Technical mystery overdrive - can you help me identify it
Discussion in 'The Hokey Ass Message Board' started by cw, Nov 19, 2025.
  1. cw
    cw
    from Midland
    I received an overdrive in a trade.
    It was removed from a 1931 Ford Model A that was restored/modified in the late 80s.
    I would appreciate help identifying the make and model so that I can dig up a manual.
    The only markings I have found are "DTS 115314 2L".
    Thanks... Chris
    upload_2025-11-19_17-16-42.png upload_2025-11-19_17-18-6.png upload_2025-11-19_17-19-0.png
    41 GMC K-18 and chryslerfan55 like this.
  2. BJR
    BJR
    Lay**** de Normanville?
  3. squirrel
    looks like it. They were used in some European cars in the 60s-80s, before Gear Vendors bought them.
    might need better pictures of it sitting right side up, showing the whole thing. With the camera in "landscape" mode instead of "portrait"
    41 GMC K-18, BJR, Outback and 2 others like this.
  4. cw
    cw
    from Midland
    thank you
    BJR and chryslerfan55 like this.
  5. Pav8427
    Pav8427
    Was it AMC that used that as well?
    seb fontana, anthony myrick and BJR like this.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes. I knew someone who had a Pacer with a three speed with this style overdrive.
    Outback likes this.
  7. squirrel
    The Pacer version was behind a Ford 3 speed top loader transmission, and had a normal open driveline at the back end.
    This mystery OD appears to be adapted to a closed driveline, it would help to see what's at the other end of it.
    41 GMC K-18 and BJR like this.
  8. BJR
    BJR
    AMC and some English cars used it also.
  9. Here’s the AMC/ford
    firstinsteele and 41 GMC K-18 like this.
  10. Beanscoot
    Beanscoot
    Also, turn off the "camoflage mode" when taking the next pictures.
    squirrel, Budget36 and 34 GAZ like this.
  11. Do they have that mode on smart-phones too :confused: ? Looks more like compost mode from here :oops::rolleyes:.
    partsdawg, jet996 and Budget36 like this.
  12. 51 mercules
    51 mercules
    Not sure? volvo.2.jpg bwover.jpg bw1.jpg Volvo and Borg Warner were pretty common swaps in the day.
  13. rusty_bits
    rusty_bits
    As stated above, looks like a Lay**** type J, I have one in my Model A and am very happy with it. My installation look like the first photo, in the 3 above.
    51 mercules likes this.
  14. Kinda looks like my Gear Vendors unit.
  15. Oneball
    Oneball
    I’m thinking Triumph. This plate here held on by two rivets will have the actual part number stamped on it. IMG_0131.jpeg
    34 GAZ, 51 mercules and porkshop like this.
  16. squirrel
    Triumph did use the Lay****.. OD also, I had one in a GT6.
  17. deucemac
    deucemac
    Yep. They did from 75-77, they used a Lay**** overdrive mounted on the rear of a Ford 3.03 full syncro 3 speed. I have one in my avatar roadster. I put a Jeep T150 top cover on it to get the old time appearance. It's behind a 354 Chrysler hemi and has performed flawlessly since installed in 2009! I mounted a lighted rocker switch under the left side of my dash. I have driven it all over the southwest without any problems. They were originally in AMC Pacers, Gremlins, and Hornets. They are pretty rare to find nowadays. Larry Ready from the LA Roadsters and did a trip around the perimeter of the USA without any problems. Great trans/overdrive combo. People will look at my car and ask about the transmission. The bewildered look on their face when I tell them that the transmission is out of a 76 AMC Pacer is priceless! It did take some time to find because they weren't widely ordered. BUT, if you can get your hands on one they are worth every penny spent. The Jeep top cover puts the shift lever within 1 inch of where original Ford shift lever came through! You should see the look on people's faces as I go 6 speeds forward for fun. After shift number 4, I get some weird looks!
