Hot Rods 303 Oldsmobile not firing
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Nov 18, 2025.
  1. drumyn29
    drumyn29
    with firing order 18736542, it doesn't start.
    with 18436572 it at least kicks and blows fire out the carbs.
    #1 plus off, finger over hole, found mark on the dizzy.
    tested the mallory, I see a spark when I pull a wire
    dizzy runs counter clockwise.
    warbird1 likes this.
  2. skooch
    skooch
    18736542 is correct firing order, there is some misinformation online.
    Mark on dizzy? You mean the rotor is pointed to spark plug #1?
    Sharpone likes this.
  3. drumyn29
    drumyn29
    It just doesn't want to fire.
  4. skooch
    skooch
    One tooth off at the distributor can cause that.
  5. tubman
    tubman
    @skooch has the correct firing order.
    Take it apart and start over from scratch.
  6. jaracer
    jaracer
    18736542 is the correct firing order. Do you have a timing pointer on the crank pulley? If you do, bring #1 up on compression and align the timing pointer. The rotor should be pointing to #1 terminal in the distributor cap. Now turn the distributor clockwise until the points close. Then move it counterclockwise until the points just open and lock it down. If the rotor is still pointing at the #1 terminal, your timing will be close enough to start the engine.
    skooch and Sharpone like this.
  7. jaracer
    jaracer
    You can use a test light to determine when the points just open. With the ignition on, connect the test light to the distributor side of the coil and to ground. When the points are closed, the light will be out. The instant the points open, the light will come on. That's where you want to set the distributor.
    skooch likes this.
  8. drumyn29
    drumyn29
    I'll give it a try tomorrow, thanks.
  9. BJR
    BJR
    If all the above suggestions don’t work, these engines were famous for the timing chains stretching and jumping a tooth or two.
  10. bschwoeble
    bschwoeble
    What's a dizzy. I'm 80, and not up on all this new lingo.
    SS327, jimmy six, warbird1 and 3 others like this.
  11. RodStRace
    RodStRace
    bschwoeble, 2OLD2FAST and Sharpone like this.
  12. Paul
    Paul
    Editor
    looks like it's been sitting a while
    does the valve train look like it's behaving itself when cranking with the covers off?
    does it have reasonable cranking compression?
    is there evidence of fuel delivery?
  13. vtwhead
    vtwhead
    I suspect to be absolutely certain of TDC marked on the pulley you could do the piston stop method and mark the pulley at CW and CCW stops then divide in half to see if the pointer lines up with the new center mark. I have seen them be off fwiw.
    bchctybob and Sharpone like this.
  14. drumyn29
    drumyn29
    Or I could just jam a screwdriver in the spark hole slowly turning it over and see exactly where TDC is and compare it to the pointer. I did mark it when I ***embled it but we shall see.
  15. Paul
    Paul
    Editor
    tdc on compression stroke right?
    not just tdc checked with screw driver in plug hole which of course could be 180° off timing and still line up with tdc mark.
    Sharpone and Moriarity like this.
  16. drumyn29
    drumyn29
    yep, the kaboom part of the stroke, thank you.
    Paul likes this.
  17. drumyn29
    drumyn29
    anothercarguy, AHotRod and warbird1 like this.
  18. drumyn29
    drumyn29
  19. skooch
    skooch
    Congrats.
  20. jimmy six
    jimmy six
    I believe it originated in a large country claiming to be a Continent where they should have kept it to themselves……
    SS327, warbird1 and bschwoeble like this.
  21. drumyn29
    drumyn29
    I really need to stop hanging out with my Kiwi buddy!
    bschwoeble likes this.
  22. AHotRod
    AHotRod
