Technical Water boiling
Discussion in 'The Hokey Ass Message Board' started by memphis66, Dec 5, 2025.
  1. memphis66
    memphis66
    from Italy
    Hello everybody, I'v been ownin' a 1954 Chevy Bel-Air, over here in Italy for almost 40 years now.
    Lately water/liquid started to boil. I checked the thermostat, but it was ok. I even tried without thermistat, but water kepr boling.
    So, I was enough sure somethin' happened to the head gasket. I went to my local car repair shop: they checked the head..and the mechanical test said the head was ok. Anyway they rectified it and they're goin' to put a new gasket on, of course.
    Now, do you think this boiling is caused by a failing water pump ? Or radiator ?...
    Any idea ? I never had water boling problems at all. Thanks so much for your help. Alberto
  2. Oneball
    Oneball
    By boiling do you mean it’s overflowing? What does the temperature gauge read?
    could be as simple as a the radiator cap
    when it’s hot feel different parts of the radiator, are there cold spots?
  3. memphis66
    memphis66
    from Italy
    Yes, it's overflowing. Unluckily my temperature gaude doesn't work....so I don't know.
    Now the radiator is apart...
  4. memphis66
    memphis66
    from Italy
    I think I am goin' to redone the radiator core...what do you think about it ?
  5. memphis66
    memphis66
    from Italy
  6. Budget36
    Budget36
    Did the shop remove the head? I don’t know of another way to check it for cracks other than removing it.
    Do you have the car at home now? And have you removed the radiator? I ***ume that’s what you mean by “have the radiator apart”.
    And it still boiled over with the thermostat removed? Okay, put the radiator back in, keep the thermostat out, fill with water and fire it up and let it run with the radiator cap off, see if any bubbles are forming through the fill hole.
    Are any of the spark plugs noticeably cleaner that the others? If so, this would indicate that cylinder is getting water/coolant in it and “steam cleaning” the spark plugs
    ClayMart and alanp561 like this.
  7. memphis66
    memphis66
    from Italy
    Yes, the head and radiator were (are) removed.
    I am goin to check if the radiator is ok.
    Will check the spark plugs.
    Thanks for the advice.
  8. 302GMC
    302GMC
    from Idaho
    Long as the radiator is out, pull the pump & make sure the impeller hasn't started to spin on the shaft. It happened to me once with a ''rebuilt" pump ...
    tractorguy and alanp561 like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    While you have the radiator out take it to a radiator shop and have it flushed out to make sure it isn't clogged up. HRP
  10. ClayMart
    ClayMart
    Do you have easy access to any of the core plugs in the side of the engine block? Removing a plug may tell you if the coolant p***ages in the block are plugged with rust or scale. Also check your ignition timing. If it's retarded too far it will make the engine temperature increase. Getting a working temp. gauge would also be a big help for troubleshooting.
    memphis66 likes this.
  11. memphis66
    memphis66
    from Italy
    Ok..thanks for the advice.
  12. memphis66
    memphis66
    from Italy
    Yes, thanks. I just planned this. Thanks.
  13. ClayMart
    ClayMart
    For that matter, is the belt properly tensioned?
    o_O
  14. Good golly, miss molly! Get the temperature gauge working! If it had been working you would have seen the coolant temperatures rising over time. The radiator is probably at least partially plugged. Since it is off, have it rodded out. Or a new core. Afterv40 years [ good for you ] a new one would not hurt.
    Ben
    tractorguy, ffr1222k and memphis66 like this.
  15. memphis66
    memphis66
    from Italy
    Thanks. I am goin to check everythin I can. Thanks
  16. memphis66
    memphis66
    from Italy
    Yes, I would say it is.
  17. memphis66
    memphis66
    from Italy
    I know..you're right..
    I am goin to have it working.
  18. BJR
    BJR
    I bought a car once really cheap, because the owner said it overheated and would boil over. I put a new radiator cap on it and never had an issue after that.
    Black_Sheep and memphis66 like this.
  19. memphis66
    memphis66
    from Italy
    How can it change so much, puttin a new radiator cap ?
    BJR likes this.
  20. gene-koning
    gene-koning
    The radiator cap has a spring in it to put pressure on the cooling system, that raises the boiling point of the water. There is also a rubber seal to seal off the opening under the cap.
    If either the spring or the rubber seal are bad, a new radiator cap could fix your problem.
    The radiator shop can test your cap as well as test your radiator. Both the cap and the radiator need to hold the pressure.
    The Shift Wizard, BJR and memphis66 like this.
  21. twenty8
    twenty8
    ..... and this should have been the starting point to solve the problem. Easy and cheap things first.
    My daughter's mechanic wanted to replace the EGR on her Toyota Prado because it was losing coolant but there was no sign of a leak. She was quoted a couple of grand to do the job. On my advice, she took it to my mechanic for a second opinion. New radiator cap, problem solved. Needless to say, my mechanic is now also her mechanic.
    memphis66 and BJR like this.
  22. Bandit Billy
    Bandit Billy
    Lots of reasons.
    Wrong cap is one. A lot of older cars require a deeper cap. Below is a comparison of a new vs older model. If you use the new cap on an old radiator, it will fit but inside the seal won't hit the throat in the radiator, so it won't build pressure. For every pound of pressure (over atmospheric pressure), the boiling point is increased by 3 degrees. So, a 4-pound cap makes the system 12 degrees cooler compared to running at ambient pressure (or a cap that has worn out seals). New cars have 17 pound caps or more, but they're radiators/heater cores/hoses and the like are designed for that kind of pressure. If you put a 17 pound cap on a flathead (for example), you will be replacing the radiator, the heater core, and likely the water pumps very soon.
    BJR and twenty8 like this.
  23. Mr48chev
    I don't know how long you have owned the car but cars with top tank radiators have to have air space above the coolant for expansion or they will push coolant out the overflow. That is a common new guy to old style radiator mistake when adding coolant/water. you want about 1 inch = 25 mm of coolant above the top of the tubes cold and not more than that. Otherwise it will puke coolant out until it finds it's own level every time.
  24. Certainly NOT a new guy. 40 years he said.
    It COULD be the cap. I have had a couple fail in 70=years. But that inoperative temp gauge is/was BAD!
    Ben
  25. Mr48chev
    I'd go with the bad cap thing but one has to remember that a stock cap for a 54 is 4 lbs. high pressure cap is 7 lbs. The GM heritage center vehicle information kit for 54 chevy doesn't give radiator cap pressure though. 1954-Chevrolet.pdf Screenshot (2130).png
  26. memphis66
    memphis66
    from Italy
    Thanks so much for your advices. My radiator cap has no spring at all. It's a simple cap. It was always like that, but I never had overflowing problems before now...
  27. memphis66
    memphis66
    from Italy
    My radiator cap is without spring at all. Only a 'simple' cap.
  28. memphis66
    memphis66
    from Italy
    Yes...you're completely right. I never went for the operative temp. gauge, 'cause I never had overflowing problems.... But you' right, of course ! :(
  29. memphis66
    memphis66
    from Italy
    So I am goin to buy a new radiator cap...
  30. memphis66
    memphis66
    from Italy
    "40 years he said."..I made a mistake: not 40, but 30 years anyway... I bought my Chevy in 1998.
    firstinsteele likes this.
