Technical 52 Buick/66 Malibu brakes
Discussion in 'The Hokey Ass Message Board' started by alphabet soup, Nov 26, 2025.
  1. My buddy has a 52 Buick on a 66 Malibu frame. For some reason, when they did it, they put the master cylinder in the floor. It really has been a pain for him. He is looking to put a master cylinder/ booster on the firewall and four-wheel disc brakes. Does anyone have experience doing something similar? If so, did you buy a whole kit of some sort? Thanks, Gene.
  2. 1pickup
    1pickup
    I'd check with Cl***ic Performance Products. They should have brake kits for the '64-'67 Chevelles.
    alphabet soup likes this.
  3. Just the frame or complete drivetrain?
    Ben
  4. oldolds
    oldolds
    They put the master cylinder under the floor so you did not have the ugly booster on the firewall.
    That being said I would just go with disc on the front. You will have to fabricate the mounting for the booster and pedal ***embly. As stated above the brake parts for a Chevelle are available at a number of places.
    38Chevy454 and alphabet soup like this.
  5. They used a complete rolling ch***is. But they had to move the motor and trans. I don't remember forward or rearward. I can ask if you want to know. Gene.
    firstinsteele likes this.
  6. Thank you, Gene. No sweat, I was just curious.
    Ben
  7. pprather
    pprather
    I don't understand moving the master cylinder. If it works why go to the work of moving it?
    Mounting the pedal(s) under the dash will not be easy.
  8. [QUOTE="pprather, post: 15758526, member: 25685"
    Mounting the pedal(s) under the dash will not be easy.[/QUOTE]
    What is in Hot Rodding?
    Ben
