Technical What modern car has an electric/vacuum switch?
Discussion in 'The Hokey Ass Message Board' started by BJR, Dec 8, 2025.
  1. BJR
    BJR
    I have a 49 Buick, and a 50 Olds 88. Both used vacuum operated windshield squirters. I want to use the stock dash control, which is just an on off vacuum switch. Push the ****on you get vacuum at the other port. I need to find an electric/vacuum switch, that when vacuum is applied to it, it closes an electrical contact. I will use this to run a modern electric squirter pump. Hope this makes sense. Now all I need is the vacuum switch. Any suggestions?
    Kerrynzl and Bandit Billy like this.
  2. Kevin Ardinger
    Kevin Ardinger
    IMG_2647.jpeg Any kind of solenoid valve should work. Just need to make sure it’s normally closed.
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Just Google vacuume switch. Lots of options.
    VANDENPLAS likes this.
  4. 24riverview
    24riverview
  5. MARKDTN
    MARKDTN
  6. vintage6t
    vintage6t
    from CT
    If you can't find one, I would think you could build an ***embly from a distributor vacuum advance unit and a universal motorcycle rear brake light switch. Just have the advance unit pull the brake switch closed.
    Really any automotive vacuum actuator can be used to pull the switch. Like from a heater box or similar.
  7. FrozenMerc
    FrozenMerc
    1980's Ford F-Series. I.E. Bullnose trucks....
    They had all the vacuum bits... Although at 40+ years old, "modern" may not quite be the correct term....
  8. rockable
    rockable
  9. Bandit Billy
    Bandit Billy
    All you need is an air switch like is used around water in your home. Garbage disposals to hot tub jets, they are just air switches that activate electric motors. I have air switches on my 442 to control the clicks on my QA-1 shocks so I don't have to crawl under it. They seem to never wear out.
  10. I remember lots of cars in the 80's had vacuum operated everything, there were vac switches under the hood in a few places.. If it has 2 terminals and a vac. port, bring your multimeter and lungs to the wreckers and try them out.
    BJR likes this.
  11. okiedokie
    okiedokie
    from Ok
    I would love to see how you did this in the Off topic.
    Jrs50 likes this.
  12. vintage6t
    vintage6t
    from CT
    I'm curious, does an air switch work on positive pressure? If so, that seems to be the opposite of a vacuum operated switch the OP is asking about.
    BJR likes this.
  13. rockable
    rockable
    Yes. It won't work. If it worked, it would work backwards. A vacuum switch, generally, requires more surface area because of the low pressure. It also needs to be 100% sealed so you dont have a vacuum leak. That is why they use diaphragms on vacuum operated switches, actuatos, etc.
    BJR and vintage6t like this.
  14. Bandit Billy
    Bandit Billy
    No, I didn't mean just use the ****on but the electrical switch to which it is attached in order to power on and off the wipers. Personally, I would just stick an electric switch in the dash and put the original knob back on it, who cares if it pushes or turns? It will look correct.
    seb fontana and rockable like this.
  15. nochop
    nochop
    from norcal
    Sewer snakes
  16. BJR
    BJR
    This can't be that complicated. All I need is a vacuum switch that when vacuum is applied to it, it connects two electrical contacts together. Thus turning on my electrical washer pump.
  17. rockable
    rockable
    I posted a link in post #8. Don't know what the current capacity is, so you might also have to use a relay but I doubt it.
    BJR likes this.
  18. BJR
    BJR
    Yes that is what I need, but there has to be some cheaper ones out there.
  19. Kerrynzl
    Kerrynzl
    Some Harley Evo Sporty's have a VOES [vacuum operated electrical switch] to retard ignition if the vacuum drops
    https://www.verifiedvaluevault.com/product-p-205913.html
    At low vacuum the circuit is open, at high vacuum the circuit closes
  20. Forklifts use tons of these the aluminum one is fairly “ old school looking “
    BJR likes this.
  21. Doublepumper
    Doublepumper
    from WA-OR, USA
  22. Joe H
    Joe H
    Looking at that last link, a fellow could simply mount a micro switch to a vacuum advance unit off an old distributor, a couple of small screws and a few holes and you would be good to go.
    BJR likes this.
  23. BJR
    BJR
    Thanks everyone for the replies. I have 2 switches on order and will report back when they come and I get one installed.
    Doublepumper likes this.
