Featured Projects Torpedo Attack Season 2
Discussion in 'Traditional Customs' started by Woodlouse, Oct 22, 2025.
  1. NoSurf
    NoSurf
    Did you use a copper backer to weld up the trim holes?
    Woodlouse likes this.
  2. pgj
    pgj
    from aurora co.
    How is the door gl*** going to work? Or no gl***?
  3. Squablow
    Squablow
    Impressive work with the door gaps, they look very even.
    Woodlouse and downlojoe33 like this.
  4. Woodlouse
    Woodlouse
    from London UK
    NoSurf likes this.
  5. Woodlouse
    Woodlouse
    from London UK
    Budget36 likes this.
  6. Woodlouse
    Woodlouse
    from London UK
    Outback and Squablow like this.
  7. Okie Pete
    Okie Pete
    Beautiful work
  8. pgj
    pgj
    from aurora co.
    I guess i should have asked how the door will open with the window up and the corner of it behind the lower corner of the a pillar.
  9. Woodlouse
    Woodlouse
    from London UK
    The sight line of the door frames welded back in, will become the shape and size of the new stainless frames minus gap for tolerance. I am going to square off the the original frames from this point then build up a new stop along side the new stainless frames to keep the weather out. Hopefully the drawing explains it better then my words.
  10. Woodlouse
    Woodlouse
    from London UK
    It is said that most of the work of a fastback chop is in the boot lid. I would agree with this statement.
    The boot lid is basically a large wedge shape, which has to be reduced in width and length whilst keeping in line with the flow of the roof, not easy.
    I first removed the outer skin to access the inner frame which I cut into 6 sections. These pieces I moved around and overlapped to fit the new smaller frame size, I kept the top piece hinged and the bottom piece locked in place. This made a good starting point to tack it all back together. Returning to the skin, I welded up the no longer needed number plate window and re-done some old repairs which needed some improvements.
    After that, the sides were cut and shut to fit the frame, the big worry was distortion, but I took my time and it's not come out bad.
    I bought myself some Cleco fasteners, first time I've used them, well impressed they work a treat.
    The skin still needs to be welded back on.
    If possible, I always aim for a factory look on any repairs or alterations, so I didn't fancy just welding the skin to the inner frame. My way round it was to make up a return lip and plug weld it to the frame with an overlap I could trim to the opening, then weld the skin to that.
    Very labour intensive, but worked well and when cleaned up looked very original, made me happy!
  11. Squablow
    Squablow
    Interesting approach to the trunk lid, looks like it fits very well.
  12. bubba55
    bubba55
    Dang it mon - y’all’s planning and execution of your skills is just awesome
    Continue on - enjoying y’all’s work and post - thank you kindly for sharing
    Outback, Woodlouse and Budget36 like this.
  13. 340HilbornDuster
    340HilbornDuster
    WOW!
    Incredible Job / Craftsmanship!!
    The Chop / Stance is Perfect!!!
    Outback and Woodlouse like this.
  14. 38Chevy454
    38Chevy454
    I really like the way you separated the inner and then cut into separate pieces, along with keeping the top and bottom secured, then fitting it back together. Nice logical plan.
    Budget36, Outback and Woodlouse like this.
  15. Outback
    Outback
    from NE Vic
    It's projects like this that I love seeing on the HAMB, what an amazing job @Woodlouse like had been said it takes guys to cut up a nice car, but still not a small job! Will subscribe & follow along for the rest of the journey
  16. Chucky
    Chucky
    My eyes are poking out, hair is blowing back, mouth agape…
  17. James D
    James D
    Impeccable!
  18. ne'erdowell
    ne'erdowell
    Very impressive. It's gonna be great, thanks for sharing.
  19. WoW! all I can say is that it reminds me of the old saying, "anyone can restore an old car, but it takes a Man to cut one up!" I guess we can now add to that with " But it takes a REAL MAN to cut up one as nice as that!"
    Looks great,
  20. Woodlouse
    Woodlouse
    from London UK
    More or less up to date now, it's been a little over a year since chop day and I finally got the car out in daylight to get them distance shots.
    Riding a little high at the moment but that will be sorted. Winters coming and it's getting cold in the barn where the build is happening so next up will be to strip the remaining paint on the roof, then filler and prime before it starts rusting up.
  21. Outback
    Outback
    from NE Vic
    Great work! Is the Barn warm enough to keep working over winter?
    Are you planning on a colour change? Or keeping what you have?
    Woodlouse and NoSurf like this.
  22. Dubonet Garage
    Dubonet Garage
    from France
    You're turning a beautiful car into a masterpiece, bravo!
  23. Mart
    Mart
    Not bad for a dead tree botherer. Great work team. Mart.
    hotrodfil, Outback and Woodlouse like this.
  24. Woodlouse
    Woodlouse
    from London UK
    Yeah, I will keep at it though the winter, I have built myself a cosy little garage in the corner. couple of fan heaters keeps it bearable the lecky bill not so much. HaHa.
    Defiantly a colour change, trouble is it changes daily.
    Squablow and Outback like this.
  25. Woodlouse
    Woodlouse
    from London UK
    Thanks Mart, my "Team" have all disappeared now, which I believe is quite normal after chop day.
    Outback likes this.
  26. downlojoe33
    downlojoe33
    That’s going to be one sweeeeet ride when finished. Can’t wait to see what color you choose.
    Outback likes this.
  27. Woodlouse
    Woodlouse
    from London UK
    Nothing like a bit of paint to make a project look like it's buzzing along. The metal prep and filler work took forever, but well pleased with the result. Thoughts are turning to the window frames now, I can see the end is in sight.
  28. Outback
    Outback
    from NE Vic
  29. nochop
    nochop
    from norcal
    Fuuuuuuuuu*k
  30. Professor Fate.
    Professor Fate.
    Tough car to chop and you got a beautiful flow across the top. Nice job.
    How many times have you walked into the exhaust pipes since they went on?
    Woodlouse and Outback like this.
