Projects Timm builds a model A
Discussion in 'The Hokey Ass Message Board' started by Tim, Mar 8, 2016.
  1. Tim
    Tim
    from KCMO
    Almost as reckless as skate boarding, it was figured out that I strained a muscle in my back…. cutting tree branches…. while in the tree.
    Apparently I’ve hit the age that even when nothing goes even remotely badly you still feel like it did.
  2. Tim_with_a_T
    Tim_with_a_T
    To quote the mid 00's movie Hot Rod: "Life is pain, and it's our job to s****e the joy from it."
  3. justabeater37
    justabeater37
    Been fighting killer pain for 7 months. It's hell to get older. Two x-rays, an ultrasound of my carotid, and an MRI later, they tell me my tore up from the floor up disease has finally caught me. Ortho doc says plan on surgeries later as he wouldn't even sugar coat how messed up my neck is. He just flat out called it a mess...Getting old ain't for pussies.
  4. Six Ball
    Six Ball
    from Nevada
    You still have muscles? They will go away too. Get'er done as soon as you can! It don't get better. :(
    porkshop likes this.
  5. Tim
    Tim
    from KCMO
    Alright time for an update.
    IMG_2938.jpeg The car is on the ground. On the suspension. The only jack stands are under the frame rails an inch or so just to put my mind at ease.
    So how did we get here? IMG_2935.jpeg Well after a week I unburied the car from “time out” and took it all apart.
    I could see where I had broke or cut tack welds on the ladder bar cross member and figured it’s as good of place as any to start and just put it back where it was.
    Then I connected the ladder bars to the cross member and rear axle.
    Measure and it’s off a good 3/4”. I have that much adjustment but it would leave me with 3/4” of thread engagement. Not loving that I cut the tack welds - just a little tip here but maybe make sure you can reach those mock up welds with a grinder…. Because I didn’t and it took for eeeeeeeevvver to hand file them off.
    I then twisted the cross member shifting the tabs backwards guesstimating 3/4”. I used some big welding clamps to hold in place and check and it looked good so I buzzed it in.
    I think I had this thing in and out 3-5 times in the last two days. IMG_2936.jpeg time to clean up a little and measure some more. Drivers side seems right and the p***enger is off somewhere in the realm of 1/8-1/4 an inch.
    Measure every which way the ladder bar cross member and found where it pulled. Cut the now better positioned tacks and pushed it in place and zapped it. I didn’t take anything apart for that last tweak. Just rolled the tire forward.
    As a funny aside pre existing marks lined up once I got it in place. Pretty good chance this is where I had it mocked up one of the first times lol.
    IMG_2937.jpeg alright ladder bars connected I removed the wheels and lowered the rear axle to attach the shackles. Figured I was roughly an inch shy from reaching. So I removed the boxing plate and spring mounts and slide the whole thing rear wards around an inch ish. Bolting the shackle in place to make sure everything was inline and not binding.
    Had a slight boxing plate alignment issue and had to clean it all up and zap it back in place again but other than nerves everything seemed to go ok.
    IMG_2934.jpeg so there it is. Take it apart, put it together, take it apart, put it together. I think I have around 10-11 hours in the last few days.
    I still need to adjust the ride height and there’s a few things that I think a thread or two adjustment would pull it 100% spec but everything seems to be 1/16” or closer to exactly right.
    I need to find some good reference points to make sure the car is the same height side to side. Both fenders are in different conditions and mounted both haphazardly so I think when I balance it out maybe I’ll put a level on the bottom of the back window or maybe measure from the belt line? Take some variables away.
    If building these things teaches you anything it’s that if something is off 1/16” it’s going to translate to a lot more 6 ft down the length.
    Plan at the moment is to breath and work on my little model car project the rest of the week. Then I’ll get the springs adjusted to correct height and start on the panhard bar.
    As much as I want to turn the car around and mess with another section the car sure wiggles its **** around a lot with no pan hard or shocks. So I’m gonna just force myself to get it ****oned up.
    redzula, winduptoy, Stu and 12 others like this.
  6. Dubonet Garage
    Dubonet Garage
    from France
    Congratulations, you did it!
    Let's solve the next issues: that's the game and the result will be bad***!
  7. Tim_with_a_T
    Tim_with_a_T
  8. Tim
    Tim
    from KCMO
    Thanks guys, some times you hurt and you're frustrated and everything jist kinda goes sideways. The week off was much needed.
    I’m going to do the pan hard bar and shock mounts next which I believe will require some re working of the bumper irons. So that’s probably the next puzzle I’ll tackle. Shouldn’t be anything to crazy.
    mean while I’m paying attention to what may hit if you really compressed this suspension and good options for bump stops.
    Im currently thinking some tall beehive shaped stops located under the crossmember at the ends. There is a body mount hole in the perfect spot but it’s other wise occupied. Maybe I’ll go right next to it. We shall see
    Thor1, drdave, osage orange and 3 others like this.
  9. RodStRace
    RodStRace
    osage orange, porkshop and Deutscher like this.
  10. Tim
    Tim
    from KCMO
    Hey that’s handy!
    I noticed @Austin kays new set up actually has the bump stop on the axle instead of the frame. Lots of ways to conquer the task :)
  11. True Grit, Tim! You tamed that naughty *******.
    05snopro440 and Tim like this.
  12. Tim
    Tim
    from KCMO
    Little wander in after Thanksgiving dinner and stare at it post. IMG_2999.jpeg Laid the hood back down, sure reads a lot different with it on/shut. Pork n ****** and I were talking about how much heavier the rear wheels look with the steelies. Even though physically the wires with knobbys weigh so much more.
    I need to lift the p***enger side rear just about 3/4” or so. IMG_3001.jpeg With it like this the rake isn’t enough and you start getting a little pro street vibe with the stuffed tires. IMG_3002.jpeg drivers side, again hard to see period but harder to see what I’m talking about in pictures but I’ll try. It’s a little higher and the rake comes back and the car reads less level, less pro street, and more pro stock ready to launch! I think this little rake change also has an effect on how heavy the rest of the car reads heavy or not.
    anyhow I grabbed an exhaust pipe and a model A jack and mocked one up to squint real quick. I have been planning a smaller pipe and maybe black pipes? But thy are there so I gotta hold one up right? Right :)
    IMG_3003.jpeg This is sorta where I’ve been picturing the tips. Maybe a little more towards center but at this position I can run them under the rear axle and straight back with a little upward jog. IMG_3004.jpeg maybe here out wider? I need more hands/ stands to play with ideas. IMG_3005.jpeg IMG_3007.jpeg IMG_3008.jpeg IMG_3009.jpeg gotta say I don’t hate it.
    Also don’t hate how the car looks with a dozen different worn out paints, primers a rust. Kinda reminds me of Blakes 32 from Texas. Sorta. I’ll have to see if I can find a photo of it.
    tempted to drive it rough for a minute first but I really would loath having to take it apart to finish it
    winduptoy, porkshop, cactus1 and 5 others like this.
  13. Tim
    Tim
    from KCMO
    Borrowed snap of Blake’s Tudor. My hood is black and blue as well IMG_3013.jpeg
  14. drdave
    drdave
    I really like how this is coming together. The stance is right on, but I do see what you are saying about the p***enger side rear. I really like the exhaust tips inboard with the license plate as well.
    porkshop and Tim like this.
  15. 05snopro440
    05snopro440
    My vote is outboard, inboard looks too early 00's Street Roddy, but that's just me.
    I get what you're saying about the p***enger ride height, should be an easy change.
    Tim likes this.
  16. Tim
    Tim
    from KCMO
    porkshop and Thor1 like this.
  17. Tim
    Tim
    from KCMO
    I’ve always wanted them under the license plate. I always like it when they sneak pipes over the banjo and under the spring
    that being said it’s more the shiny that I have issue with. There will be nearly zero chrome or shiny trim on the car they kinda stand out in my head when I think bout the finished vision. Not totaly sure if it’s in a good way.
    gonna mock them up on the 46 next for giggles.
  18. Tim
    Tim
    from KCMO
    Just farting around in the shop before heading to work. Thought I’d try a few other ideas real quick. IMG_3043.jpeg IMG_3044.jpeg IMG_3045.jpeg
  19. willymakeit
    willymakeit
    Tim, Im still living thru and stealing ideas from you. Building a T coupe on an A frame so alot of it applies.
    Keep it up
  20. Tim
    Tim
    from KCMO
    Awesome got a thread going yet?
    winduptoy and porkshop like this.
  21. 05snopro440
    05snopro440
    Watching this thread is the reason I got my A in the shop a couple weekends ago (as you know) and have been tinkering on it almost every night. It might only be 30 minutes some days and nothing real huge, but it's something.
    The stance of yours is too good and you're doing a similar suspension setup to me, so I had to see mine start taking shape.
    redzula, winduptoy, pcbart and 4 others like this.
  22. Tim
    Tim
    from KCMO
    That’s awesome man! There have been times when all I could get was 7 minutes a day if I was quick getting out the door to head to work and p***ed through the garage on my way out.
    It adds up. Keep truckin man
    redzula, winduptoy, porkshop and 4 others like this.
  23. Tim
    Tim
    from KCMO
    Little update. It’s cooooooooold. Blah.
    Ok that’s not really an update but it is partially cause for a slowed schedule. I was going to complain that we didn’t have a long fall but I checked my notes and yup, turns out it’s December. Winter. Anyways… IMG_3162.jpeg messed with the car a bit. Raised the p***enger rear 5/8” roughly half a turn of the bolt. If it was any further I would have had to pull the wheels and tires and drop the rear axle. Do a whole little dance to get the weight off the springs. But this little adjustment let me jack up the p***enger frame rail about 3-4” and thenI could get a bit of a turn in with out stressing anything too much.
    Found a good spot to measure the ch***is to the ground on both sides and was able to do it all from inside the car… while standing on the floor. IMG_3164.jpeg IMG_3165.jpeg That done I decided to take a tape to the center line marks I’d made when this started. Just shy of 102” meaning this rake has “shrunk” the wheel base over 1.5” I’m sure if it was level the numbers would be pretty close to stock. IMG_3167.jpeg you may have also noticed the mocked up exhaust tips, I tried 2,4 and 6. I mean I got a pile why not try! These all got mocked up about .2.5-3” from the top of the exhaust to the bottom of the axle tube. Much lower than I’ve mocked stuff up before but I don’t hate it. IMG_3166.jpeg the 24” pipes get chrome all the way past the axle tubes the 48” plus’s mufflers would be nearly full chrome exhaust haha
    Panhard is next.
  24. Bandit Billy
    Bandit Billy
    Don't go too low. I backed the truck into work one morning and just about tore the pipes off on the curb. You can see the one on the left is flat at the bottom. I have straitened it three times so far. It's starting to get thin.
  25. Tim
    Tim
    from KCMO
    Yeah I don’t think it would take much!
    edit: to bend them. Not hit them on this. That *** end is UP. I think the bottom of the front axle is maybe 4-5” off the ground, the back axle is like 15” haha
    05snopro440, Six Ball and porkshop like this.
  26. Tim
    Tim
    from KCMO
    Got the “other” model A done. Figured I’d share since I mentioned it earlier. IMG_3185.jpeg IMG_3184.jpeg
    redzula, Tim_with_a_T, Thor1 and 4 others like this.
  27. 05snopro440
    05snopro440
    Damn that's BA.
  28. Tim
    Tim
    from KCMO
    Thanks :) I think hammering a tiny track nose and hood out of aluminum was harder than doing it full size lol but it was fun
    Six Ball, 05snopro440 and porkshop like this.
  29. 05snopro440
    05snopro440
    I bet! Did you make the rest of the body/ch***is or was it a kit/kits?
  30. Tim
    Tim
    from KCMO
    It’s mostly one kit with some left overs from a few others. But mostly this kit. Every couple of years I pick a kit and get like 5 buddy’s to build the same one with a lose deadline as the only “rule” just to see how everyone builds them completely different.
    This one gives a lot of options as it comes as a 2n1 with two different ch***is, motors and floor pans to make it channeled or not.
    Six Ball, porkshop and 05snopro440 like this.
