lifter set. I figured that a company that had been in business that long wouldn't risk their reputation by selling junk parts. Mine went great.... Also of all the failures that I had read about, I never read about one that involved isky parts
  6. cpraceman
    cpraceman
    from walls, ms
    That is THE coolest FE Model A you could ever dream up !
    Sharpone likes this.
  7. Jmountainjr
    Jmountainjr
    Nothing wrong with a good quality flat tapped cam. Especially if you take the precautions to ensure success:
    Lifter to bore clearance; oil flow mods; break in springs; correct break in process.
    Sharpone, 57Buick and anthony myrick like this.
  8. Chiefrider
    Chiefrider
    from Lower 48
    After seeing his name spelled incorrectly, three different way- it's BRENT Lykins lol
    57Buick likes this.
  9. Troy,
    I ***ume you are going to use the motor you got from Kenard? I would clean up the heads with a valve job, flat tappet cam of your choice, aftermarket intake and headers, curve the distributor, and call it a day. If that doesn't give you what you want, go full tilt on the motor you got from Chris, following the advice from the FE gurus here.
    57Buick, Sharpone and anthony myrick like this.
  10. mammyjammer
    mammyjammer
    from Area 51
    Can’t remember the whole story, but the problem is you can’t get the “Good Stuff” in the cam break in lube anymore. That is what has been causing a lot of flat tappet cam failures.
    That being said, I broke in the Comp cam and Comp lifters in my FE with (a lot) of their lube and it is fine.
    A set of Prescion Oil Pumps rocker shaft stands is worth the investment.
    57Buick likes this.
  11. Sharpone
    Sharpone
    @Mummert has a good video on cams and lifters. He talks about buying a couple extra lifters and hardness testing them. Not sure what hardness is desirable maybe he, @chicken or @PackardV8 would know. I agree with @Moriarity with using Isky lifters, don’t think you’ll go wrong they’re a little pricey but I’m sure the quality is there.
    https://www.jalopyjournal.com/forum/threads/flat-tappet-cam-one-more-step-towards-success.1343053/
    Another good thread.
    https://www.jalopyjournal.com/forum/threads/camshaft-advice-needed.1314239/page-2
    57Buick and Moriarity like this.
  12. 57Buick
    57Buick
    from Alabama
    Thanks for checking back in. Yes, you are correct on the Kenard engine. I like your ***essment here and it is tremendous advice, just as you have offered in the past. Thank you
    sir.
    Bangingoldtin and Sharpone like this.
  13. 57Buick
    57Buick
    from Alabama
    Thanks !! I appreciate the links
    Jeff Norwell and Sharpone like this.
