Projects Bought a 51 Ford on Purpose
Discussion in 'The Hokey Ass Message Board' started by guthriesmith, Aug 11, 2025.
  1. guthriesmith
    guthriesmith
    In the middle of a carburetor rebuild, but clogged main jets seem like a possible issue? :rolleyes:
  2. bchctybob
    bchctybob
    My bone stock ‘55 Ford 2 dr wagon had a similar problem. It would drive fine but occasionally act up under load or just shut off on the freeway. I knew it had rust debris that migrated into the carb, I had cleaned it out a few times. It turned out to be a piece of a shop towel floating around in the tank along with the filter sock from the pickup. I just bit the bullet and went through the whole fuel system. Bringing these old cars back from retirement is full of adventures.
    Squablow, Okie Pete, porkshop and 4 others like this.
  3. guthriesmith
    guthriesmith
    Well, I’ll see if I made things any better. Carburetor at least looks cleaner and I painted the base black. :D Also put a new distributor cap and rotor on it since they didn’t look great. It still needs plug wires, but I didn’t do that yet. Oh, and trashed the Champion plugs and replaced with some Autolites. Little by little…
  4. guthriesmith
    guthriesmith
    Oh yea…. Back in business! Runs better than it ever has!
  5. e1956v
    e1956v
    Alliance Vendor
    I’m a GM guy all the way but always use Autolite plugs not AC. I just have had better luck with them. Glad she’s running happy.
  6. lostn51
    lostn51
    from Tennessee
    Now this is a sight that I like to see!!:D I’m glad you got the bugs worked out and back on the road again.
  7. guthriesmith
    guthriesmith
    Me too! Even drove it 30 miles to work this morning. :cool:
  8. lostn51
    lostn51
    from Tennessee
    Sweet, I really love that car!!:cool:
    winduptoy, porkshop and guthriesmith like this.
  9. guthriesmith
    guthriesmith
    Yea, I have never been a fan of Champion plugs in anything other than maybe a lawnmover. Hey, since it was cold this morning, my speedometer cable started bouncing some. Last time I went to the parts store to get some graphite cable lubricant, they don't keep it anymore. :eek: Should I order some somewhere or is there something else that works well?
    Okie Pete, bchctybob and porkshop like this.
  10. bchrismer
    bchrismer
    Jeff, don't forget what this wise guy said about the power valves in the Holley '94 carbs.
    Yes, he was correct. Buy those from https://www.vintagespeed.com/
  11. guthriesmith
    guthriesmith
    You know, I looked real hard at the two different power valves that came in the Standard brand rebuild kit, and it appeared that one of them had a real square corner. I even screwed it in without a gasket to prove to myself that it would actually seal. So, I'm fairly confident that it was correct for a 94...but, now you have me questioning myself... :oops:
  12. MMM1693
    MMM1693
    Jeff, glad its running like a flathead should.
    Okie Pete, porkshop and guthriesmith like this.
  13. tubman
    tubman
    Be careful. If there were two "power valves" in a rebuild kit, one of them is a "spark valve" that serves a completely different function on a later model Holley (2100, 2110). Why Holley made them look like a power valve and have the same thread is beyond me; probably a move to reduce costs. Trying to use a spark valve as a power valve just doesn't work, even though it will install nicely.
  14. guthriesmith
    guthriesmith
    Good point. I just need to order what I know is right. And, I'm 90% sure I put the spark valve in it... :oops:
    Edit: Ordered a couple correct power valves and will try to put the spare one somewhere where I may remember I have it...
  15. e1956v
    e1956v
    Alliance Vendor
    Jeff,
    Stay away from graphite and just use white lithium grease, like motor ***embly grease. Graphite is a real no-no and is a speedometer repair guys best friend. It works its way up the cable and gets in the speedometer head and causes havoc with the magnet and speed-cup. It's good on door locks and such but stay away from it on speedo cables.
    My dad used to say that sh..ts made to sell not to use;). Even Vaseline will work in a pinch.
  16. guthriesmith
    guthriesmith
    Thanks Rusty! I knew I was asking the right guy! :)
  17. lostn51
    lostn51
    from Tennessee
    Yeah I used lithium grease on mine the other week. It was jumping around before I used it and smooth as ****er afterwards
  18. I've used the power valves in the Standard carb kit in a number of '94 I've rebuilt lately, including the duals on my '50. No problems with them sealing. All working very well.
    I'm glad you're enjoying your '51. They're made to be driven ... carry on. :)
  19. guthriesmith
    guthriesmith
    That’s good to know!
    Okie Pete, porkshop and bchctybob like this.
  20. guthriesmith
    guthriesmith
    Drove it to work again today and hit a little over 1900 miles since I started driving it. I should probably park it until I get the correct power valve, but I needed a way to get to work today. :D Stopped at a gas station on the way home and had a good conversation with a guy that has had his 56 Chevy since 1963. Amazing how these old cars are such a great conversation starter. :)
    And, every time I look at it, I am reminded how I need to lower the front more.
  21. lostn51
    lostn51
    from Tennessee
    Looking good to me!!:D:D
  22. guthriesmith
    guthriesmith
    So…I have a thought that I figured I would run by you guys that know these carburetors better than me. I’m trying to convince myself that the only way that the bowl can empty itself after sitting a while is if it leaks past the power valve? Otherwise, not sure why the bowl would be empty after sitting a day or so. Does that make any logical sense? :rolleyes: By the way, still waiting on the one from Vintage Speed.
    winduptoy, Algoma56, porkshop and 2 others like this.
  23. lostn51
    lostn51
    from Tennessee
    I’m thinking that it’s today’s gas with the alcohol added to it. Me thinks it evaporates faster and therefore not leaving much in the bowl or the pump. Since I put the electric fuel pump in all I do is give it an 2 to 3 second burst and it fires right up like it’s fuel injected.
  24. guthriesmith
    guthriesmith
    Well, I can still buy supposed non-ethanol gas here in Oklahoma so try to always run that. I think I may have just figured out it can also leak past a worn throttle shaft? I know mine has some wear.
  25. Okie Pete
    Okie Pete
    Looks great Jeff
  26. guthriesmith
    guthriesmith
    So...my daughter was on the way to our house to drop off my grandson yesterday morning about 5 am when she had a guy pull out in front of her. Thankfully she and my grandson are fine, but her car is totaled (again considering she bought it as a salvage car that we rebuilt). So, what that really means is that the shoebox really is my daily now other than the Harley. So, thankful to have it right now while she is borrowing a vehicle until we figure out what insurance is going to do. It was the other guys fault, so hopefully it won't be a big fight to get her enough to cover the cost of the car.
  27. Tim
    Tim
    from KCMO
    Glad they are safe. I keep seeing more and more arguments for dash cams like this.
    I did for a second think you were going to have her drive the shoebox haha.
    on the gas evaporating, the corn does make it go faster but even in an edelbrock which because of
    Design is more prone to having that happen, takes at least three days to get close to dry so I’d really be surprised a Holley flashed in two.
    winduptoy, Thor1, lostn51 and 3 others like this.
  28. guthriesmith
    guthriesmith
    You know, that is one thing I haven't taught my daughter to do yet...drive a standard, or even more confusing, a three on the tree. Both my boys know how, but my daughter also didn't start driving until she was older. So, seems I need to teach her sometime. This car is pretty easy to learn in so maybe would be a good one for lessons.
  29. guthriesmith
    guthriesmith
    Working offsite today in a different town and also heading in later than normal so got to drive toward a beautiful sunrise. :)
    Deutscher, Jrs50, 63Biscuit and 20 others like this.
  30. 210superair
    210superair
    from Michigan
    Glad your family is alright.
    bchctybob and guthriesmith like this.
