Projects LA HOT RODS Get's A 37 Pontiac Gasser Build
Discussion in 'The Hokey Ass Message Board' started by saltflats, Dec 24, 2022.
  1. saltflats
    saltflats
    from Missouri
    Here's a picture with the 11 inch setback.
  2. saltflats
    saltflats
    from Missouri
  3. saltflats
    saltflats
    from Missouri
    Got my tubing racks done and somewhat organized. Moved the car over a little and leveled up.
    So now I can get started on making the other frame horn.
  4. saltflats
    saltflats
    from Missouri
  5. saltflats
    saltflats
    from Missouri
    Now one can see why I just couldn't leave the rail just straight out the front. I see my vision coming together.
  6. rusty1
    rusty1
    very nice work, neat project you got goin...
  7. saltflats
    saltflats
    from Missouri
    Thank you. It's fun to get back at it.
  8. Got to agree with Rusty1. Top notch professional work. Damn! Now what engine/transmission's going into Geronimo?
  9. saltflats
    saltflats
    from Missouri
    I have several options but leaning towards one of my 409 engines. What ever it will be it will be back by a top loader 4 speed.
  10. atch
    atch
    Wouldn't a Super Duty 421 be more appropriate?
    We know you have more 409's laying around than the general population but come on...
    bchctybob, 31 B'ville, SS327 and 6 others like this.
  11. saltflats
    saltflats
    from Missouri
    Don't have any Pontiac engines in my stable. They did use 409s in Canadian Pontiac.
  12. mad mikey
    mad mikey
    Looking great James, You are right, could not leave it with straight frt frame rails. Your creation of the rails makes it much more stylish and unique compared to most g***er cars being built. Happy Thanksgiving buddy.
  13. saltflats
    saltflats
    from Missouri
    Thank you Mikey. Happy Thanksgiving to you and yours.
  14. saltflats
    saltflats
    from Missouri
    Got the cuts made now a little cleanup then I can bend them into shape.
  15. saltflats
    saltflats
    from Missouri
    Getting closer. Need to fire up the torch to finish the front off.
    bchctybob, porkshop, 5w Jen and 11 others like this.
  16. saltflats
    saltflats
    from Missouri
    Think I can live with this.
  17. Stock Racer
    Stock Racer
  18. saltflats
    saltflats
    from Missouri
  19. saltflats
    saltflats
    from Missouri
    Thinking something like this for the inside fishplate.
  20. mad mikey
    mad mikey
    Wow, that looks so good James. Kinda just flows.
  21. saltflats
    saltflats
    from Missouri
    Thank you Mikey.
  22. Again, professional, flawless, well thought out.
  23. SS327
    SS327
    You should start manufacturing those. They really dress up a boring frame!
  24. saltflats
    saltflats
    from Missouri
    Thank you Steve.
    porkshop and chryslerfan55 like this.
  25. saltflats
    saltflats
    from Missouri
    I think I can put these fishplates into production.
    enloe, bchctybob, mad mikey and 6 others like this.
  26. saltflats
    saltflats
    from Missouri
    Playing around with the steering location. I do know I want the drag link as level as possible. I may need a box that is reversed from this one. Not sure yet.
  27. saltflats
    saltflats
    from Missouri
    Still playing with the steering and think I'm getting it close. Also checking the caster and I'm just under 10 degrees at this point. Doing a lot of reading on this subject a lot say 5 to 7 not sure if my just under 10 will work. This car will be race only and has a 122 inch wheel base.
  28. Tickety Boo
    Tickety Boo
    from Wisconsin
    When the stance of the car changes, the caster degree will change, might want to just tact the axle for now, until the 409, front clip and body is on the springs with all 4 wheels on the floor
  29. saltflats
    saltflats
    from Missouri
    Be a lot of tacks before final welding.
  30. saltflats
    saltflats
    from Missouri
    Finally out of the kitchen and got a start on welding up the new frame pieces. Figured I would jump around and side to side so I don't tie this in a knot.
