Projects The Chevy T WildCaT project
Discussion in 'Traditional Hot Rods' started by Blackbob, Mar 9, 2020.
  1. Blackbob
    Blackbob
    I was measuring that today, there's 0.30" between the bores.. I have my concerns but will give it a try, worse case is that I have to get them lined and go down in size, but it's a low compression motor so I might get away with it.
  2. 282doorUK
    282doorUK
    I have three blocks, all have a lot more wear in number one bore behind the water pump, presumable from that area being colder.
    My retired machinist mate reckons that 3.870" for F**d pistons would clean them up, and a good gasket width between bores can be retained by moving number one and four outwards and number two and three inwards just a tad. Quite a common trick in days gone by apparently. The offset to each rod would be too small to have any effect.
    I mentioned this in Andys thread but was too late for him to tell his machinist.
    You might have better results by lapping the head on and doing away with a gasket altogether.
    Dannerr likes this.
  3. Blackbob
    Blackbob
    P
    That would have been a better way to go, with the aA rods being narrower on the journals theres room down there too! I mis read the notes 0.135” between bores .. still carefully lapped head and sticky aluminium paint might do the job!
    Dannerr and 282doorUK like this.
  4. Duke of Haphazard
    Duke of Haphazard
    from PNW
    Checked out your builds. They're all pretty interesting. Still working on them?
    Blackbob likes this.
  5. Outback
    Outback
    from NE Vic, Oz
    This is as cool as a cool thing, hopefully there is some updates sometime soon!
    In the words of someone greater than I
    "Patiently waiting" :D
  6. Blackbob
    Blackbob
    it’s all still on the bench, I’ve just had to go back to full time work and been doing a full Restoration on a house.. more soon
    Outback and Dannerr like this.
  7. Hi Steve, Nice to see you're still doing it. The last time we communicated was after you moved from Achnasheen, and we moved to Boston. Since then we've built a garage and I (sort of) finished my truck. new7.jpg Charlie (ex of Skye) Good luck mate.
  8. Outback
    Outback
    from NE Vic, Oz
    So good to hear it's still on the bench :cool:
  9. Blackbob
    Blackbob
    Hi Charlie,
    Good to hear from you, love the truck 8) Yeah time moves on at pace, the list of jobs never gets smaller , the list of big ideas is the same. I need to trim down the projects to what I can manage but as we all know, that ain't easy!!
    Deutscher and Outback like this.
  10. Yeah! Not enough hrs. in a day, at least not enough that I can use( getting old now). Got the truck on the road, so, now redoing Irene's OT moggy. It needs a good cuddle. Onwards an upwards.
  11. WeeTom
    WeeTom
    Hey Charlie,
    Good to see you’re still on the right side of the gr***! Did you ever do anything with that Model A grill shell? Truck looks good.Sorry to Hijack thread, Steve.
    Tom
    Blackbob and Outback like this.
  12. Cheers Tom, Still got the shell, and most of the parts to build an "A" roadster (Gl***), if I ever get round to doing it.:D:D
