Hot Rods 1927 Touring body what would you do?
Discussion in 'The Hokey Ass Message Board' started by Royalshifter, Nov 30, 2025.
  1. 29Sleeper
    29Sleeper
    from SoCal
    warhorseracing and porkshop like this.
  2. Joe Blow
    Joe Blow
    I get your Voodoo to Voodoo ****ogy but nah, a modern mill in a vintage car doesn't float my boat at all. That '64 425 hp Super Wildcat Nailhead is perfect in that car....and in a 1700 lb. tub, will more than pucker the ol' ********.
    rod1, Sharpone, SS327 and 2 others like this.
  3. Sounds different and :cool:!!
    Sharpone and porkshop like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir, they were cool. HRP
    Lady hrp trying the car on for size, she is slightly taller than John and still fits but I couldn't get my big old Neanderthal self in with the top on. HRP
  5. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    I haven't updated my build thread in quite some time.
    Customs - From Clown Car to 1927 T Touring Custom Rod | Page 2 | The H.A.M.B
    I'm in the design and modeling stages of scratch building the ch***is.
    I will have all of the steel cut on a water jet and fixture and weld up the ch***is as one unit.
    The rails will be 3" wide and 6" tall, in an attempt to mimic the 1932 Ford rail side profile.
    No Fenders, Boards, etc... It will be highboy style. Chuck V's Voodoo Doll was an inspiration
    for my build. "Semi" traditional with a 302 SBF, C4 Ford A/T and 9" Ford rear axle.
    Front Cross Spring with a dropped axle up front and Coil Overs in the rear (I know, the not traditional
    part of the build). I have a set of 1936 Spoked Wheels. I will run a chopped original Windshield with a
    stock Radiator and Radiator Surround.
    That body that you have is Cherry. Stock is boring ! Make her a nice Hotrod.
    VR&C.
    Royalshifter, porkshop and Sharpone like this.
  6. Royalshifter
    Royalshifter
    Moderator
    Well with a lot of thought and possibly found a roadster body I cannot cut this perfect body up so the majority wins.
    Up for grabs if someone needs a perfect Tub body.
    AmishMike, GuyW, porkshop and 3 others like this.
  7. Dave G in Gansevoort
    from Upstate NY
    I’m just glad that there’s a whole continent in between us… SWMBO would kill me if I started another project
    porkshop likes this.
  8. Royalshifter
    Royalshifter
    Moderator
  9. silent rick
    silent rick
    your little modified was inspiration for my build
    I saved the good parts from it when I found a real nice roadster body to put on 32 rails
  10. blvdbill
    blvdbill
    Sell it and get what you want.
  11. Royalshifter
    Royalshifter
    Moderator
    porkshop and warhorseracing like this.
  12. Royalshifter
    Royalshifter
    Moderator
  13. James D
    James D
    You'd absolutely have to woodgrain paint the ch***is on this.
    Royalshifter and porkshop like this.
  14. Mo rust
    Mo rust
    Put it on a32 ch***is with bobbed rear frame horns and a quick-change or a banjo rear out back in plain sight. I've always like the looks of that tall back showcasing a cool rear end.
  15. Royalshifter
    Royalshifter
    Moderator
  16. TERPU
    TERPU
    porkshop and Royalshifter like this.
  17. I see my tub made the cut… cheers!
    cactus1, Kelly Burns and porkshop like this.
