Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. Kevin Pharis
    Kevin Pharis
    from Califunny
    Workin on a dual Winfield setup and missing one of these… not anymore!:D
    Sharpone, elgringo71, jet996 and 22 others like this.
  2. Kevin Pharis
    Kevin Pharis
    from Califunny
    Gettin closer…
    1952henry, BigRRR, NJ Don and 24 others like this.
  3. Excellent work Kevin! Your attention to detail is always so inspiring!
    BigRRR, Sharpone, winduptoy and 2 others like this.
  4. tubman
    tubman
    Simply amazing work.:cool:
    BigRRR, Sharpone and winduptoy like this.
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
    Doesn’t get any kooler than this…!:cool:
    Jimmy, 1952henry, BigRRR and 23 others like this.
  6. Pretty impressive, keep it up
  7. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  8. winduptoy
    winduptoy
    well, that set up is sure going to make the A/F mixture dizzy for more HP......
    Ed would be proud
    Sharpone, porkshop, jet996 and 3 others like this.
  9. Johnnyfud
    Johnnyfud
    absolute artwork
  10. Kevin Pharis
    Kevin Pharis
    from Califunny
    After a short stint at the plating shop, I now have most of a new carb copper plated. Now, before anyone blows me up about what color they supposedly were originally… I have been lucky enough to have, or gain access to, some incredibly well preserved (dare I say NOS) original pieces.
    Most Winfields have long shed their thin protective plating, retaining either a pewter look, or a heavily stained brown color commonly mistaken for plating. But occasionally, small segments of original plating will survive. When cleaned with some polishing compound, a bright copper sheen is revealed.
    I have heard the tale of Winfield carbs being “bronzed” at the neighboring baby shoe dipper, but am trying to stick to tangible facts rather than folklore. The cleaned up originals are definitely copper, and mold marks being visible thru the plating indicate that the plating was very thin (electroplated, not dipped). The tarnish lifts quite easily, even considering that there is an additional 90 years of buildup. I highly doubt these carbs were offered with a bright copper finish originally, and would have corroded into green carbs long ago if they had. So I began to look into industrial treatments to prevent corrosion on copper, as the original Winfield finish was likely not proprietary. Most copper treatments are artis**** and produce green surfaces, but eventually found a process that creates a chemically induced tarnish, that will protect against green corrosion and also turns the copper dark brown/black.
    Here we are in brilliant copper. Gotta admit, I like it! But the goal here is to get close to the original color as possible;
    A little time in the magic dip, and it looks almost like a gun metal, but with a brown undertone instead of blue. Hard to get a pic that truly shows the color, but here are some pieces ***embled to a throttle barrel that is near NOS. Color is close, with an extra dose of gloss;
    The 90 year old original throttle barrel lacks any luster to the plating finish, but I can’t help but wonder if it was simply lost over time. The surface finish of the original castings is quite smooth and very similar to what I produce, so it may be possible that the original copper plating finish would have been similar as well. This tarnishing process changes the color, but as the pics show, not the sheen. I am considering ways to dull the finish without sacrificing color…
  11. RodStRace
    RodStRace
    Beautiful! I'd guess that the dulling is going to be difficult, considering that those NOS parts were probably stored in the box on a shelf so the typical 'cool, dark place'. Not UV, probably not heat/cool cycles, but more just oxygen or other air g***es over time deepening the oxidation.
    Could also be chemicals involved back then that aren't used or available now, like some stuff in the firearm refinishing arena.
  12. Kevin Pharis
    Kevin Pharis
    from Califunny
    Couldn’t agree with you more! My thoughts of dulling the finish would de to simply remove some of the luster and sparkle, not match the oxidized original. These are the best quality pics of Winfield carbs that I have scrounged up, and both clearly show dark color, but also a bright reflection similar to that of the nearby aluminum castings. Not claiming to know the original recipe, simply in pursuit of a reasonably similar result
  13. j hansen
    j hansen
    About patina,,,found this on the Web.I have no idea if it works!
    Sharpone and porkshop like this.
  14. RodStRace
    RodStRace
    Interesting. I have done the salt and vinegar directly to copper to clean it. I'd guess the vapors with oxygen in the air do the opposite?
    Sharpone, porkshop and lothiandon1940 like this.
  15. Kevin Pharis
    Kevin Pharis
    from Califunny
    Vinegar and salt will produce a green patina, primarily used for artsy fartsy stuff.
    I wish pics would show my results better, it’s almost like black chrome, but with some oil slick swirling of brown and black color. Gonna try a few things this weekend to improve the finish…
    Sharpone, porkshop, dwollam and 2 others like this.
  16. brjnelson
    brjnelson
    Kevin, I truly believe this C downdraft bowl I have is new old stock there’s plating still in the threads and no sign of a float moving inside the bowl.
  17. G Baese
    G Baese
    Winfield S & SR's in various states of copper and non-copper Parts2.jpg Parts3.jpg S:SR_Group.jpg Group1.JPG SR-BD#5899.JPG
    rod1, RodStRace, porkshop and 4 others like this.
  18. Kevin Pharis
    Kevin Pharis
    from Califunny
    Thanks for the pics fellas! Starting to think there were several generations of plating. I went back thru my stash and found that I have 1 kinda rough S bowl that I always thought had been painted with gold spray paint, but a closer look shows the orange colored plating like a few of the sample pictured above. When attempting to polish the orange plating, it requires quite a bit of effort and never really achieves a copper look.
    All other samples with intact plating have the darker brown/black color similar to many samples in the pics above. These polish relatively easily, and reveal a bright copper color with smooth/shiny surface.
    For kicks, I downloaded one of those AI photo colorizing apps
    I put this fuel inlet back in the magic dip for another go, and got what I think is a really solid effort at the brown copper color (which is the color I have been going for). It has a touch of shine, but no sparkle. Now I just have to get the rest of the carb pieces this color…
  19. Sharpone
    Sharpone
    WOW
    Excellent-Most Excellent
    Dan
    porkshop likes this.
  20. Kevin Pharis
    Kevin Pharis
    from Califunny
    This pic posted by @carbking on another thread seemingly shows yet another variation of color on these carbs. Look to be black and shiny! Choke horns are the notorious 45 degree, which I still suspect are simply cut off 90 degree horns. Does anyone have an original 45 degree horn that can share some closeup pics? Curious to see if there are any differences to identify a different casting mold than the 90 degree horns
    rod1 and porkshop like this.
  21. SS327
    SS327
  22. rusty valley
    rusty valley
    Whats that motor, Miller?
  23. j hansen
    j hansen
    From the Web,,
    Skärmavbild 2025-12-12 kl. 08.00.06.png Skärmavbild 2025-12-12 kl. 07.59.56.png
    Deutscher, rod1, fauj and 2 others like this.
  24. Kevin Pharis
    Kevin Pharis
    from Califunny
    Making progress… BIGGER progress!!:D
    Started with S-B a couple years ago, and now making S-C, and S-D size carbs! The bowls and choke horns for the larger sizes were made over the summer, and still working on the last few internal br*** parts. Hope to have one complete and ready to run soon!
    fauj, VI Lonewolf, Deutscher and 19 others like this.
  25. The37Kid
    The37Kid
    WOW! I'm amazed by what a C&C machine can do. You clamp a chunk of aluminum in a vice hit some ****ons and you have a new 100 year old carburetor. Fifty years ago I thought running a Bridgeport was a big deal. Look forward to more progress. Bob
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Not everything is made on CNC machines these days, some things are made the old fashioned way while CNC’s are running. It’s called mul***asking! ;)
    While my machine ran another S-D barrel today, I started making up some float shells for the new carbs. Here is a peek at my very manually operated hydraulic forming press. Start with flat br*** sheet, anneal, stretch, anneal, stretch a little more, anneal, etc…
    Next step will be t******* the “hat” off;
    Then finally some tedious soldering to ***emble;
    fauj, VI Lonewolf, Deutscher and 17 others like this.
  27. The37Kid
    The37Kid
    Very nice! Ed would be pleased, this is one of the few extra Winfield bits I have, sits on the shelf in arms reach of this keyboard.
    Bob
  28. OHV DeLuxe
    OHV DeLuxe
    from Norway
    Ed stated they are bronze plated originally, not copper.
