1961 Ford Econoline window van
Discussion in 'The Antiquated' started by RMR&C, Jan 16, 2024.
  1. How will you fill that gap on the wheel opening?
  2. RMR&C
    RMR&C
    from NW Montana
    Keep watching...
    b-bop likes this.
  3. RMR&C
    RMR&C
    from NW Montana
    First outer piece fitted
  4. RMR&C
    RMR&C
    from NW Montana
  5. Well done!
    porkshop and RMR&C like this.
  6. RMR&C
    RMR&C
    from NW Montana
    I finished the body work on the wheel arch. Also straightened out the grille and the chin panel below it. Rust repair is finished, not sure where to stop on the rest of the body.
    Okie Pete, porkshop, b-bop and 2 others like this.
  7. Nylint used to make vans like it
    down-the-road likes this.
  8. RMR&C
    RMR&C
    from NW Montana
    Not much happening on this lately , but I did manage to do some work on the engine cover.
    Insulation on the inside and bed liner on the outside.
  9. iwanaflattie
    iwanaflattie
    That is some nice work!!
    Are you keeping the faded green paint?
  10. RMR&C
    RMR&C
    from NW Montana
    Yes, for now. Wish I could match/blend it, I'd fix some of the bad bodywork
    Okie Pete and Deutscher like this.
  11. iwanaflattie
    iwanaflattie
    I think you can do it..
    Im gonna have to donit in my bus..I plan to bring the green OD under the house paint.
    Okie Pete likes this.
  12. RMR&C
    RMR&C
    from NW Montana
    At some point in the past, someone butchered the ashtray hole.... for a radio maybe? Luckily the metal was still there, just folded in.
    Deutscher and Okie Pete like this.
  13. RMR&C
    RMR&C
    from NW Montana
    Welded back up.
    Need to find an ashtray. Supposedly there are a couple of these vans in a junkyard an hour away. I need a few other things too, maybe check it out when it warms up a bit
    chevy57dude, Deutscher, Lepus and 5 others like this.
