1932 -1934 Ford Model B 4 Cylinder Engine Motor Block WITH HEAD and bearing caps,
Discussion in 'Parts For Sale' started by bustingear, Sep 9, 2025.
  1. bustingear
    bustingear
    City: Pickerington
    State: Ohio
    Price: 550
    Shipping: I will strap to a skid that I provide and work with your shipper that you arrange for pick up at my location or you can pick up locally.1932 -1934 Ford Model B 4 Cylinder Engine Motor Block WITH HEAD and bearing caps, Head has small crack in an area that will not hurt anything (picture arrows) It could be epoxied or welded but probably not necessary. Vintage Antique Banger TROG, Has fuel pump mounting area cast in block. Has 2" main bearing area, It includes the 3 main bearing caps. Block will need to be cleaned of its surface rust, machine work possible but unsure if necessary. .I have kept it indoors in the time I have owned it. It is sold as is and sale is final keeping in mind that it is 93 years old. Engine has no numbers from the factory and number pad is smooth as it was a replacement block. That is consistent with Ford replacement procedure. Thanks for LQQKING!
  2. bustingear
    bustingear
