Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. Zak Hall
    Zak Hall
    IMG_0450.jpeg 77179932921__9954ABB8-8A45-453F-A887-4EC6E0D38542.jpeg IMG_3910.jpeg IMG_3909.jpeg IMG_0423.jpeg att.7awHq2MmVtzN_28hGq1ebyx-mt-R1mAUt3WyLNWqaGw.jpeg att.rxKRXle7NnCh6bPKRCTUwjXCAa0VY2qnN7KV8vjuDKA.jpeg IMG_0277.jpeg att.d6AqdlxcHL0E9rkHPludQOsievvLHYNzuYNe9qDqJhw.jpeg Been tinkering with the ramp truck.
    Got it lettered up today, and it’s going to look killer going down the road.
    Also started tearing down the 400 and getting it ready for cam/heads/intake. It’s getting a small rv cam and ditching the smog 882s and putting a set of double hump heads on it to help with compression and performance. Going to swap it and the 400 turbo into the old truck here this winter.
  2. Zak Hall
    Zak Hall
    Made some p***es, car ran great in the heat testing, and the ramp truck is just my favorite thing ever. Lol IMG_0998.jpeg IMG_0942.jpeg IMG_0944.jpeg IMG_1017.jpeg IMG_1015.jpeg
  3. AmishMike
    AmishMike
    Getting consistent times. Good light when don’t red ( smile )
  4. Zak Hall
    Zak Hall
    A few pics from this past weekend, last bracket race of the year at Bristol, going to try to make a few changes and make some more p***es in a few weeks and see if I can find the tree and maybe find some et too. IMG_2255.jpeg IMG_2254.jpeg IMG_2245.jpeg IMG_2233.jpeg IMG_2236.jpeg IMG_2238.jpeg IMG_2237.jpeg IMG_2230.jpeg
    Outback, Deuces, Chucky and 23 others like this.
  5. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Nice indeed.
    Zak Hall and enloe like this.
  6. Grumpy ole A
    Grumpy ole A
    Looking good
  7. Zak Hall
    Zak Hall
    IMG_5281.jpeg IMG_5282.jpeg IMG_5284.jpeg IMG_5285.jpeg IMG_5286.jpeg IMG_5287.jpeg IMG_5288.jpeg IMG_5289.jpeg Spent the past few weeks working on the tow rig, getting it updated and ready for 2026.
    Removed the dog turd 305 v6 and NP435 that was worn out, and swapped in the 400 small block that I’d reworked, with 186 heads, RV cam, and aluminum intake and Holley 600. Also added gauges so I know what’s going on while driving down the road. Has long tube headers, and some exhaust we made up in the shop, just 2.5” duals with china flowmasters and turn outs, but it’s really pretty quiet in the cabin and has a ton more power than the 305 v6 had.
    Still have a few small things to ****on up on the wiring, and clean and paint the engine bay (couldn’t get the truck in and out of the shop to clean it with no engine/transmission/clutch/ or brakes) but it’s pretty cherry now. I want to redo the seat, and find a taller geared rear end but other than that the truck is perfect. It’s 7.20 rear gear in high range right now so the cruise speed is about 3700rpm at 60mph. 5.86 gear rear end would be optimal with the 40” tires that this truck uses.
  8. ididntdoit1960
    ididntdoit1960
    from Western MA
    Looks great - living the dream - don't s**** that NP435 - the off roaders love 'em
  9. Zak Hall
    Zak Hall
    I sold it and the 305 v6 for a couple hundred dollars and sent that stuff down the road to someone that can hopefully use it.
  10. benchseat4speed
    benchseat4speed
    from Golden, CO
    Right on Zach! Did you put a SM420 back in it am I seeing that correctly?
    Zak Hall, porkshop and bobss396 like this.
  11. Zak Hall
    Zak Hall
    Yes I did put an sm420 in it.
  12. 6sally6
    6sally6
    Zak.. Old HomeGrown still look'in good ! I've seen you guys a few times at the SEGA races..
    Ya got any more "details" on the Carolina Pushrodz ?!!
    Places they race?
    How many race cars?
    As organized as SEGA ?
    Locations of their races ?
    Are they mainly in the Carolinas ?
    So many questions...so little time !!
    Thx
    6sally6
    Outback, Zak Hall and porkshop like this.
  13. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Look for a brown light secondary trans. It has under /1to1 / and over drive. And there are many versions. There was a 62 lcf gmc here in town that actually had two brown lites behind a Clark 5 speed. ( 5 speed wasn’t an over drive).
    Is it a square tube Eaton rear or other? Look for some of the older logging /big truck wrecking yards. You’d be surprised how cheaply older bigger rear ends go for because the modern stuff is the big ticket fast mover. I’ve got a Hollander exchange book from that era. Depending on housing there are actually a lot of options.
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    And the guy running the cherry picker with that heavy jimmy V6 fully extended is my hero. That hoist must be a hoss.
    Used to be a lot of tips on drive lines on GMC 6066 Guy also
    Outback and Zak Hall like this.
  15. Zak Hall
    Zak Hall
    We are having a racers meeting at the end of January to get an idea of what all the 2026 Pushrodz season will entail. It’s just a group of mainly western NC and NE Tennessee racers, there’s currently probably 20 or so, and it’s all split on et, and it is dial in bracket racing, but bunched for closer racing, and it is still pro tree.
    it’s not quite as organized as Sega, and definitely a whole different deal. It’s more along the lines of “fun runs” albeit there is a winner with a trophy and cash payouts, it’s more laid back and about hanging out and making p***es. Kind of like early unorganized sega in the 2014-16 era.
    hopefully we’ll have about 4-6 races scheduled for 2026, probably in North Carolina and maybe a couple in South Carolina and maybe one in Tennessee.
    Thor1, loudbang and 427 sleeper like this.
  16. Zak Hall
    Zak Hall
    For an overdrive option I’m planning eventually to go to a nv4500 or even an nv3500.
    but if I could like you said find a rear end or even center section with a 6.20 or 5.80 range gear I wouldn’t even need OD. I’ll have to figure out what exactly is in the truck and get with you on decoding and cross referencing because medium duty trucks was nothing I was knowledgeable about, before I got this ramp truck. lol
    Outback and 427 sleeper like this.
  17. Zak Hall
    Zak Hall
    It tweaked the hoist it’s not quite right anymore haha. That thing was definitely twice as heavy as the 400 small block. lol
  18. 6sally6
    6sally6
    I'll be on the look out !!!
    6sally6
    Outback and klleetrucking like this.
  19. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I have a pretty good Hollander listing. Find the casting in your chunck and then we can see. Might be just as cheap to get the whole Rearend. The older stuff usually gets s****ped if it doesn’t move pretty fast these days( meaning rearends etc. )meaning it goes cheap. As in 2-400$ for the whole Rearend
  20. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I’ve seen 5/10 lug/and 6 lug. But if the chunck is swapped only not an issue. Don’t forget that some of the big Chevrolets and even Ford etc run the same style etc axles.
    Outback, Zak Hall and loudbang like this.
  21. Zak Hall
    Zak Hall
    IMG_6409.jpeg IMG_6407.jpeg IMG_6497.png Gave the engine bay a quick spray down rinse, and put some satin black paint down to just freshen it up a bit without getting carried away, it’s still just a tow rig…
    Also got a working fuel gauge now too. May possibly put a transfer tank in the bed at a later date to add range between fill ups for trips too.
    Also picked up a 650 double pumper for it, with a mechanical choke. Just can’t get the single line 600 to run right, something is funky with the idle circuit, it runs good everywhere but at idle. Going to swap the carbs out this week, and then other than some bed marker lights, and rebuilding the winch brakes, the ramp truck is finished.
  22. Zak Hall
    Zak Hall
    Yeah I will see what I have, I’d like to swap centers if at all possible, as the 6 lug setup is a lot harder to find used and I’m kind of stuck 6 lug, I don’t want to have to carry two different giant spares when I travel. lol. And also all of my brakes work well I’d rather not get into more brake work on another old housing of if I swapped rear ends.
    427 sleeper and Outback like this.
  23. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I totally get that. Especially with the brakes working. Those trucks were known to have brake issues if not maintained or they sat up a long time. Again I get it.
  24. DDDenny
    Meanwhile back to the 55!
    Zak Hall likes this.
  25. Zak Hall
    Zak Hall
    Yep got the trans out freshening up the power glide and putting a new trans brake valve body in it. Hoping to run some personal bests again this year!
  26. Zak Hall
    Zak Hall
    IMG_6407.jpeg IMG_6699.jpeg IMG_7019.jpeg IMG_7022.jpeg IMG_7024.jpeg IMG_7038.jpeg IMG_7039.jpeg Covered the old seat in the ramp truck tonight, Not a Perfect job, but my first time so I was definitely learning as I went. Been ****oning up a few more things on it as I’ve been driving it a little. Has a few leaks to solve, and I have got to get some overdrive in this thing, it just screams down the road even in high range, 4000 rpm to run 65 mph. I have a line on an nv3500 I’m probably going to scoop up, and cut my rpm at cruise speed by 1000rpm.
    otherwise the new motor isrunning well and I think with overdrive we will be able to maybe even tickle 10mpg.
    enloe, SilverJimmy, bobss396 and 3 others like this.
  27. 427 sleeper
    427 sleeper
    The NV3500's are pretty light duty for what you're doing with it. You might be better off with an early 90's era NV4500, if you can hunt one down. They have a Granny 1st. gear and an overdrive 5th, and much heavier duty.
  28. I have a NV4500 here with clutch, bellhousing, shifter, slave cyl, etc that I know is good, because I took it out of my own truck! Was going to keep it "in stock" for a future project, but the older I get the more I realize I'll never get to all the projects in my mind.:p
    If the O.P. is interested, he can contact me in a P.M.
    God Bless
    Bill
    https://www.jalopyjournal.com/forum...ar-transport-hauling-open-or-enclosed.614419/
  29. Zak Hall
    Zak Hall
    This truck loaded is barely more weight than a standard 1500 Silverado pulling an open trailer with a normal 3500lb street car,
    And the sm420 bulldog 4 speed is factory rated at 285ft on of torque, the nv3500 is rated at 300-340ft lb depending on spline count and version.
    The nv4500 is undoubtedly a stronger transmission and the lower gear would be beneficial, but that trans came behind ***mins trucks, so definitely more powerful than a fish piston 400. And I also have the 2 speed rear end, which in high range is the pickup tire size equivalent to a 5.57 rear gear, and in low range, is the equivalent to a 6.50. So I can crawl around if needed and even in high range, am not really loading the transmission as much as even a 2005 Silverado 5.3 5 speed stock truck.
    The other reason is cost, nv4500 prices are 1000-1800$ for a GM 2wd now and that’s just more than I am really looking to spend. lol
    If I was planning on doing any kind of heavy hauling closer to the gvwr of the ch***is I’d probably go with a stouter trans, but I’d also be concerned about the cast crankshaft in the 400 snapping.
