GM Camel Hump Heads (492) & Chevy 355 With TRW L2252A Pistons De-Tuning Queston
Discussion in 'Off Topic Hot Rods & Customs' started by MoreHPplease, Dec 4, 2025.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Took way too long to look up suffix # ending HW so I didn’t breaking down the forwarding numbers. Casting number say’s either 1969 327 or 350. Suffix HW say’s factory 350 HP 350 cid 4 Barrel 4 Speed.
    MoreHPplease likes this.
  2. MoreHPplease
    MoreHPplease
    Wow, I would have never thought that what you mentioned above with regards to milling the piston domes down was even possible. Wouldn't that compromise the strength of the pistons. Of course that would only apply to the pistons if the domes are not solid, but then you would have to keep a very careful eye on what the actual weight of each piston after the machining to keep them all within an acceptable + or - finished weight.
    Doesn't seem like a very practical approach unless you have your own lathe or access to one where the milling could be done very cheap.
    I think in my case of having those KB pistons for a swap would be a more prudent approach.
    I think I will look into the cylinder head swapping approach you mentioned by investigating the 76cc heads available which will make things a little complicated.
  3. MoreHPplease
    MoreHPplease
    Johnny, I'm told this engine was the actual factory SBC 350 that was in the 1970 Chevelle my relative owned.
    I believe he bought that car new from the dealer and it had the factory 4-speed transmission. I have the transmission, with the bell housing, a aftermarket Lakewood ****ter shield, Z-bar, pedals and Hurst shifter with the linkage.
    Do you have any opinion on the bore scope picture showing the cylinder wall and the top part where theirs clearly an area where the piston isn't making it way up to the very top of the deck.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    If you mean has the block been decked? You’ve been looking at the answer all along. IMG_5048.jpeg
    MoreHPplease and Budget36 like this.
  5. jaracer
    jaracer
    I used to mill the TRW forged pistons I ran in the race car. Never had a problem with a piston being weak.
  6. Budget36
    Budget36
    Johnny pointed it out, so not decked, which works in your favor if you move forward to lower the static CR.
    edit: I meant to add about you CR #’s you posted with the KB pistons, because I didn’t see it mentioned.
    Some after market manufacturers post the numbers with the block zero decked.
    So what you need to do is find out the piston volume, plug in .025 (should be close enough) for them down in the cylinder, then add the head gasket, and head chamber volume.
    You also need to know the wrist pin height of those pistons, as many come .020? Different in height which moves the top of the piston further down into the cylinder.
  7. MoreHPplease
    MoreHPplease
    Yes, I was aware that having the block decked usually means that the stamping on the block can get removed, but it's not always the case if the machine shop just skims the deck a few thousandths to just clean it up and remove any light warping.
    But yes you verified what I was referencing.
  8. MoreHPplease
    MoreHPplease
    Gotcha you.
    I was just looking at some aftermarket heads to get a bigger combustion chamber size and I'm finding that a pair of complete heads are far more pricey than swapping out the pistons.
    So to me, having the pistons sitting below the deck, as you pointed out, and roughly around .025 is a something that works in favor of doing a dished piston swap.
    The pistons you are referring too being .020 wrist pin height are the TRW's in the holes or the Kieth Black 9002HC hypereutectic 2-valve relief flat top pistons that are 0.30 thousandths that I was talking about swapping into the block?
    I know someone pointed out that the TRW pistons are forged while the KB pistons are cast and are a tighter fitting pistons.
  9. Fordors
    Fordors
    The 350, 350 horse engine was only optional in Corvettes in 1969. There were two suffix codes for that engine, HW and HX, I have a HW short block in the garage. The HX code engines came in an air conditioned car.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Now you did it!
    19Eddy30 likes this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    Moved to the off topic forum
    Johnny Gee likes this.
  12. jaw22w
    jaw22w
    from Indiana
    Forged pistons usually require about .005" piston to wall clearance. Those KB's will require only .0015" clearance. Your KB pistons would flop around in the loose bore terribly.
    Won't work. Too bad though. I have KB's in a 355 for 10.31:1CR. It runs on 89 octane with no detonation. They are aluminum 64cc heads.
    Tickety Boo and MoreHPplease like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    About time. This is killing me.
    SS327, lumpy 63 and Moriarity like this.
  14. swade41
    swade41
    from Buffalo,NY
    I used KB hypers once, never again for me, I know some people love them but they came apart on my Henry J's first engine. This engine had about 200 street miles and 4.5 1/8 miles p***es shifting at 5,000 rpm, next engine got forged pistons.
    TA DAD and SS327 like this.
  15. Deuces
    Deuces
    Ouch!......
  16. Deuces
    Deuces
    Those 386 blocks were also used on 1969 Z/28s along with 4 other different block casting numbers which included the 010 block.... 1 er 2 different block casting numbers were made with more nickle (sp) for extra strength.....
  17. 1biggun
    1biggun
    Many TRW pistons can not be milled down and you need to mill a bunch.
    Then your balance will be off.
    A set of heads of a 400 SBC wpuld be dirt cheap and larger chambers and have seats that would work with unleaded gas .
    Also if you want to keep angle plug heads be sure your headers or exhaust manifolds work with them .
    Deuces, Tickety Boo and MoreHPplease like this.
  18. MoreHPplease
    MoreHPplease
    Well I talked to a close friend of my relative who were friends from the 5th grade and he’s emphatic on the fact that engine was original to his 70 Chevelle. He claims that engine was pulled out of the car around 1976 or 77 when he had the opportunity to get a BBC 427 7.0L from someone who was getting married and needed the money (lol).
    I have that engine too, but it’s got issues and needs a new crankshaft and complete rebuild. I’m actually working with a guy from NY who is supposed to come get it after the holidays in the beginning of next year.
    But on the other hand I’ve sort of narrowed down on what I think is going to be the direction of this 355 ci engine.
    Spoke to a tech at DSS racing in Illinois and hey believes I could swap in these forged pistons in with good results using the 462 heads.
    Of course the wild card is going to be the camshaft since I don’t have any information on its specs.
    8702-4030 350 Small Block Chevy E Series -8cc Flat Top SBC 23 Degree Forged Piston Set 4.030 inch bore Pin Dia.: 0.927" Comp Height: 1.56"
    Regular price $409.95
    Deuces and Tickety Boo like this.
  19. Fordors
    Fordors
    Your relative apparently had a friend in the Chevrolet corporate offices and was able to get a COPO Chevelle that was one of one.
  20. MoreHPplease
    MoreHPplease
    Honestly, I don't really know what is the true origins of this block, but as someone stated a few post back that the block stamping indicates a 69 year manufacturing date code.
    If that poster could provide the resources on where he obtained that information regarding the engines year of manufacturing that would be helpful. Is it possible that my relative also got that block from another 1969 Chevrolet car and did an engine swap? Possibly, because he was a lifelong Chevy guy who had been building and drag racing street cars from the time he was a teenager in the early 1960's.
    I do know that he had recently sold his mint 1995 very low mileage ZR1 Corvette that was his pride and joy around 4 years ago to my cousin when he was first diagnosed with prostate cancer.
    But anyways, does anybody here have any thoughts on the DSS pistons I'm considering for that 355 engine. The company seems to have a good reputation on their products build quality but I'm just curious if there are any other brands of pistons that would be a suitable choice.
    Will the -8 cc flat tops be okay compression wise to run on pump gas with the 64 cc heads or should I play it safe with -13 cc dished pistons?
    I've used a compression calculator, but I'm not sure that I'm inputting the information correctly when it comes to the piston volume. I'm using this one here----> https://www.powernationtv.com/calculators/compression-calculatorng
    The DSS pistons above with rings and wrist pin retainers can be had for around $500 shipped.
    SS327 likes this.
  21. DDDenny
  22. MoreHPplease
    MoreHPplease
    Gotcha.
    This is why I’m asking for what some of you more experienced guys opinions are.
    Obviously there will be differences on the subject matter of piston makers, and quality, but I’m just trying to limit my chances of making a bad choice.
    You guys already gave me some solid advice on why I should not be going with the SBC cast hypertectic pistons for a swap.
    DSS racing has a pretty good selection of 4.030 pistons for a 355 ci engine. But the problem I’m trying to solve is what is going to work best with 462 heads on the street and not having to use race gas as it’s not in the cards for where this engine will be going.
  23. 1biggun
    1biggun
    hypertectic pistions are fine in applications well over 450 hp and better than the originals cast pistons in 98% of SBC ever built. Then there are about every LS built using hypertectic pistions were guys are making well over 600 HP with ease .thousand of local level stock car racer using hypertectic pistons in claimer cl***es or in most flat top pistion rules cl***es.
    Unless your planning on 200hp shots of nitrous, boost, 8000 rpm operation there going to be fine . More than enough for the 375 HP or so your going to make with those heads in a 9.5-1 or so compression ratio 350 with any sort of street cam .
    Forged pistons require more pistion clearance, weigh more, require a longer warm up time and cost a lot more .
    Before you start considering pistions as far as dished, two, or 4 eyebrow id recommend pulling the heads off and see if they have been milled and how much .
    Id see if they have hardened seats installed so you can run unleaded gas.
    If not id figure on having it done .
    Id weigh the old TRW pistions in it and see what the new pistions your looking at weigh .
    Needs to be close or your going to want to rebalance.
    4 eyebrow flat top pistons depending how deep there in the hole , gasket thickness and actual chamber of 64cc will get you somewhere between 9-1 and 10-1.
    Id avoid thin steel shim gaskets on a used deck and be prepared that you may need to mill the heads or the block or both .
    $500 for pistons, figure $50 for rings, $300ish to re balance to do it right, cost to up date heads ?? ( maybe $600) better add another $100 for bearings while its apart
    You can get at or over the cost of a new set of aluminum heads with bigger chambers into this and got slower than with the heads you have.
  24. Back in the late 80's I had a friend with a 327 with the same cir***stance. He brought the pistons to me and I clamped them in a piston vise I made and milled the domes a bunch. no rebalance, no rering, nothing extra. It was able to run a regular gas after that with a Comp cams high energy 268 cam.
    Because the dome thickness is very substantial on those pistons, they still has more than 3/16" thickness. End of problem.
    MoreHPplease, Tickety Boo and 6sally6 like this.
  25. 6sally6
    6sally6
    For goodness sake man !!
    Pull the front cover off the engine and check the numbers stamped on the cam...
    It may have an adjustable cam gear..... I would try retarding the cam a few degrees (6-8) to maybe calm it down enough to run as is. With a manual ****** you can prevent the engine from lugging down unlike an A/T which gives YOU no control.
    Take a good look...see what you're working with...then ask for suggestion. You're only talking about replacing a couple of gaskets (if you use gaskets...which I don't...)
    6sally6
    MoreHPplease and 427 sleeper like this.
  26. swade41
    swade41
    from Buffalo,NY
    On the second engine (after that hyper blow up) in my Henry J, I used ICON forged pistons and those worked great shifting at 6200 rpm.
    Your engine sounds similar to my engine with the Offenhauser intake and the 600 Carters. It's a 355 with 2.02 valve 462's or 461's (I forget which) 510 lift solid lifter and use 93 octane pump gas
    Deuces and MoreHPplease like this.
  27. 19Eddy30
    19Eddy30
    from VA
    Just posting If not seen , something information not available or not able find easily. Another older catalog I have.
    Tickety Boo and Deuces like this.
  28. MoreHPplease
    MoreHPplease
    That's a great solution WFO.
    I would have never thought that was even a possibility, but if the domes are solid and milled exactly the same through out the milling process then I can definitely see that how that would be a great solution as long as every piston is marked and goes back to the same hole they came out of.
    I will keep that in mind, but I don't know if there's a qualified machine shop in my neck of the woods who could do that kind of technical machine shop work.
  29. MoreHPplease
    MoreHPplease
    You are %100 correct. I'm going to be doing that and dropping the oil pan real soon in order to really understand what was actually done to this engine build wise. I do know that the oil pan was also modified for what I think is a high volume oil pump and most likely a larger fill capacity.
  30. MoreHPplease
    MoreHPplease
    Swade, that is one sweet ride. We don't get to see builds like that very often around here even at the local car shows as everybody wants all the modern vehicles with the techno conveniences.
    swade41 likes this.
