1940 ford deluxe hood hinges . Been taken apart and cleaned will need new rivets. $60 Cylinder ridge reamer $50 Heater. Motor works. Was not leaking when pulled. Has been out in the shed a few years. $40 New fox body mustang aluminum quadrant and cable $60 Horn ****on with rod 44 inches long. Have no idea what make or model it’s from $100 Steering column outer with a bit of damage. Not sure what year or model it’s from. 45.5 inches long X 1.5 inches OD $40 Prices are + shipping. Local pickup ok I took a wag at some of the prices so if I am off you can correct me up or down. Parts are better off at your house getting used not at mine collecting dust.
more stuff speedway flathead V8 engine gasket set 910-15948. Got this for a build that never got done. Package was opened to look at the head gaskets. $75 New set of pistons +40 for a 239 flathead. Box was opened and pistons weighed. Sealed Power 1003P40 Ford 46-53 239 V8 Flat Head $200
Holley /ford 3 Holley 94 carburetors with ford script. Ready for rebuilding. $40 each or $100 for all 3 + shipping
