Customs What’s a good highway rear gear
Discussion in 'The Hokey Ass Message Board' started by ahshoe, Nov 24, 2025 at 5:03 PM.
  1. ahshoe
    ahshoe
    Looking for a recommendation on a good cruising 65-70 mph highway rear gear for a 51 coupes I am working on. Has a mild Ford 302 with an AOD .What would be s good highway gear with that combination?
    Tow Truck Tom likes this.
  2. squirrel
  3. Bandit Billy
    Bandit Billy
    3:70? I see Squirrel beat me to it.
    GordonC likes this.
  4. chevyfordman
    chevyfordman
    definitely not the 3:55 with an AOD, I changed mine to a 3:70.
    2devilles likes this.
  5. Bandit Billy
    Bandit Billy
    I have a 3:55 behind a T-400 in my Olds, nice fit for around town and light highway use (<70).
    I have a 3:70 in the 41 PU behind a RE46 OD trans and it is a pleasure both in town and freeway speeds.
    HemiDeuce and Tow Truck Tom like this.
  6. jimmy six
    jimmy six
    If it’s in your avatar…I installed a 2.74 rear gear in our 56 and it’s perfect for hyway and street with no OD trans. I don’t know what the ratio is for your AOD or what rear you have and what’s available. Mine is an 8.8 from a Ford Explorer with F-150 drum brakes. IMG_2009.jpeg
  7. Mimilan
    Mimilan
    Depends on Tyre rolling diameter.
    A good ratio for highway use would be between 3.2 and 3.4 depending on tyre size
    If it has 26" diameter tyres a 3.27:1 would cruise at 1981 rpm at 70mph in O/D
    pull it out of O/D for p***ing ,and the revs jump to 2958 rpm
    A 1951 Ford coupe weighs 3170 lbs [probably less with a SBF]
    And a Fox Body GT Auto Mustang weighs 3320 lbs
    This is a car of similar weight and a 302 [5.0] with AOD
    The GT Auto Mustang had a standard rear end ratio of 2.73 and a 3.27 ratio optional with auto trans
  8. Bandit Billy
    Bandit Billy
    All of the US (muscle cars, if you can call them that) had legs like that under them because they needed fuel economy, not for power or fun. Most of the late 70's Trans Ams I owned all had those gears, dogs on the street! Embarr***ingly so. Couldn't get out of their own way. They are cheap though, every wrecking yard has a host of 2 series carriers in them. I guess it depends on what the OP wants out of his ride. To each their own. Not every car needs to be quick. I get lousy gas mileage, but I make it from station to station in a hurry.
  9. krylon32
    krylon32
    from Nebraska
    Another vote for 3.70's That's the ratio I sold most of when I built a customer ch***is with an OD trans.
    Sharpone and Just Gary like this.
  10. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    @chevyfordman Seems to me that highway speed, these days, starts at seventy.
    jes sayin'
    Squablow, ekimneirbo and Sharpone like this.
  11. Dos Cincos
    Dos Cincos
    I run a 3.50 gear with my mild 302 and AOD and it cruises just fine down the interstate
    Sharpone likes this.
  12. Tim
    Tim
    from KCMO
    Tire diameter is going to be a big factor but given the general range of tire that would be common on a shoebox 3:70 sounds about right.
    There are plenty of free calculators online if you have a certain rpm at x speed you are wanting to aim for.
    Sharpone and snoc653 like this.
  13. snoc653
    snoc653
    from Iowa
    The answers given work for the people giving the advice. But you need more info to make a proper decision. Tire size, power and torque curve of the engine and all 4 gear ratios for the trans. And most importantly how you plan to drive it. There are numerous rpm calculators online. Once you have the above, figure out where you want it to cruise at the speed you desire. Also figure out what it looks like in each of the gears. If you accelerate you want to be somewhere in the power band and you want it to shift before you are out the top of that band. But you don’t want it to fall through the bottom when you hit the next gear. OD is usually a lock up gear so what does it take to lock it up?. Is 3rd a lock up also? Small blocks usually cruise at more rpm than a big block but with rpm comes exhaust noise. What is comfortable is also a consideration.
    clem and Tow Truck Tom like this.
  14. 38Chevy454
    38Chevy454
    What type rearend are you running or have? That may help the gear ratio choice some. Also good point on tire diameter. I think around 3.55 will be good starting point for evaluation.
    Algoma56 likes this.
  15. squirrel
    keep in mind that the AOD might like to "hunt" between 3rd and 4th if you don't give it enough gear
  16. Nice Drivelines driveshaft. Wades white stripe.
  17. mixerman
    mixerman
    I've got a 327 engine rpm 2900/ TH350/3:55 rear/28.9 dia. tire = 70.26 mph
    I wish I had around a 2.73 rear
    A good site to figure out what you have or what you need to get better results.
    Transmission Ratio RPM Calculator | ****er Parts
  18. 57JoeFoMoPar
    57JoeFoMoPar
    65-70 will allow you run a little more gear. I like to gauge "left lane" speed, so I try to gauge my gear on an 80 mph cruising speed. I have a stock 3.08 rear with a 700R4 and a 27.7" tire, and it could really use a numerically higher gear. A 3.64 or 3.42 would probably be ideal, since right now 80 mph is 2000 rpm and sort of below the powerband.
    49ratfink likes this.
  19. AldeanFan
    AldeanFan
    Something that starts with a 3.
    I have 3.45 gears in the ‘54 with a Yblock and AOD and it is a perfect cruiser with 205/65r15 tires.
    My mustang has a 302 and t5 with 373 gears and 235/60r15 tires. It’s also a great combo. It previously had 308 gears and that wasn’t enough, and 410’s temporarily but that was no good on the highway.
  20. ebfabman
    ebfabman
    27 inch tall wheel, stockish sbc, 200-4r trans w lockup, and 3:73 rear gear. Perfect for a 1951 Merc.
  21. 49ratfink
    49ratfink
    my OT car with OG 28" tall tires has a 3.42 gear. I do 2000 RPM's at 65 MPH. I don't see any reason to want a higher cruising RPM than that. the only time it downshifts is up a hill or when I hit the go pedal hard.
  22. DDDenny
    My 57 BelAir had a tired 283, T-10 and 4:11's, let them small blocks sing!
  23. 1biggun
    1biggun
    Id look at a 3.55 gear for a driver that see a lot of highway miles.
  24. I had an old hot-rodder (now I fit that bill) tell me years ago when I asked that question- 3.25 to 3.50 for non-OD transmissions, 3.55-3.90 for OD transmissions, and torquey engines such as Nailheads and straight 6s high 2s or low 3s
  25. Acres
    Acres
    from Sweden
    My chevy with a tired sbc 267 with a 350 trans runs suprisingsly good with a 3.30 gear.
    But the most optimal choice is a high torque engine with a 2.73 gear, youll get there fast and cheap
  26. jimmy six
    jimmy six
    They come to the house to measure and get the correct u-joints….how can you beat that!
    427 sleeper and GuyW like this.
  27. MARKDTN
    MARKDTN
    An AOD has a .67 overdrive so take any ratio you had with non-OD and divide by .67. So if you liked 2.73s for cruising with a 1:1 transmission, with an AOD you could have a 4.1 to have the same RPM at highway speed. 3.73 is a common gear for an 8.8 or 9-inch as is 4.10. I would lean towards 3.73.
    2devilles and Tow Truck Tom like this.
  28. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Get your tire size and use the calculator someone listed above to see what puts you at 80 mph and 2200/2300 rpms in overdrive. That is what it takes to be able to cruise with most traffic in my truck. I imagine my rear tires are probably slightly larger than what you will have. It came with 3.73 rear gears. What you don't want is to have to be at 2500 rpms+ when in the speed lane and just staying generally with the traffic. Try getting on an Xway and driving about 30 miles at 70 mph in your DD and see if you aren't constantly looking in your rear view mirror at the approaching traffic behind you........especially semis.
    427 sleeper and Tow Truck Tom like this.
  29. Plan on using a 3:70 in the wife’s car with an auto OD
    I have a 3:92 in the car I’m building with a 3 speed OD
    I cruise around 55 I’m my beater.
    Never an issue on the interstate
  30. Mimilan
    Mimilan
    The number 336 is what you need to remember for the calculations [it is the constant]
    The formula is "RPM x Tire diameter [inches], then ÷ by MPH , then ÷ by 336 = Overall Ratio.
    If 2000 Rpm is desirable and you have 28" diameter tires , it goes like this.
    2000 rpm x 28" = 56000
    56000 ÷ 70 mph = 800
    800 ÷ 336 = 2.38 overall ratio
    2.38 ÷ 0.67 AOD overdrive ratio = 3.55
    If 2000 Rpm is desirable and you have 26" diameter tires , it goes like this.
    2000 rpm x 28" = 52000
    52000 ÷ 70 mph = 742.85
    742.85 ÷ 336 = 2.21 overall ratio
    2.21 ÷ 0.67 AOD overdrive ratio = 3.29 [3.27 is available from Ford]
    So going from 26" tire I previously posted up to 28" tire drops the rear-end ratio from 3.27 to 3.55
    The formula above allows you to use your phone calculator [just remember "336"]
