1932 ford sedan, nice original car. I would guess that it was painted back in the 60s. It has a good running flathead v8 (59AB) 2x2 intake from gear drive with two Stromberg 97s. Original Navarro heads, Fenton headers, electronic ignition,12v negative ground, 39 ford trans, original banjo rear, newer tires, 40 wheels, juice brakes, electric fan, 3.78 ratio. I’ve had this car on numerous multi hour trips with zero issues. I have the original sales receipt for this car in 32 from Washington DC. The car is located in Wytheville Virginia near i77/i81 split. Call Jeff 2766135508
