Early Ford Suspension & Brakes #2
Discussion in 'Parts For Sale' started by ClutchDumpinDan, Oct 21, 2025.
  1. ClutchDumpinDan
    ClutchDumpinDan
    City: Fredericksburg
    State: Virginia
    Price: Per Item
    PM me for more photos or details.
    1940 Ford car perch pins. For use with factory anti-sway bar. Wire wheeled clean, threads chased. Ready to use.
    $125 shipped for the pair
    Nice straight '37-41 Ford front axle.
    $40 picked up in Fredericksburg VA. Can ship.
    Real nice '37-'41 Ford front wishbone. Still wearing a lot of original black paint.
    $150 picked up in Fredericksburg VA. Can split the wishbone for shipping.
    ***GONE*** 1940 Ford banjo rear in great condition. Rotates smooth by hand. Complete as shown with wishbones, spring, brakes.
    Original 1940 Ford front and rear lever action shocks.
    $100
    Original 1940 Ford front anti-sway bar.
    $100
    ***GONE*** 1940 Ford front leaf spring in nice shape. The one you want to use for the rear in your hot rod.
    Very nice 1940 Ford front crossmember. Rivets drilled out, nothing cut. Can be riveted back into original frame.
    $75
    Ford front backing plates that will fit '37-48 spindles. Originally for '42-48 with the fixed lower mount. $65
    '37-41 Ford roundback spindles.Good threads and bearing surfaces. Have two pairs.
    $125/pr
    '40 Ford front hub. Single. Mounts inside the drum. $45
    '46-'48 Ford outside mount front hubs. The ones used for finned Buick drum conversion.
    $75 for the 3 of them.
    New '28-'31 Model A front spring perches and nuts. Used for mock up, never driven on.
    $100 shipped in the 48 states.
    '37-41 Ford complete front suspension. Disc brake conversion. Split wishbone GM transmission mount. Bolt on upper shock mounts with tube shocks.
    $300 picked up in Fredericksburg Va
  2. ClutchDumpinDan
    ClutchDumpinDan
  3. ClutchDumpinDan
    ClutchDumpinDan
  4. ClutchDumpinDan
    ClutchDumpinDan
  5. ClutchDumpinDan
    ClutchDumpinDan
