Customs 1963 Rambler Classic 770 build
Discussion in 'The Hokey Ass Message Board' started by Bruce A Lyke, May 15, 2025.
  1. duecesteve
    duecesteve
    Glad you are feeling better :)
  2. Bruce A Lyke
    Bruce A Lyke
    It will be 4 weeks tomorrow and I'm finally able to move around pretty well without pain.
    Hopefully will be taking it to have the transmission checked out in the next week or two:cool:
  3. Just be careful doing that; don't want to jeopardize the mending process. Coming from guy who had a total shoulder replacement 7 weeks ago. Minimal pain, but limited as far as working on stuff.
  4. warhorseracing
    warhorseracing
    from cameron wv
    The project looks great. Do not push yourself but stay in your comfort zone. If it hurts you are going to your limits. Pay attention to your body. We all want to see it progress.:cool:
  5. Bruce A Lyke
    Bruce A Lyke
    Getting better and can start working on the car a bit more next week
    Did enough this week to confirm the issues with the transmission are beyond my abilities so the Rambler will be going to a local transmission shop Monday for a diagnostic and estimate, probably a rebuild.
  6. patsurf
    patsurf
    "Fiash o matic!
    Sharpone and Bruce A Lyke like this.
  7. Bruce A Lyke
    Bruce A Lyke
    Decided it was time to see what the Spinner Wheel Covers look like with the dirt and road tar cleansed off. Should be fine for the semi-survivor look I'm going for.
  8. Bruce A Lyke
    Bruce A Lyke
    Well, it took a bit longer than planned but the transmission is done, and the care came home Monday 12/8
    The 7-mile trip was all the test-drive it will get until spring. all the strange noises seem to be gone.
    Will get started on some minor items as time permits
  9. Bruce A Lyke
    Bruce A Lyke
    Winter is full on in Minnesota and the work on the Rambler is getting going
    Backup light lens was removed to check the bulb, leading to a need for a new gasket. this also confirmed the problem was not the bulb. Suspect the Neutral Safety switch is bad.
    It also allows the car to start in any gear so i think i will order a new one
    Door locks did not work. The p***engers lock just needed some lubrication and now works. The driver's side will need some more involved repairs or replacement.
    While the door was apart, I reglued the side of the cover.
    Sharpone, bobss396, 63Biscuit and 7 others like this.
  10. Bruce A Lyke
    Bruce A Lyke
    I now have a pair of functional Locks, .... so, I've got that going for me
    Which is nice.
    Sharpone, SS327, Algoma56 and 6 others like this.
  11. Bruce A Lyke
    Bruce A Lyke
    Waiting for parts so decided to see how bad the rust I saw in the trunk floor is.
    Should be an easy fix with homemade patch panels
    Sharpone, 63Biscuit, pprather and 3 others like this.
  12. Squablow
    Squablow
    Practically rust-free by Minnesota/Wisconsin standards.
    Sharpone, SS327, 63Biscuit and 2 others like this.
  13. Bruce A Lyke
    Bruce A Lyke
    Moved on to the dash cluster area, things were really loose, especially the ignition key area
    5 screws, some new foam and a nut and it is very solid.
    The ignition switch was basically held in place by the wires, found the mounting tab after removing the ash tray
    Seems a PO had it apart and didn't quite get back together all the way
    Sharpone, Squablow, pprather and 3 others like this.
  14. Bruce A Lyke
    Bruce A Lyke
    The trunk springs did hold the lid open, short term a piece of 1 by was cut to length. Further investigation revealed the right side was severely damaged. The left side was black and obviously not original. got a replacement (in blue) for the right side and painted them to fairly closely match. Will line up some help to remount the lid but moving on to some other items.
    I am baffled as to how the damage would have happened, but at this point it is not important:rolleyes:.
    Sharpone, 63Biscuit, Squablow and 3 others like this.
  15. Bruce A Lyke
    Bruce A Lyke
    Making progress with Neutral safety switch and backup lights
    Mistake #1, ***uming the wires on the old switch was correct
    Pulled out the schematic (which is not my strong suit) and determined both of the main wires were reversed
    Used a meter to get the 12 volts on the correct tab when in reverse and need to see why the lights still are not working, the left bulb is good suspect the grounding may be poor
    Sharpone, loudbang, 63Biscuit and 2 others like this.
  16. Squablow
    Squablow
    I was without trunk lid springs in an OT Pontiac that had those same torsion bar style springs as the Rambler has, finally got them replaced and working like 2 years ago. They can be really hard to wrestle into place.
    As for the other stuff, it's good progress. Even the most low mileage, pampered survivors still end up having issues like this to fix, and it's usually a result of other people fussing with it in the past.
  17. 63Biscuit
    63Biscuit
    from Hudson, WI
    I ***ume your Rambler is likely to make it for BTT50's this year too? My Biscayne and Shoebox will be there.
  18. Bruce A Lyke
    Bruce A Lyke
    that is the plan, online sign up begins on Groundhogs Day:cool:
    Sharpone, 63Biscuit and guthriesmith like this.
  19. Bruce A Lyke
    Bruce A Lyke
    Point of clarification
    It has become clear the actual milage is not 23K
    :oops:
    At this point it is what it is and the build continues:cool:
    Sharpone, Squablow and guthriesmith like this.
  20. Bruce A Lyke
    Bruce A Lyke
    Backup light trouble shooting continues
    Break in the wire near the taillight, have power to that point.
    Need to work on the grounding and am optimistic that will be the solution
  21. Bruce A Lyke
    Bruce A Lyke
    It was a battle, but the backup lights are now functional:cool:
    It finally dawned on me that the voltage meter will show up with very little amperage compared to the bulb
    Ran a jumper from the negative battery terminal to the bumper to confirm my concept and lights worked.
    Since this is a "fixup" a budget friendly solution was utilized grounding, body to bumper bracket and its GTG
  22. Squablow
    Squablow
    I had a similar issue with the parking lights on my '57 Chevy, for whatever reason the path to ground was broken somewhere despite it being all conductive metal in every direction. A good ol' jumper ground and they've worked ever since.
  23. Bruce A Lyke
    Bruce A Lyke
    Whatever it takes to get it working:rolleyes:
    Sharpone and guthriesmith like this.
  24. Bruce A Lyke
    Bruce A Lyke
    Was able to successfully trim my antenna and now have a much more functional AM Radio
    Which is nice....
    warhorseracing and guthriesmith like this.
