Technical 1932 ford roadster juice to bendix or disc
Discussion in 'Traditional Hot Rods' started by Sdsurfer01, Nov 4, 2025.
  1. Sdsurfer01
    Sdsurfer01
    @3blapcam yes I agree on checking system again. I was going to check and bleed the system again tonight or tomorrow.
    I was having some issues with getting the emergency brake to work so I decided to swap the rears to bendix. After some research I’ll probably swap the fronts to bendix soon. Debating going with boling brothers 1 3/4 back plate shoes because I can use my current drums a little longer.
    I do think my pedal is bottoming out before my master cylinder is fully depressed (I did bench bleed it). I’m having a hard time sourcing a 32 pedal that will fit my setup. Majority of ones online appear straight pedal and mine has a slight bend in it.
    im wondering if i can thread on an extension between the pedal arm and the pedal to give me a little more travel before the brake pedal bottoms out on the floor. I think i only need about 1/2 to 1 inch max. Thoughts….?
  2. alchemy
    alchemy
    You still haven’t confirmed what kind of pedal you have in there. Original or aftermarket? We’re flying blind.
    You can bend a pedal most any direction you need. Original Fords are forged, and most aftermarket are mild steel cut from a sheet. It’s not hard to do with a little heat, a vise, and some large pliers.
  3. 3blapcam
    3blapcam
    You definitely need to know this... You need to be able to get 100% of the piston travel in the MC or there's always going to be a chance of trapped air... and that'll always leave you with a squishy pedal.
    You've got homework to do!
    3blap.
  4. Sdsurfer01
    Sdsurfer01
    I’ll take some photos after work and report back.
    plus I’ll disconnect pedal and master cylinder and push the rod by hand to see how far it goes. Mark it. Then compare to with pedal attached.
    3blapcam likes this.
  5. Sdsurfer01
    Sdsurfer01
    Hard to get good photos but hopefully below helps.
    so I jacked up the front and did the large adjustment screws on the bottom and got the wheels to just drag ever so slightly.
    Now when I do pedal it doesn’t bottom out on the floor. Hopefully it was just the adjustments I needed to do.
    tomorrow or this weekend I’ll measure how far the master cylinder push rod goes in without the pedal attached
    RICH B likes this.
  6. alchemy
    alchemy
    Looks like you have the lower pedal arm about as short as possible, placing the rod as close to the crossmember as you can, so I don’t think you can improve the pedal ratio without significant fabrication. Is it really only 4 to 1?
    As said above, I’d check that the master is receiving a full stroke. And if you want some almost bolt on improved brakes, get some Lincolns.
  7. Happydaze
    Happydaze
    While you have the tape measure out don't forget to measure the critical dimensions of the pedal.
    Possibly nothing, but the pedal looks very scratched and scuffed. Has it been hanging up on something.
    What's the operation of the brakes like now with the drums adjusted? I suspect higher, more re***uring, pedal but possibly no notable change in stopping power. I can't check it from here!
    Chris
  8. NoSurf
    NoSurf
    I had ****py brakes on my A coupe that i fought for awhile. Ended up being the pushrod needed to be adjusted about 1/4" longer.
    Tim and 3blapcam like this.
  9. 3blapcam
    3blapcam
    Well, they're OG Ford pedals, which is good! They look like they're stock '32s, except that brake pedal has a zig & a zag added to it, which is fine if it clears everything. I see the s****ing that Happydaze sees, and it's only a little concerning, but not extremely concerning. It looks like someone has welded on the extension down to the adjusting rod, which has me concerned about why was it messed with? The weld does not look concerning.
    Couple of things to note. You're not going to be able to push that MC piston with your hand, unless there's significant relief in the system. If you get it to move, you're never going to get full travel out of it. Easiest thing to do in my opinion is to identify that MC and grab a new one to measure for comparison. If you're lucky, once you've ID'ed it, see if you can find specs online for its intended travel. Next, IF that extension/pendulum (not sure what it's called) down to the rod has been modified, it HAS TO HAVE a 45 degree angle forward in it so that it will finish with a 45 degree angle when fully compressed. I hope that makes sense? I made that mistake with my first Model A hot rod when modifying pedals for hydraulic brakes. If you don't have enough sweep, you'll never get full travel out of the rod/piston. In the pic, it looks like it is straight down, which will not give it enough travel.
    I'll try and remember to crawl under mine tonight and take some pics for comparison sake.
    You're on your way! You're going to crack this code very soon!
    3blap.
    Deutscher likes this.
  10. Tim
    Tim
    from KCMO
    Another vote for bleeding the brakes. Even if the push rod was too short to get the brakes all the way applied the pedal feel wouldn’t be squishy or weird.
    Also those pedals look pretty standard so you may be measuring the ratio wrong. That being said 4/1 would just require more foot effort it wouldnt give you a bad foot feel.
    continentaljohn and 3blapcam like this.
  11. alchemy
    alchemy
    His brake pedal has the stock arm cut off the upward direction and welded onto the downward direction for the conversion to hydraulic. I’m guessing the guy who did it knew what he was doing. Very common and should work fine when everything is adjusted properly. And even better if he switches to Lincoln style front brakes.
    In my 32 sedan I have a very similar setup and use a 68 Mustang dual master from a drum/drum car.
  12. 3blapcam
    3blapcam
    I think your ****ysis is spot on regarding the removing and rewelding the arm! It does look solid and the only concern I have is the angle of the dangle on it!
    I crawled under my hoopty last night. I forgot how much I had modified my setup. It's not pretty and I wish it was 3/16 to 1/4" longer so that the rod pushes on the piston in a 100% linear direction. In a daily driver, I would expect this to cause just enough wear to create a sloppy MC piston prematurely. PXL_20251113_020922816[1].jpg PXL_20251113_020943356[1].jpg PXL_20251113_021109981[1].jpg PXL_20251113_021126569[1].jpg PXL_20251113_021141442[1].jpg PXL_20251113_021257849[1].jpg PXL_20251113_021922798[1].jpg
    Deutscher, continentaljohn and NoSurf like this.
  13. Sdsurfer01
    Sdsurfer01
    Sorry long week at work. I go some homework to do tomorrow.
    I agree, I don’t think I have the arm strength or leverage to push the push rod in by hand.
    Tomorrow I’ll:
    1) research on the master cylinder. It was a Dorman M36367
    2) check the angle on the rod coming off the lower side of the pedal
    3) bleed the brakes again.
    The s****ing on the brake pedal is from the metal over the wood floor. I may just need to file a larger opening an put a rubber garmet around it
  14. Sdsurfer01
    Sdsurfer01
    Not home but I was able to find a shot of the angle in a photo I took.
    does appear to be more or less straight down but I’ll confirm tomorrow
    if straight down I guess I could engineer something to move the pushrod connector behind the pedal arm to be closer to 45 degrees?
  15. Happydaze
    Happydaze
    The new pic clearly shows that the start point is too far towards the rear which will result in something of an extreme of diminishing travel (because it is in an arc the travel cannot be strictly linear). I'm not so sure about the 45 degree thing, but generally agree with the sentiment. You need about 1.25" of travel (to get full stroke on the master) p***ing through the mid point, and roughly equidistant. If that works out at 2 x 45 degrees then so be it!
    Chris
    Deutscher and 3blapcam like this.
  16. 3blapcam
    3blapcam
    Sdsurfer Doooood... yeah, it's running out of travel too quickly pointing straight down. Cut it 90-95% through at the base from behind, bend it forward until a bunch and fill with weld. You'll have to bleed it afterwards because there's still air in there and then booooooom! You'll have brakes!
    I look forward to hearing about your happiness after this is done!
    3blap.
  17. clem
    clem
    Clicking “full image”
    when posting photos of cool cars is always appreciated …..:)
    beautiful roadster that you have there !
  18. alchemy
    alchemy
    I wouldn’t cut and weld the arm. I’d just clamp it in the vise and hold the torch to it. Bend the arm.
    Might be a good time to check the wear on the pedal bushings as well.
  19. Sdsurfer01
    Sdsurfer01
    I may try bending with heat. I am horrible at welding :(
    I also saw someone selling this:
    https://www.jalopyjournal.com/forum/threads/1932-ford-pedal-***embly.1327163/
    I may get that one and see what I can do with it. I think earlyv8garage sells an adapter so I don’t have to cut and weld under.
    Or I know a hot rod shop in Houston that does a lot of 32s. They maybe able to cut and weld the one for sale
  20. 3blapcam
    3blapcam
    Yeah, starting fresh wouldn't be a bad idea. As you can see on those pedals, that vertical brake lever is pretty long. I used an extra transmission/cross shaft jammer that the throw out bearing attaches to, to cut down and extend (by about an inch, maybe an inch.25) the pedal pivots. Then I built an attachment arm at about a 1:1 ratio with that arm kicking up, for my brake lever. I bolted the uppers together, and attached the rod to the lower. I think that shaft is 1.00" diameter, so I think I found an oilite bushing for my new pivot. added a bolt on the end so it stays in place. So far, it's working. I did do all this work with the body off the frame, which obviously makes life easier when doing this work.
    If you're going to heat & bend, you're going to need an Oxy Acetylene setup. The blue/yellow cans at Home Depot aren't going to get hot enough. Sorry, from behind this computer, it's hard to tell your skill set, so excuse any ***umptions, please.
    The Early V8 Garage definitely is a solid source. I think they have 100% retro-fit kits. Or, you might be able to get a partial kit.
    3blap.
  21. Sdsurfer01
    Sdsurfer01
    Long update from this weekend:
    1) I bleed the breaks and didn’t notice any air bubbles at the bleeder screw hoses but strange thing: I started with both reservoirs full of fluid, started with rear p***enger, 2 full pumps with cap off and bleeder open, I could hear some fluid spilling from the master cylinder. Checked front brakes reservoir and instead of being full it was less than half empty. Didn’t run dry but thought it strange, either 1) it pushed that much fluid out of the reservoir? Or 2) was some air bubbles in the front line that came out the master cylinder and fluid replaced it? Fill them both up and bleed all 4 wheels, no major fluid drops on other wheels and no bubbles.
    2) I am getting a firmer pedal about an inch before I used to, which is better.
    3) I measured pedal push throw disconnected and it was a little over an inch of travel (see photos). I marked that distance on the pushrod and took a video all connected again and pedal was firm and stops about 3/4 of an inch into master cylinder so appears I’m reaching resistance before pedal reaches max throw. I should have checked with bleed screw open to see how far I could push the rod into master cylinder by foot or hand before it bottomed out. But next time I bleed I can check that.
    4) ordered the original pedal set and will look into engineering something to use.
    5) in the meantime, I’ll drive around the neighborhood and see if beans are better. Got a few rainy days ahead than vacation so maybe about a week or more till I report back on how it does.
    Deutscher and NoSurf like this.
  22. AULIZ
    AULIZ
    1939-> ford brakes are good
    1937-> lincoln brakes are good
    Both are hot rod brakes. new disc brakes are for "bolt on cataloque builder street rodders".
    If brakeshoes are right installed, drums are "nearly" round -> I say OK condition, cylinders are not leak,
    brake hoses are not engorged inside..... brakes are good. old hoses make smooth pedal feeling.
    You have OK pedal ratio. I have had many MEC style under K-member bracket like You have, no problem.
    You need to overhaul Your hot rod. Its one part of this lifestyle.
    To change new disc brakes is not solution. Its hot rod, keep it like hot rod.
    12" disc brakes are enough for much more heavier car than these under 1000kg fords.
    AH
  23. 3blapcam
    3blapcam
    It seems like you're heading in the right direction! I think air traveled up to the MC from the fronts. Firmer pedal higher than it was means some air moved. But, you gotta get it all out or it'll cause problems down the road and the last thing you want to do is wreck that pretty roadster!
    I think getting the other pedals and starting from scratch is a good plan also. Then you'll know how it's designed and should have better confidence. You can also swap the tab from the top to the bottom and change the angle, or create your own tab from steel plate and start messing with the ratios like you were talking about in the beginning.
    I probably said it before, but I will mention again... that without bottoming out the piston in the MC while bleeding, you're always at risk of air still being trapped inside. I can't explain why that can occur, but I can say I have had that problem. I wasn't successful in fixing the problem until I had full travel of the MC piston. Sorry to beat that dead horse, but only say it again in case it was missed the first time.
    Keep us posted!
    3blap.
  24. alchemy
    alchemy
    He doesn’t weld, guys. How’s he going to add a new arm to a fresh set of pedals?
    The pics with the gloves show the start and stop of the master’s stroke? If so, I don’t think there is any improvement possible with a new pedal. Looks good as is.
    I believe the performance can be improved by bleeding properly, and adjusting the shoes properly (were they ever arced to the drum?).
    Happydaze likes this.
  25. 3blapcam
    3blapcam
    He lives in Houston. Did Houston run out of welders? Any qualified welder would weld that for beer money.
    Send it to me, I'll weld it for you, and send it back. MIG, TIG... you pick.
    3blap.
  26. If you're getting a new set of 32 pedals, then make sure you have somebody who really knows how to weld - your life is depending on it! If you get the right length arm in the right position, you should be fine.
  27. Sdsurfer01
    Sdsurfer01
    The plot thickens…
    Was going to take it for a spin and noticed front driver side had about a tables**** of brake fluid on rim / ground… plot coming together, cylinders probably leaking and causing air to enter the front brakes, thus sponge and fluid drop in reservoir when bleeding them.
    Going to take off drum and hone cylinder and replace spring/seals with a rebuild kit I had bought a little bit back.
    then I’ll bleed brakes again and try to measure master cylinder push rod distance by hand with bleeder open to see how far till it bottoms out.
    Limited time but I’ll report back what I can before vacation
  28. Sdsurfer01
    Sdsurfer01
    Ok, honed the cylinder some, seems nice and clean no pitting, put in new spring and plungers. Bleed brakes and strangle when I press the brake with the drum off the front shoe is the only one moving. That doesn’t seem right? The front and back should be moving? I got to bleed some more but taking a break for the night and going to see if anything leaks out tomorrow.
    Also these the wheel cylinders I got cuz couldn’t find anywhere else
    https://www.speedwaymotors.com/1939...XNVShbePktTwsWFALJyMjy79bgawH1QEaAryUEALw_wcB
    Anyone know somewhere else that sells them? I may try replacing driver side but can’t seem to find them anywhere else
  29. Sdsurfer01
    Sdsurfer01
    Follow up question… I see the speedway ones I got are 1 1/4x1 but I’ve seen a few 1 3/8x1. I have a 1 inch master cylinder. Would changing to 1 3/8 on the fronts help or hurt my pedal setup?
  30. alchemy
    alchemy
    The small size difference shouldn’t matter as long as they match on both sides, but the best solution would be to just put new cups in the old cylinders after honing. Some modern produced cylinders have been known to be faulty, in that the port from the hose is drilled into the main bore too far to one end. If the cup is slightly too far to the center, it will let fluid past the cup and leak out the boot.
    Only way to use the bad cylinder is to make sure the shoes are already adjusted out via the cams, so they won’t push the cup too far inward. Before you put any fluid in there.
