I finished the body work on the wheel arch. Also straightened out the grille and the chin panel below it. Rust repair is finished, not sure where to stop on the rest of the body.
Not much happening on this lately , but I did manage to do some work on the engine cover. Insulation on the inside and bed liner on the outside.
I think you can do it.. Im gonna have to donit in my bus..I plan to bring the green OD under the house paint.
At some point in the past, someone butchered the ashtray hole.... for a radio maybe? Luckily the metal was still there, just folded in.
Welded back up. Need to find an ashtray. Supposedly there are a couple of these vans in a junkyard an hour away. I need a few other things too, maybe check it out when it warms up a bit
Minor update. I finished the body work on the dash and sprayed it with some rattle can green. Not an exact match, but works for me. Fits fine with the rest of the van's "character "
