Hot Rods The (mis) Adventures of a Compulsive Tinkerer
Discussion in 'The Hokey Ass Message Board' started by bchctybob, Apr 13, 2024.
  1. Budget36
    Budget36
    I like either, but sure like the originals better. I just like the “swoop” in the back.
    But I’ve no doubt you’ll sort it out as you want it to look.
  2. bchctybob
    bchctybob
    Yeah, just looking at options. My first choice is full fenders. I’m hoping to find some decent front fenders and running boards. But I have always wanted to use those bobbed fenders….
  3. Rice n Beans Garage
    Rice n Beans Garage
  4. bchctybob
    bchctybob
    This whole project started because of a Weesner print that I saw and bought. I like everything about this truck, even the candy tangerine paint and white and orange interior. That’s why I lean towards full fenders.
    Unfortunately, my wife doesn’t like orange cars so it will be dark gray hot rod primer at first. It will probably end up blue or light metallic green if I get that far.
    (Credit: amazing artwork by Keith Weesner)
    wicarnut, charleyw, Chucky and 13 others like this.
  5. bchctybob
    bchctybob
    I cut out my previous Buick mounts today clearing the way to install the new boxing plates. I used my new cordless grinder from HF with a Dewalt cutoff wheel. It kicks ****. I’m not a big HF guy but this grinder is great.
    The PO had removed the rivets and bolted the front crossmember in with grade 8 bolts. I’ve modified ‘33-‘34 front crossmembers to drop the front an extra inch before and I was thinking about doing that, but I was also thinking about maybe installing a Model A crossmember. I have a really nice one that I can use. I’ve done it to ‘32 frames but I’ve never done it to a ‘33-34. It looks like it would give me a little more drop than cutting up the ‘33 crossmember.
    4CE195F8-1D62-483A-B87C-ABF0665CF8A0.jpeg 25787063-E5D9-415C-B94F-EB0B1D7BC259.jpeg
    Almost a 2” drop at the spring mounting point. It might affect the lower radiator hose but from my recent fit check, the radiator needs work anyway.
    wicarnut, Outback, Thor1 and 4 others like this.
  6. bchctybob
    bchctybob
    While I let my poor old brain mull over the front suspension, I decided to get out the starter for the new Stude engine and see if it fits. The Wilcap adapter uses a Mopar starter, part numbers are listed in the instructions. I bought a starter on sale a long time ago so I got it out and bolted it up to the adapter plate. I’m not real happy. The solenoid sticks straight out the side. There’s only three alternate positions and they all stick the solenoid out where the steering box and stuff are.
    I can rotate the whole starter up and drill new mounting holes in the adapter but one hole will be very close to the edge. I will probably do that.
    I do have another starter that might fit better. It came with the other Pontiac engine. I’ll pull it off tomorrow and see if it fits.
  7. Budget36
    Budget36
    I love me some Baurer.
    Yes, I’m a HF guy!
    enloe and bchctybob like this.
  8. Budget36
    Budget36
    Would a mini indexable starter work?
  9. bchctybob
    bchctybob
    This one is indexable but only has three positions. ?? It doesn’t change very much.
    It never fails, you buy something you know you’re going to need way ahead of time and either it doesn’t fit or it doesn’t work when you finally try to use it.
    It doesn’t matter, I can swap with the other Pontiac or go upstairs and get out the one that came with the Hemi to TH400 adapter that I bought long ago. I’m sure one of them will fit.
    Thor1, enloe and Budget36 like this.
  10. bchctybob
    bchctybob
    I got out the boxing plates just to see how well they fit. They look really good.
    (Yeah, I know they go on the inside)
    This is the radiator problem that I mentioned earlier…..
  11. Budget36
    Budget36
    What side is the top hose on?
    bchctybob and porkshop like this.
  12. bchctybob
    bchctybob
    I’ll have to go look. I’m not really sure that that’s the correct radiator but it was the only old one there when I bought the truck. The seller didn’t seem to know either.
    I bought this little truck as a basket case, it was spread all over a storage space along with construction equipment. My wife and I partially ***embled it with the help of the seller and his son so we could put it on the trailer for the ride home. We knew ahead of time so I brought nuts and bolts and tools.
    wicarnut, Outback, Thor1 and 2 others like this.
  13. Jacksmith
    Jacksmith
    from Aridzona
    I was voting for the Bobbed fenders... 'til I saw the Weesner truck... now I'm with you on the full fenders.
    Outback, enloe, 427 sleeper and 3 others like this.
  14. jaracer
    jaracer
    The Buick is a long engine. It also has the starter on the left side so steering gear clearance may be a problem. I used a Steer Clear unit on my Model A to solve the starter problem.
    enloe and porkshop like this.
  15. bchctybob
    bchctybob
    Yeah, I noticed that things were a little tight with the starter on the same side as the steering but I will probably use a Vega or 525 box and cross steering (I have both lying around) , so it should just be a shaft running by the starter.
    I’m leaning towards keeping the Buick in there but since the Chrysler hemi has the front mounts in a similar position and might be able to share a single motor mount crossmember, I’m gathering up the parts to install the Hemi for a quick fit check.
    Those Steer Clear units are pretty slick, huh?
    wicarnut, Outback, Jacksmith and 3 others like this.
  16. bchctybob
    bchctybob
    I got to put a little time in on the 33. I trimmed and generally cleaned up the Model A crossmember. It looks much better.
    I cut out the remains of the old boxing plates.
    D1556DF6-2014-4073-B22F-4E317C194AC2.jpeg A3C3749F-C20D-439C-A9D7-8D5C4FE1C3D7.jpeg
    I moved the jack stands and positioned the truck at the approximate ride height and rake and made sure everything was level side to side.
    I straightened the p***enger side frame horn. Then I cut and welded in a temporary spreader bar to hold the frame position.
    wicarnut, Outback, porkshop and 8 others like this.
  17. bchctybob
    bchctybob
    I carefully removed the old front crossmember. Nothing sprung or moved significantly, the bolts came out without hammering and the crossmember slid back fairly easily for removal. I went to work with a wire wheel and flapper wheel to clean the area for welding. I’ll probably do a little more tomorrow.
    I heated and straightened the horizontal rivet flanges at each end of the new crossmember to give myself some more weld area and something to clamp on. I marked and trimmed them a little and the crossmember fit nicely.
    Before I started this series of modifications I printed out the dimensional diagram from Wescott so I have accurate dimensions to refer to. Hopefully tomorrow will be a final fitting and alignment, I need to build in some caster angle. Then I can start welding it in.
    C38F0547-AB43-4F72-A310-5E05E8151E61.jpeg 34BFF81B-B7D4-472B-BABB-1BFC5DF26F6B.jpeg
    My front inner tubes arrived so the front tires are aired up and ready. I ordered a 6” drop transmission crossmember that I will trim the mount from and use for a crossmember for motor mounts. I think I’ve identified a position that will work for both the Hemi and the Nailhead. We’ll see I guess.
    wicarnut, Outback, porkshop and 14 others like this.
  18. Jacksmith
    Jacksmith
    from Aridzona
    porkshop and bchctybob like this.
  19. bchctybob
    bchctybob
    Yeah, I was hoping that there was no stress on the front crossmember that might indicate that the frame was twisted or racked. All good. Whew!
    wicarnut, porkshop, Thor1 and 2 others like this.
  20. bchctybob
    bchctybob
    I agree, Ford did a nice job with the fenders on these trucks.
  21. bchctybob
    bchctybob
    I’m in the process of positioning the crossmember and I decided to do a little experiment. I have the ch***is at the height in the back as dictated by the tire to stock fender relationship.
    Measuring from the forward most bolt hole in the front frame horn to the floor, I am kinda stuck with 11 1/2” due to my jack stand height.
    If memory serves me, my ‘33 coupe was 10” and I was striving for 9” when I was messing with the front end as a young lad. I never got there IIRC. And it became a moot point because I did the Corvair IRS. Hey, it was the 60s and I was an avid reader of HRM. Lol
    So I decided to see just how much the caster angle changed from the 11 1/2” height to the 9” height. (The photo is random)
    With the crossmember set at 5.9 degrees at the 11 1/2” height, and using a Craftsman digital level, I lowered it in increments as follows:
    11” = 5.7 degrees
    10”= 5.4 degrees
    9”= 5.0 degrees
    Not high science but interesting data. A 2 1/2” drop in front caused about a one degree change in caster angle.
    For my purposes, installed as mocked up, I will never raise or lower the front enough to leave the 5-7 degree standard range. Using my hairpins I should have enough adjustment to optimize the caster at my chosen height.
    Or have I had too much coffee today…..
    BigJoeArt, wicarnut, Outback and 12 others like this.
  22. bchctybob
    bchctybob
    I got enough weld on the crossmember to keep it in place. I made little plates to connect the front and back flanges of the crossmember to the frame rail. I’ll weld them solidly and then put the boxing plates over the area and weld them in. Now that it’s welded in solidly I can raise the front to make it easier for an old guy to finish welding it up. I’m hoping to trim the boxing plate to fill the wedge gap across the top. We’ll see….
    9CEB7C65-EEBB-420D-9E3A-C6A28EAADD3D.jpeg 2385E8D3-96E1-4F63-82B9-15A09AAD3873.jpeg
    I needed a break, so I welded up the headers for the Buick. They’ve been taking up space on my welding table and I needed to check my TIG skills before tackling the final welding on the frame. I was mainly wondering about my vision - it’s fine.
    I wanted to make headers down through the ch***is so I could run a full hood eventually but lakes headers with mufflers underneath will be good for now.
    BigJoeArt, wicarnut, Outback and 14 others like this.
  23. bchctybob
    bchctybob
    Had appointments and stuff that cut into my progress but I’m fitting the boxing plates. With the ‘33 double frame, it’s a little more trouble than a Model A or ‘32. I got my crossmember yesterday and it looks like it’s going to work out well. I have Hurst mounts for the Chrysler and they move the mounting points very close to the Buick mounting points. That will make the placement of the crossmember easier.
    I ordered a Trans-Dapt 6” drop transmission crossmember because it only has one bracket to trim off and it was cheap. Unfortunately, they welded it all around, both sides, so it will be harder to trim off than I thought. Oh well.
    84E8FD28-BDFE-44B9-B189-D25D910D0E71.jpeg A26D71EF-301E-46E9-A2D5-0A349C4F247A.jpeg 6D4A022A-AFFB-43B3-BB13-FE16239F0A0D.jpeg
    wicarnut, Outback, Thor1 and 9 others like this.
  24. Jacksmith
    Jacksmith
    from Aridzona
    Is that a Harley belly pan lurking under the Hemi?
    porkshop likes this.
  25. bchctybob
    bchctybob
    It sure is. A skid plate from one of the old rigid frame basket cases I built. One of the few items left from my old Harley days. I sold my last Harley, a ‘53 Pan/shovel sometime in ‘97-‘98. Riding in LA traffic was not fun anymore.
    wicarnut, Outback, porkshop and 4 others like this.
  26. bchctybob
    bchctybob
    With the holiday and family in town shop time was limited but yesterday I made an executive decision to install the Chrysler and build front motor mounts for it based on the old Hurst mounts. The Buick mounts will be built to sit on the same pads as the Chrysler. I removed the transmission mount from the tube crossmember so it’s just a blank. My shop is sorta crowded so I rearranged everything so I can lift the Hemi and install the transmission adapter and trans.
    I need to weld nuts on the inside of the boxing plates for the new crossmember and I need to get the engine where I want it so I know where the crossmember goes. I’ll finish fitting the other boxing plate and tack them in place. It’s like dominos, one thing after another, and I find that it’s easy to get ahead of myself.
    That thing’s a monster, but it looks like it will fit fine. (Not sure about the 3” blower drive though) Lol
    wicarnut, Outback, choptop4 and 11 others like this.
  27. bchctybob
    bchctybob
    I cut and fit the Trans-Dapt crossmember to fit where my measurements told me it needed to go. But there’s a little problem….
    Yeah, if I use a Vega box, with the crossmember in the right place the steering box is 1” farther back than it needs to be to have the drag link and tie rod parallel. This is all by my dubious calculations, so it could be better or it could be worse. I have a pitman arm coming so I can figure more accurately. Nothing like having the parts in your hand so you know for sure what you can do with them.
    I could always go the full old school Hurst method. I have that option…..
    But I like to use a bolt in crossmember when I can because it leaves you with a clean slate if you decide to swap engines in the future. (In this case the Pontiac would get a new crossmember farther back and this one would be removed) And no unused protruding brackets to deal with.
    I guess I could also contact the gentleman who rebuilds early Ford steering boxes and see what he recommends for a standard drag link steering box for a ‘33-‘34 ch***is. I’m not married to the Vega steering, it’s just usually easier and works good.
    Fordors, wicarnut, Outback and 5 others like this.
  28. bchctybob
    bchctybob
    I’m waiting for some stuff to be delivered so I decided to not be lazy and mock stuff up just to be sure. I got the adapter and my TH400 case bolted to the back of the Hemi.
    9DD2CD6D-36F6-4A57-936D-903153455352.jpeg 06FFF87D-8D51-4B7D-BA14-8C840D74C471.jpeg
    Then I dropped it in for a sanity check. Turns out my measurements were right on the money. Right in the middle of the slot, only the height was in question.
    With that behemoth sitting in there, it’s hard to think of using anything but the Hemi…..
    I’ll have to dig up a couple extra leafs to add to the front spring. Lol
    Fordors, BigJoeArt, ffr1222k and 16 others like this.
  29. Budget36
    Budget36
    Damned Bob, I was out back pulling a fence down while you were in the shop. My feet and hands are still numb.
    Tell the truth now, your area is heated?
    If not, I’m going into hiding until April;)
    Outback and porkshop like this.
  30. Jacksmith
    Jacksmith
    from Aridzona
    That is a handsome mill!
    Outback, porkshop and Budget36 like this.
