Technical 55-59 chevy truck shackle replacement
Discussion in 'The Hokey Ass Message Board' started by fastcar1953, Oct 27, 2025.
  1. fastcar1953
    fastcar1953
  2. squirrel
    I doubt it will do much. The rubber bushings on shackles on cars that have a smooth ride, are at least twice as big diameter as that.
  3. fastcar1953
    fastcar1953
    I thought about checking bushing size and bolts like I have on my 54 chevy car.
    I'm not impressed with truck shackles. The small carriage bolt is all that holds the links together ?
    Seems like a bad design.
    The shackles I posted are meant to replace the truck shackles.
  4. You’ll need an adapter. Hehe
  5. 325w
    325w
    Those old trucks took a beating. Never saw a bolt that had broken. Lots of worn out bushings
    Bob Lowry, SS327 and tb33anda3rd like this.
  6. squirrel
    no adapter needed, just remove the threaded bushings from the spring and hanger.
    Some of the shackles have the carriage bolt holding them together, others have big nuts on the ends of the pins. But what actually holds them together, is the taper at the end of the pin, and the hole in the plates.
    oh, you have to grease them all the time to keep them from wearing out, too.
    on my 59
  7. fastcar1953
    fastcar1953
    Mines a 1/2 ton without the big nuts. Just the carriage bolt.
  8. squirrel
    Mine's half ton also. They're sold with the carriage bolt for 55-56, and with nuts for 57-59, it seems.
    I've never seen them come apart when they weren't supposed to. They can be difficult to get the taper disengaged, with either style.
  9. fastcar1953
    fastcar1953
    One shot is the back shackle others are on front axle if the bolt breaks they would fall off. The ones I took off didn't seem to be holding much tension. Plus a pic of Old and new. IMG_20251027_204847_895.jpg IMG_20251027_204743_500.jpg IMG_20251027_204706_830.jpg IMG_20251027_204653_557.jpg
  10. fastcar1953
    fastcar1953
    54 Chevy car shackles seem like a better design. IMG_20251027_210335_477.jpg IMG_20251027_210326_008.jpg
  11. 57tailgater
    57tailgater
    from Georgia
    '55.2 & '56 used the shackles like you have with the just the carriage bolt holding the side plates on. '57-'59 use the ones like Squirrel shows that have the nuts on the outside of the pins. Front and rear are the same. My '57 has the ones with the nuts and never had issues. They are just originals and need to be replaced. You have to get complete kits to swap over. If you do get new kits, make sure you get what you want. I recently ordered some and they were your style and the pins didn't seat into the side plates as intended (manufacturing error). Given that and they didn't have the nuts outside like original (and my peace of mind) I returned them and got the later style from another source. As far as replacing with rubber bushings, I don't think there's enough room for a bolt, sleeve and enough bushing to fit in an original spring eye.
    Just looked at the Posies shackles. Interesting and probably not too bad of a price either for a pair as compared to stock replacements.
    fastcar1953 likes this.
  12. fastcar1953
    fastcar1953
    I ordered the rubber replacements. I will let you know when I get them and see if they are worth it or not.
    I just like a solid shackle not one held together by a all thread bolt.
  13. 57tailgater
    57tailgater
    from Georgia
    Yes the ‘55-56 ones just have that carriage bolt holding them together where the ‘57-59 have nuts on the ends of the heavy pins. Curious to see how these Posies one work!
    squirrel likes this.
  14. Joe H
    Joe H
    It might make it quieter, but I doubt the ride will be much difference. It will be an interesting test.
  15. 1971BB427
    1971BB427
    from Oregon
    I buy urethane bushings and they're always too large, so I run a bolt through them and then chuck the bolt in my lathe and turn the OD down to fit the '55-'59 springs, or other springs. They turn down quickly and easily. The bushings come with sleeves, so if I have to cut them down in length also I just cut the sleeve length to match.
    I'm not sure the ride is much softer, but a lot less road noise is transferred to the cabin.
  16. fastcar1953
    fastcar1953
    They are installed and I'm very pleased. I replaced the shocks and shackle bushings.
    Ride is better. Easy to install and replace if needed.
    If I replace them every year no big deal. I do expect to get 2 or 3 years of driving.
    Surely they will last 15000 miles or more.
  17. 1971BB427
    1971BB427
    from Oregon
    They've lasted since 1956 for the originals, so doubt the new ones will wear out an our lives.
    fastcar1953 and Budget36 like this.
  18. fastcar1953
    fastcar1953
    The originals were greasable bolts. These are rubber bushings.
    Although if you didn't grease the bolts they may not have lasted long either.
  19. 57tailgater
    57tailgater
    from Georgia
    Awesome to hear! Will have to keep this in mind if I have to go thru this again. Congrats on the fix!
  20. 57tailgater
    57tailgater
    from Georgia
    One thought I had was this just gives isolators on the shackle end, correct? It's still a steel to bronze connection on the front/stationary end, right?
  21. fastcar1953
    fastcar1953
