Projects The used up '48 Plymouth Coupe
Discussion in 'The Hokey Ass Message Board' started by themoparkid, Nov 22, 2025.
  1. themoparkid
    themoparkid
    Well folk's I'm new here so hopefully I'm in the right place. To start off I acquired this beat up but fairly solid 48 Plymouth Coupe about a year ago. In the last few months when time allows I go to my tiny "shop" and work on bringing this old thing back to life. The ultimate goal is a sort of custom/hotrod. It'd sat for 30+ years when I got it and someone had partially dis***embled it. So here I am rebuilding, and cleaning things up (slowly) as time and money allow. These first two images show it as I found it on Facebook marketplace Messenger_creation_1548269819120776.jpeg Messenger_creation_854947766619617.jpeg
  2. themoparkid
    themoparkid
    Someone had swapped in a '68 318 and 727, along with the brake booster/master cylinder from what I ***ume is the same '68 Chrysler product (dart I believe). In doing so they cut the front floor pan out of the Plymouth Coupe and grafted in the 68 dart floor pan so the ****** tunnel had enough clearance. Over the last month I've wire wheeled and s****ed all the rust and hard undercoating off and applied P0R15 image.jpg IMG_20241130_162709025.jpg IMG_20251022_155048429.jpg
  3. Rocky
    Rocky
    Classified Editor
    Cool. I've always thought those 40's business coupes have a beautiful top. I likes it.
    osage orange, rod1, Budget36 and 4 others like this.
  4. evintho
    evintho
    Lots of potential there! I hope you have the all the front sheetmetal and rear fenders as they could be a bear to locate. Also, what's that steering column out of? Looks like a great project!
  5. themoparkid
    themoparkid
    Have all the front sheet metal.... didn't have a good however when I purchased it. I ended up driving from Pennsylvania to the Ohio/Michigan border and bought a slightly dented one for $50 Column was out of something GM and was all busted up, so a good friend donated a decent tilt column out of a mid 80's cutl*** image.jpg
  6. themoparkid
    themoparkid
    My small "shop" it's actually an old school and the cl***rooms are garage bays...I can't complain, the rent is cheap. IMG_20241116_153040258_HDR.jpg IMG_20241116_153015049_HDR.jpg
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Looks as if You are on the right track,, with a great player in the post war trafficing.
    My Step Dad had that in the 2door version.
    I'm glad you are continuing to bring it up to a usable level.
    We'll all be glad to see the growth.
    Thank You.
  8. themoparkid
    themoparkid
    Appreciate the kind words! Currently have the front end all torn apart and waiting on parts... pictures to come in a few days!
  9. catdad49
    catdad49
    Keep at it, Kid. Looks like it has good bones!
  10. Budget36
    Budget36
    I love that body style.
    But it needs to have some at***ude and be a hotrod!
  11. themoparkid
    themoparkid
    The plan so far is to use 51 Pontiac taillights, skirts, lake pipes, and maybe dummy spotlights. And drop it 2" in the front and 3" in the rear
  12. Yup, you are in the right place…
  13. RodStRace
    RodStRace
  14. themoparkid
    themoparkid
    Someone had already done that and used what I ***ume are motorcycle shocks...I plan on doing something a little bit different there
  15. RodStRace
    RodStRace
    Uggh. Got my current project with Harley coil overs. They are gone now!
    Here is a listing for shock upper and lower mounts and length. It will take a bit to find exactly what you need, but once you do the number will show application and you can cross reference to another brand if you prefer.
    https://www.shockwarehouse.com/pages/monroe-measurements
  16. goldmountain
    goldmountain
    Looks like the previous work done is decent. My avatar shows a leaning in this direction.
  17. themoparkid
    themoparkid
    For the most part it's ok for being done 40 years ago. Mostly it's me doing thing what I consider "improvements" the whole v-8 swap was done using nothing but donor car parts and a stick welder. Same goes for the mustang 2 rack they put in. It's easy to criticize someone else's work but after a while I came to the realization that not everyone is a Chuck Lumbardo or Gene Winfield. These guys were like me doing everything by hand probably in a rinky dink shop, with pennies and no Internet.
  18. SASROD
    SASROD
    How did they get the Chevy truck rally wheels on the front?
  19. RodStRace
    RodStRace
  20. 1952henry
    1952henry
    Nice project, good luck with it. The chalkboard would be very handy for notes, checklists, sketches, etc. Very cool!
    down-the-road and osage orange like this.
  21. themoparkid
    themoparkid
    ffr1222k and bchctybob like this.
  22. themoparkid
    themoparkid
  23. RodStRace
    RodStRace
    Those look new. Consider some sort of protection in the area where the rim meets the inside. That little crack tends to rust, and the best time to deal with it is now. Either a really good wax/sealer/coating or a thin bead of clear silicone. Something to shed the water that wicks in.
  24. gene-koning
    gene-koning
    The 318 will make that car a great driver. My 48 Plymouth business coupe was in a lot rougher condition then what you started with, but my son and I built a 47 Plymouth for him years ago. We put a 360 4bbl in his coupe. Do you have the gl*** for your car?
  25. themoparkid
    themoparkid
    Yup.... have all the gl***, my headliner came unattached from the bows and the interior guy told me to leave the gl*** out so he can take the headliner out and fix it
    ffr1222k, gene-koning and bchctybob like this.
  26. themoparkid
    themoparkid
    A little progress was made in the evenings over the last week or so. New wheel cylinders, bearings, races, seals, relined shoes, cut drums, slightly used chrome steelies... I apologize for the terrible pictures but I am after all a grease monkey working in an old school room IMG_20251130_123736418.jpg IMG_20251130_143441602_HDR.jpg IMG_20251130_121908955_HDR.jpg IMG_20251203_180002302.jpg
  27. themoparkid
    themoparkid
    The next issue with using the gm tilt column with a mustang 2 rack was the steering shaft. Ebay saved the day until the parts showed up and I realized we now have clearance issues. I believe the mid 90's rams had a more rear exiting Snapchat-1205236607.jpg exhaust manifold sooo I will be heading to the junkyard on Saturday to find one on the cheap
    osage orange, Okie Pete and ffr1222k like this.
  28. RodStRace
    RodStRace
    While there, look for a later model mini starter too. You would hate to bolt up later manifold and find the old starter won't play nice.
    osage orange and themoparkid like this.
  29. themoparkid
    themoparkid
    It's hard to see but its already on there...best part was it was sitting in my ba*****t collecting dust from my last project ( 73 dart sport 340) ran the newer style starter with headers so I needed all the room I could get. Sold the dart as a roller and someone else bought the short block and didn't want the starter
  30. Okie Pete
    Okie Pete
    A chock board to write down a to do list
