Projects 64 fairlane build
Discussion in 'The Hokey Ass Message Board' started by unclechop, Jan 27, 2021.
  1. unclechop
    unclechop
    Re starting my build of a baby thunderbolt,
    New rear tyres 245/60/r14s on the back
    Front wheels are 15x5.5 hipo galaxie rims or torq thrusts
    Sent from my SM-N975F using The H.A.M.B. mobile app
  2. AVater
    AVater
    Love that year and body style! Best wishes!
  3. oldiron 440
    oldiron 440
    What have you got for power?
  4. caper
    caper
    from Cape Cod
    I built three T-Bolt clones over the years: 1st one was tubbed with a 512ci 385 motor - ladder bars and C6. 2nd was a 5.0 injected with a T5. 3rd was a 482 ci FE hi-riser with a 4speed Jerico. If I built another I would power with a 460" small block and a 5 speed Gforce.
    ffr1222k, unclechop and loudbang like this.
  5. unclechop
    unclechop
    Atm a stock 289, but will build a mild roller 302 and t5z that I already have
  6. unclechop
    unclechop
    Nice how easy was the t5 conversion I'm thinking hydraulic throw out brg will be the easiest
    ffr1222k and loudbang like this.
  7. ffr1222k
    ffr1222k
    I don't know how similar the Fairlanes were to a first generation Mustang but I did a Mustang and used the cable from a Fox body and a Firewall adjuster.
    loudbang and oldiron 440 like this.
  8. southcross2631
    southcross2631
    I second the cable clutch set up . I am using it on my southeast g***er super stock 65 Comet wagon. I modified my stock pedal to accept the cable end and used a Ford motorsports cable and firewall adjuster. Had to build a simple spacer block to give the adjuster room to work. DSCF3771.JPG
  9. oldiron 440
    oldiron 440
    I second the cable/ fox mustang setup as there is no provision for a clutch pivot point on the block and the hydraulic throwout bearing is expensive.
    The cable setup works nice.
    ffr1222k, sidevalve8ba and loudbang like this.
  10. caper
    caper
    from Cape Cod
    I used a six cylinder cross shaft, an aftermarket engine side ball that bolted to the bellhousing, and stock fairlane frame bracket. worked perfect. Also found the 6 cylinder throttle linkage worked with the efi. Stick shift headers cleared everything.
  11. unclechop
    unclechop
    Unfortunately the plenum needs a fair chunk out of it on the fairlane for the cable setup from what I've read
  12. unclechop
    unclechop
    Cheers for that, Unfortunately there aren't any manual fairlane bits around in Australia, so piecing all the bits together is a challenge, I think I'll go the hydraulic route and it may be easier on my knee
    oldiron 440 and loudbang like this.
  13. oldiron 440
    oldiron 440
    That's one thing about the hydraulic setup is how easy the clutch works.
  14. unclechop
    unclechop
    pprather likes this.
  15. unclechop
    unclechop
  16. unclechop
    unclechop
  17. patsurf
    patsurf
  18. ffr1222k
    ffr1222k
    I like your Fairlane and wish I could see the pictures
  19. unclechop
    unclechop
    Sorry mate just changed the permissions
  20. ffr1222k
    ffr1222k
    Progress looks great. I really like the 64 Fairlane
    unclechop likes this.
  21. T. Turtle
    T. Turtle
    Nice car, dad had a 64 compact Fairlane many years ago when I was growing up in Israel and I did look at one in Germany before I got the Comet (well I even tried to trace dad's car but according to IL DOT it was s****ped long ago:() but the seller wanted a bit too much and it was an auto, so it was not to be.
  22. unclechop
    unclechop
    Wouldn’t have thought there were too many fairlanes in Germany in the 60s - your comet is cool as
  23. T. Turtle
    T. Turtle
    That car was a recent US import but Ford and Mercury cars sold all over Europe back then, and I'm aware of at least 2 64 Comets sold originally here in Austria (not mine - mine lived its first 54 years in Oregon). Oh, I don't regret buying it, but the 64 compact Fairlane has a special significance for me...
  24. unclechop
    unclechop
  25. unclechop
    unclechop
  26. T. Turtle
    T. Turtle
  27. unclechop
    unclechop
    Yes that is me - I wrote that one off a week or so after that photo unfortunately.
    I love the white and red combos on the 64s- great photo
    T. Turtle likes this.
  28. oldiron 440
    oldiron 440
    Those lower rear quarter panel repair panels are not easy to fabricate, they have a curved lower edge and the outer edge is curved so your bending two angles at the same time. My 64 only had rust on the lower rear quarter panels, just a thin line on the very bottom body line where the water would collect. So I was lucky I was able to hammer forum the repair panels.
