Projects Building a 57 Chevy Shop Truck
Discussion in 'The Hokey Ass Message Board' started by swade41, Nov 1, 2017.
  1. Motorwrxs
    Motorwrxs
    Looking forward to seeing the direction you take your paint…
    porkshop likes this.
  2. swade41
    swade41
    from Buffalo,NY
    This whole adventure started as me wanting to make a Project X themed truck, yellow, cragars, etc. but I didn't think it would really work.
    I do have to say I like the factory dark blue and could see it in a weathered dark blue look, it's a shop truck so I don't want nothing fancy.
    Then I started matching that old flaky bed paint and all of a sudden the whole bed is done, leaving only cab and front clip. Since I did the water drops I've thought of doing different paint styles on the rest, maybe some lace, maybe some panels with endless lines, maybe this on the doors
  3. Dick Stevens
    Dick Stevens
    Mixing styles won't work out well, IMHO
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    porkshop and swade41 like this.
  5. swade41
    swade41
    from Buffalo,NY
  6. 57tailgater
    57tailgater
    from Georgia
    The Project X theme would have been interesting. I would like to do a 2 tone on mine similar tri-5 Chevy's but there's no good "breaking line" in my opinion. I am sure you will come up with something cool and appropriate for the shop truck theme.
  7. Motorwrxs
    Motorwrxs
    Project X would be cool as well as a two- lane black top truck. I have seen a tri-five truck on here somewhere that had the rear fenders opened like on TLBT, looked tough.
  8. swade41
    swade41
    from Buffalo,NY
    The Project X theme really just looked like a yellow truck with cragars, not really any connection at all.
    Maybe if the hood was off with a blown sbc and it sit a little higher in front, but without that it's definitely just a yellow truck with cragars like this one.
  9. swade41
    swade41
    from Buffalo,NY
    I do still kinda like this photoshop I had done when I was thinking of using a fleetside bed, I could still incorporate that "Bad Man" stripe super subtle like.
  10. swade41
    swade41
    from Buffalo,NY
    I started s****ing the crud off the frame, lot of original paint still on it
    Original paint under the undercoating too
    porkshop, X-cpe, Tickety Boo and 9 others like this.
  11. swade41
    swade41
    from Buffalo,NY
  12. Motorwrxs
    Motorwrxs
    What kind of sponge/scrub pad do you have attached to the drill? Looks like it saved some elbow grease…
  13. swade41
    swade41
    from Buffalo,NY
    $10 dollar set of nylon brushes I bought off Amazon, they work pretty decent
    https://a.co/d/2TRuzhk
    Tim, Tickety Boo, porkshop and 6 others like this.
  14. swade41
    swade41
    from Buffalo,NY
    I had got the majority of the frame cleaned except around the steering box, so I decided to remove it. This pitman arm was pretty difficult to come off using my old tried and true methods of aluminum wedges, pry bars, hammers and heat.
    So I hit the s**** bucket and found a pair of 1/2 inch or so plates that looked like buggy spring plates off of something from the past. I cut the back out on one to slip over the steering box shaft, drilled the holes out for the bolt heads to slip into so I could weld them in place. The reason for that was how close the pitman arm was to frame, the width of plate along with the width of the head of the bolt was just to thick.
    The contraption worked like a charm and pulled the pitman arm with relative ease, so I got the steering box/column combo out, along with clutch and brake pedals.
    Even found the number on the frame
  15. swade41
    swade41
    from Buffalo,NY
    I have to say the plastic was one of my better ideas, sure is making a mess
    But the frame is looking clean
    I didn't do the bottom side yet or any under the cab but it sure seems like it'll be less messy when I wire wheel it.
    Tim, Tickety Boo, porkshop and 5 others like this.
  16. kls50
    kls50
    I need one of these in 2XL! I have lived and hoarded stuff for thirty years in my current home, I started selling stuff I know I'll never use again, even though it is COOL. Nothing car related yet! Funny how we can fit 2 1/2 cars in a 1 car garage. By the way, your Kaiser/projects are COOL! No downsizing needed please!
    LOST ANGEL and swade41 like this.
  17. swade41
    swade41
    from Buffalo,NY
    Plastic was out since I was drilling, chiseling and grinding rivets to remove the brake and clutch ***emblies, making a mess.
    Almost as much of an ***ault on my nose from BP Blaster and really rank old gas when removing brake and fuel lines, it actually ran me out of the garage. LOL
    When you use a chisel and hammer you quickly find out where the rust is, it's right down your shirt, pants and in your face !
  18. fastcar1953
    fastcar1953
    Pb blaster works. I hate the smell. Wife wants me to take off clothes before coming in from shop and not for the good reason. She washes them separate. I now have only shop clothes and the shirts stay in shop.
    porkshop, X-cpe, swade41 and 2 others like this.
  19. swade41
    swade41
    from Buffalo,NY
    Back when my garage still had the apartment and tenant in it I had used BP on something. The tenant called me up saying I was g***ing him out, they were puking and turning green. LOL
  20. kls50
    kls50
    I cleaned a gun once with PB Blaster and it took the bluing off. Pissed me off too!
    swade41 and porkshop like this.
  21. X-cpe
    X-cpe
    My brother was a roofer. They had a separate washer and dryer for his work clothes.
    porkshop and fastcar1953 like this.
  22. swade41
    swade41
    from Buffalo,NY
    My son is a Toyota tech and he definitely has shop aroma when he comes in from work and there's a stain in the laundry tub to prove it. I ask him if they had laundry service and he said yeah, but things get lost, so he's afraid to use it.
    I got some of that stinky gas on my pant leg, man it was powerful, I threw the paints down in the ba*****t instead of putting them in the laundry basket. LOL
    I put the old gas lines outside and plugged the tank line before I made a break for fresh air, that gas looked like rootbeer it was so old.
    Dooley, porkshop and loudbang like this.
  23. swade41
    swade41
    from Buffalo,NY
    Even with all that cleaning I did it still makes a hell of a mess, I think I'll use the full face respirator to finish it up.
    20260102_162856.jpg 20260102_163847.jpg 20260102_151942.jpg 20260102_151913.jpg 20260102_153924.jpg
    Amazon just dropped off some new brushes to tackle the rest, supposedly the knotted is better, we'll see
