Technical Couldn't just braze it for Effs sake??
Discussion in 'The Hokey Ass Message Board' started by Bird man, Nov 28, 2025.
  1. Bird man
    Bird man
    from Milwaukee
    Picked up this great Oil pump core, Flathead Caddy. It's worth a few bucks.
    Started s****ing the barnacles off and saw this.
    Sigh.
    Squablow and chryslerfan55 like this.
  2. Royalshifter
    Royalshifter
    Moderator
    Good ole days just make it work.
  3. Ebbsspeed
    Ebbsspeed
    @Bird man I think I have an extra gear and shaft if you need one.
    winduptoy likes this.
  4. While it's good to see someone messing around with a Flat cad motor, I need more info. Are you building a motor for something? Just asking because I have one in a running car and two on the floor. The two on the floor should be enough to come up with a complete motor with a good block left over. I'll still be short some parts like Flywheel, water pump, dist drive shaft and the tall housing that the shaft runs in and starter.
  5. They we likely nervous about the flux/braze br*** itself coming lose inside the engine
    I have heard for years welding even Oxy-Fuel welding the pick up in a Small Block Chevy oil pump and not brazing for fear of it or the flux coming lose.
  6. winduptoy
    winduptoy
    get out your die grinder and a cutoff wheel....
    tedious but doable to work your way through that goober and miss the shaft
    Mr48chev, alanp561 and Algoma56 like this.
  7. theHIGHLANDER
    theHIGHLANDER
    I want more detail. What was done and why? I'm not totally hip to flat cad oil pumps.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If my Dad had done it you’d be happy. He loved brazing over welding.
    Now I have Barbra Streisand echoing between my ears, Mem'ries…
  9. Bird man
    Bird man
    from Milwaukee
    "get out your die grinder and a cutoff wheel..." Def thought of that.
    "What was done and why?"- Thought of posting in one picture worth a thousand words.
    They didn't want the coupler to come loose & the welder got rather impressive penetration!
    The gears look quite good, wonder if the core is worth saving...
    bchctybob and Algoma56 like this.
  10. RICH B
    RICH B
    Reminds me of a time a while back dumping some iron at the afterhours "donation" dumpster at the s**** dealer; saw four flathead Caddy mills in there; seemed a shame.
    31 Coupe and bchctybob like this.
  11. Ebbsspeed
    Ebbsspeed
    I think what you have is the long geared one with the short shaft. Let me know which one you have for sure and I'll get it shipped to you. Caddy Pump Gears.jpg
  12. Squablow
    Squablow
    Is that from the bus in Antigo? ****s it was welded but I'm pretty jazzed he let us buy **** out of there at all, I'd like to go back again and dig through there deeper.
  13. Bird man
    Bird man
    from Milwaukee
    On those tall gears, it looks like the "coupling collar" might be in da wrong spot?
    1940 Caddy 346.
  14. Ebbsspeed
    Ebbsspeed
    The darker spot is not the coupling collar. It's the area of the shaft that is between the pump housing and the collar, stained because of exposure to crankcase fumes, etc. This ge****t and shaft is from a '46 but should be the same.
    Algoma56 likes this.
  15. Bird man
    Bird man
    from Milwaukee
  16. Bird man
    Bird man
    from Milwaukee
    Ebb set me up with a nice set of gears, no charge! They look very good too.
    I have freshened up some clean, older pumps by lightly buffing the teeth with 800 grit paper on a small stone and they run just fine. It's a great way to check for burs & damage, you can really see the diff between the working side & the coasting side of the teeth.
    See what you think. Now I just gotta find the pump o_O
    Thanks Ebb!
    Squablow, Deutscher, mike1951 and 2 others like this.
  17. Doublepumper
    Doublepumper
    from OR-WA, USA
  18. Ebbsspeed
    Ebbsspeed
    Glad they got to you OK, hope they work out.
    fordor and Squablow like this.
  19. Bird man
    Bird man
    from Milwaukee
    Finally got this pump back together, who knew that linoleum was harder than an oil pump gear? Had to buff off a small burr. Sanded the pump plate & bottoms of gears on a slab of gl*** w/ 600 grit.
    Kinda the****utic
    Ready to run :)
  20. Ebbsspeed
    Ebbsspeed
    Glad that ge****t fit, good luck with it.
    RodStRace likes this.
