Technical Early Hemi/Poly question, feasibility of an odd one?
Discussion in 'The Hokey Ass Message Board' started by Ebbsspeed, Nov 27, 2025.
  1. Ebbsspeed
    Ebbsspeed
    I am building a Chrysler 354 Poly motor for a friend, and am having issues with finding a second good head. Out of four, three have failed pressure testing. Evidently there is a thin spot in the castings in the center exhaust ports which is prone to failure.
    The back story: A fellow named Howard had a '34 Plymouth for decades, and reached the age where he was no longer able to build the dream car he wanted. Through a series of what the new owner calls "weird cir***stances", he was given the car. A portmanteau of "weird cir***stances" and "Howard" have become the car's new name. "Howeird". Hence the desire to use unusual components in the build. Very few people will be able to identify the engine at a glance, because it's a small community that will recognize an early Poly.
    So on to the question which would make this even more weird. Given the difficulty of finding good Poly heads vs good Hemi heads (I have Hemi heads laying around) would a Poly head on one bank and Hemi on the other be feasible? The Poly and Hemi blocks are the same, and interchangeable. Heads bolt on, camshafts, lifters, etc. are the same. It would require Hemi pistons on one side and Poly on the other. I need to have custom Poly pistons made anyway, so I could make the compression ratios and piston weight per side very close to the same.
    Weird, eh? Thoughts?
    Or if any of you have some good Poly heads somewhere, preferably in the midwest, hit me up.
    bchctybob and Sharpone like this.
  2. George
    George
    I actually had similar thoughts. I'd put it in a split hood 46-48 Dodge, Take it to the Nationals in Louisville. Have one side hood open one day, the other side the next! Best I can tell thinking about it was balancing the rotating ***embly and weather the cam would work for both heads.. If the hemi & poly pistons weigh about the same it should be able to match them up. No idea on the cam. Intakes interchange so that should be no problem. You didn't say which Poly. Only hemi based polys can be converted, not the "A" Polys.
    Sharpone likes this.
  3. 1952henry
    1952henry
    I am waiting for more information on this. Will be a good read.
    in the mean time, have a great Thanksgiving!
  4. George
    George
    The other answer is just convert it to hemi & call it done.
  5. Is it a Dodge poly or Chrysler? The 31' Chrysler coupe I'm building will have a 57' Chrysler 354 Poly. I have a set of 301 Chrysler poly heads. Don't remember the condition, been years since I looked at them
  6. RodStRace
    RodStRace
    Okay, it's a mental exercise of weird. I get it. But if you are doing stuff just to be different, you gotta stick a Fluid Drive behind it, you know a clutch and hydraulic bellhousing. Oh, and that 2door/4door that was posted? That too. Gotta shove in a Vee drive and a FWD setup. Might as well make it center drive, so it's off for left and right hand drive people. Take the Munstermobile serious and have a solid roof in the middle and a folding top in back. We have had 3 wheelers for almost a century, but most are one axle and a single front or rear. Build it so it's like a bike with a sidecar!
  7. Ebbsspeed
    Ebbsspeed
    1957 354 Chrysler Poly
    Then it wouldn't be weird.
    Chrysler 354. Take a peek at those 301 heads if you can, and let me know if they look reasonable. The fellow I'm building it for is based in Mitchell SD, so Bismark isn't beyond the limits of a one day round trip.
    Tim and Sharpone like this.
  8. DDDenny
    @earlymopar to the white courtesy telephone please!
  9. I can check em out tomorrow or Saturday and let you know
  10. 2deuces64
    2deuces64
    I've seen this done before, a picture here on the Hamb, but I can't find it
  11. tubman
    tubman
    I personally think it's a dumb idea, especially when you have to replace 4 pistons and all the problems that entails. Either find a good poly head or go hemi all the way. Rat Rods have weirdness points, traditional Hot Rods don't.
    57Fury440 likes this.
  12. earlymopar
    earlymopar
    From what I recall the 301 poly heads are not interchangeable to a 354 Poly. Putting hemi heads on the 354 Poly, while achievable will require a piston change.
  13. George
    George
    The '55 Chr 301 Poly heads will work, the '57 301 Plym "A" Poly won't.
  14. George
    George
    That would take a long tail 331 Hemi....
    RodStRace likes this.
  15. earlymopar
    earlymopar
    There ya be then... although I would suspect there are some real combustion chamber compromises
  16. George
    George
    Bore difference is .311 so they might/might not clear, but will bolt on where the 301 "A" poly won't bolt on.
