Technical 1954 Chevy 210 Turn Signal Issues
Discussion in 'Traditional Customs' started by mike1951, Nov 19, 2025.
  1. mike1951
    mike1951
    from Colorado
    For lack of a better descriptor, my turn signals have been acting up. First they were not cancelling every time. I noticed they would be still blinking after a turn. I would cancel manually and move on. Today the stalk felt different. It feels gummy, like it is not fully engaging and I am not seeing turn signals activated. I dropped the cup holding the cam and switch in place and I can see some movement, but I do not know what is appropriate. Any suggestions on cleaning the cam mechanism out and trouble shooting this?
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Here’s a pic of a complete working unit. Does your’s look like it? Any missing or broken parts after seeing this?
  3. mike1951
    mike1951
    from Colorado
    Thank you. I will pull the wheel tomorrow after work. and check with yours..
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I edited my post, added more info.
  5. mike1951
    mike1951
    from Colorado
    Thank you. I appreciate your help.
  6. 325w
    325w
    Make sure the gap between the collar and the steering wheel are close.
    wvenfield likes this.
  7. 302GMC
    302GMC
    from Idaho
    Take the Phillips head screw holding the cup to the mast jacket to Ace Hardware - get an Allen head same length to replace it so the switch doesn't ever come loose again.
    The switch is easy to take apart, clean & lube.
  8. RMONTY
    RMONTY
    I replaced the tiny springs that handle he canceling part of the mechanism on mine. I haven't installed it yet but just two nights ago I pulled it off the "to do" pegboard and noticed I had purchased a new wiring harness for it. Need to see how that will adapt to my wiring harness i purchased.
    I also noticed mine was acting " gummed up". Wonder what the best modern lubricant would be best suited for this application? I'm hesitant to go spraying brake clean all over it to get the gummed up **** off the rocker parts that get pushed by the steering wheel. Maybe some cotton swabs drenched in some isopropyl alcohol would do the trick. Sorry but no real answer from me but thought I might post what I've done and found on mine.
    mike1951 likes this.
  9. mike1951
    mike1951
    from Colorado
    I shot these this morning. Stalk side does have more of a gap. switch feels better this morning. Still no flashers and the cancel function is working. Will pull wheel after work and take a better look and show pics.
  10. mike1951
    mike1951
    from Colorado
    Here is what mine looks like. It appears to be hitting both sides of the switch just fine. IMG_2637.jpg
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    I enlarged the pic, always select "full image" when posting pics
  12. mike1951
    mike1951
    from Colorado
    I yanked the ***embly and I can manipulate that piece inside the switch. It feels pretty loose. When I move it up and down I do not get any turn signal action. Did the switch take a dump?
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    Possibly, I would check the fuses first and replace the flasher
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Did you turn the key switch on?
    Moriarity likes this.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The crack looks concerning. IMG_4975.jpeg Does the pivot screw feel firm when tight?
  16. mike1951
    mike1951
    from Colorado
    IMG_2641.jpg I did. And I got the car running for good measure.
    I found this flasher which appears to be related to it. and it is getting 12v to ground in and out.
  17. RodStRace
    RodStRace
    These are fuses. That is a flasher
  18. mike1951
    mike1951
    from Colorado
    Copy. Then the flasher is getting power on both sides.
  19. RodStRace
    RodStRace
  20. mike1951
    mike1951
    from Colorado
    I'll check that out. Electrical is not my strong suit, but I will learn. Car was done at some time by a PO when it was updated...and the wiring under the dash is not the cleanest. Will have to plan time to go through that. So here is what I know at this point:
    The turn signal mechanism appears to work as intended. I can see it go to each of the detents in the top and bottom of the p***enger side. You can see it set to the top detent in the initial photo.
    The crack in the cup where the screw mounts is concerning and my cup is not perfectly round. The cup is snugged up but not uniformly. But I am not sure if those impact the functioning of the turn signals. It looks like the mechanism just moves the switch in the gold housing. I do not think there is a circuit being completed by the mechanism.
    When I pulled the mechanism I could manipulate the switch back and forth and was getting no turn signals even when the car was running. The switch inside felt very loose. No real resistance or clicking. It just slides.
    The flasher is getting 12v in and 12v out when I turn on the ignition. Should it cut in and out when activated from the stalk? Does this indicate a bad flasher? If that were the case, I would think the turn signals would be on all the time?
    I have functioning parking lights. When I pull the headlight switch 1/2 way I have parking and brake lights on.
    When I turn on the headlights the parking lights go out and the headlights and brake/ rear running lights are on.
  21. 302GMC
    302GMC
    from Idaho
    Read post 7 again. If no detents are felt, take the switch apart & replace the broken parts, The springs can be made from Bic lighter parts.
  22. You have a bad turn signal switch. I'll note that the head/park/tail lights are powered and controlled from the headlight switch; the turn/brake lights are powered and controlled completely separately other than grounds. A lot of these old turn switches are unobtanium, but you're in luck; repos are available and at a very reasonable price... 1954 Chevrolet Bel Air Parts | TF900446 | 1953-54 Chevy Bel Air, 150, 210; Turn Signal Switch | Cl***ic Industries
    You mention the wiring is a bit messy, so I would highly recommend physically identifying each wire going to the switch before trying to install the new switch. There should be six wires; turn power will show voltage with the key on only, brake light power will show voltage when the pedal is depressed (key on or off), and the left front light, right front, etc etc. Connect each of these in turn to voltage to identify them, then mark.
    As I'm not very trusting of wiring diagrams or color codes, testing your new switch using this info... Turn Signal Wiring How-to | The H.A.M.B. ... will verify where each wire connects and also confirm that the switch is good.
    RodStRace likes this.
  23. mike1951
    mike1951
    from Colorado
    Thank you. I am going to oder a new switch and I am testing the flasher for resistance this afternoon.
    Hopefully I can get it knocked out before we head to Iowa for the Holiday.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    a bad flasher can do strange things, I have never heard of testing one before. they have them at every auto parts store and they cost 10 dollars. just get a new one and plug it in
  25. mike1951
    mike1951
    from Colorado
    Agreed. $10 part. I will be getting one, more about the rigor of practice for me. Using a volt meter.
    Checking resistance on the part reporting out what I find.
  26. 325w
    325w
    Lots of GM cars the headlight switch controls park lights with switch first stop. Second stop headlights on park lights off. Later switches allowed the park lights to stay on when the headlights were on.
  27. BJR
    BJR
    Just a note, the new flashers are ****. I got 3 bad ones in a row from 3 different stores. Found a NOS one and it worked great.
  28. RodStRace
    RodStRace
  29. mike1951
    mike1951
    from Colorado
    Resistance on the flasher is 53..... That seems low.
    Replaced flasher and we are up and running.
    I have a second switch enroute and I will keep it in the parts stash for future needs.
    I think I was thrown on a red herring by the poor feel to the stalk. On the plus side I have it all pulled out and cleaned up. It feels much more solid.
    Thank you to all who ***isted in the diag.
  30. Mr48chev
    Park lights that stayed on with the headlights on didn't come about until 1968 when the feds required side marker lights and the park lights often served as side marker lights or the added side marker lights were run off the park light circuit. Any earlier car or truck with park lights working when the headlights are on has been rewired to do so. On the 53. that is moving the Park light wire over with the Tail light wire on the headlight switch if you have a stock switch.
