Technical 235 Chevy timing cover modification
Discussion in 'The Hokey Ass Message Board' started by 36roadster, Nov 20, 2025.
  1. I want to change the bottom bolts (which come in from inside the oil pan) to external bolts, but I keep reading articles which say to drill and tap the bearing cap to take a 5/16" bolt- but the hole is already 5/16" diameter- too big to tap a 5/16" thread into. The only way I can see is to drill and tap for a 3/8" bolt. Then I would drill a suitable clearance hole to open up the existing (tapped) holes in the re-enforcing block to clear a 3/8" bolt. Am I missing something?
    chryslerfan55 and Ken Smith like this.
  2. Budget36
    Budget36
    I remember dropping the pan on my 235 to tighten them. Put it back together, a day or two later I wondered why I didn't tack weld them to the plate if they ever needed tightening again. Mine was seeping oil from the bottom of the cover.
    Wouldn’t help with having to drop the pan to replace the cover gasket, etc. though.
  3. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You're not missing anything. That's exactly what I did on my engine.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    A 21/64” (1/64” over 5/16”) pilot hole is what’s required to tap for a 5/16” Helicoil.
    lumpy 63 and chryslerfan55 like this.
  5. Casual 6
    Casual 6
    from Great NW
    Yes. That's all you have to do. Tap for 3/8-16 & drill a clearance hole in the "re-enforcing block". Pretty standard modification for these engines.
  6. jimmy six
    jimmy six
    All mine are tapped for 3/8”. Best to use what some call a “header” bolt. Built in washer and a 3/8” head for ease of attaching.
