Featured Hot Rods Lock her up!
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Dec 10, 2025.
  1. flynbrian48
    flynbrian48
    IMG_4419.jpeg IMG_4421.jpeg IMG_4420.jpeg IMG_4419.jpeg IMG_4421.jpeg IMG_4420.jpeg I got the trunk lid latch mount roughed in for the roadster. I used bodyman in a can (long strand fibergl*** filler), and the new latch, covered with waxed masking tape to make the fillet. Tomorrow I’ll smooth it up with some filler, prime and paint it using the can of Testors blue enamel I used on the model I built if the ca a couple years ago. Close enough for the underside of the ‘gl*** deck lid. I’ll have to make a striker, the one that came with the latch won’t work with my car.
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. oldiron 440
    oldiron 440
    Looks like something I wouldn’t be showing the world, fairly competent body man fabricator could’ve done that in sheet metal…:)
    Rocket88NZ and chryslerfan55 like this.
  4. Jalopy Joker
    Jalopy Joker
    be careful to not hit your head on it. seems that would be the lower piece
  5. Tim
    Tim
    from KCMO
    it’s a gl*** car, makes since to make it out of gl*** I’d say.
  6. 19Fordy
    19Fordy
    Brian: Don't let the "nay sayers" upset you. What you did is just fine and dandy.
    Be sure and post photos when its finished and painted.
  7. flynbrian48
    flynbrian48
    “…a fairly competent bodyman…”? That is about the most ignorant thing I’ve had anyone say about this, or any car I’ve built. Right up there with “I hope you didn’t put a Chevy motor in that thing”. And, “…did you buy that new?”.
    Since you felt compelled to show your ***, I’ll explain to you, like you’re a 5 year old, that this is, aside from being UNFINISHED, on the underside of the deck lid. On a car that’s fibergl*** bodied. I’m not the guy who puts the hood up, trunk up, doors open at a car show, with a model of the car on the air cleaner and a stuffed animal in the seat. It will be smoothed, finished and painted, and while it’s not in the original configuration, it will work just fine and look good.
    Good God man.
  8. flynbrian48
    flynbrian48
    Unless someone was in the trunk, it’s not likely going to be where one’s head will hit it. :rolleyes: I never planned to have a latch, the Austin Healey handle I mounted too close to edge of the lid, so wouldn’t work in the original spot, in between the inner and outer deck lid skins.
  9. flatheadpete
    flatheadpete
    from Burton, MI
    Anything that makes a car more useful is a win. I've liked this car since day one...it just keeps getting better!
  10. flynbrian48
    flynbrian48
    Thanks. If only I were a semi-competent bodyman. ;)
  11. COCONUTS
    COCONUTS
    This looks like a excellent example of function over form.
  12. flynbrian48
    flynbrian48
    It’s an outtie, not an innie. :rolleyes:
    mad mikey likes this.
  13. hotrodA
    hotrodA
    Good on you! Solved the problem you previously posted about the AH handle being in the wrong place.
    “Necessity is the mother of invention.”
  14. charleyw
    charleyw
    Thanks for the pics, I have that task to do on my gl*** '32 project. You can bet there will be longstrand filler used in the process.
  15. lostn51
    lostn51
    from Tennessee
    Looks good to me and it’ll help keep the trunk from bouncing around;)
  16. winduptoy
    winduptoy
    I'm not a body man....I am a leg man....
    my buddy has a '29 A that is a gl*** car and he ran the Texas Mile in it....first run....the trunk flew open...he exceeded the holding strength of the cabinet latch magnet when he hit 77 mph....good thing to have a secure trunk latch in my mind...I like it
  17. oldiron 440
    oldiron 440
    I was looking at the large chunk of filler/gl*** whatever and didn’t notice that the deck was gl***, actually you need to be looking for it to see that it’s gl***. But I also fabricate in fibergl*** casting parts and lying then up with cloth and mat and other than fabricating in metals I stand by my statement..
  18. goldmountain
    goldmountain
    I built my trunk lid out of fibergl*** and wood so I would say you did good.
  19. flynbrian48
    flynbrian48
    Close enough. It’s almost Ford tractor blue, which might be closer than this. I’ll try a rattle can of that, and I struggled to get the striker positioned, tomorrow is another day.
  20. flynbrian48
    flynbrian48
  21. Happydaze
    Happydaze
    The joys of having to get creative with 'gl***! I have a gl*** 32 roadster BTW. What you've done should latch OK but will the handle actually lock? Just in case you didn't realise, you have the newly installed mechanism the wrong way around. In stock form it goes between the skins with the round tower against the inside of the outer skin. The notch is for the engagement of the tang that comes out when the key is turned, locking it. I guess you could kind of replicate that action with the way you have it though. Just a square notch filed in the 'gl***. Might be strong enough? Otherwise a holed and notched steel plate ( sheetmetal) bonded to the inside might help, but the thickness of the 'gl*** skin might make that not possible. Like I said, the joys of it! But locking a roadster, what an oxy***** !
    Chris
  22. seb fontana
    seb fontana
    from ct
    Did he make it to 88? Lol.
  23. VOODOO ROD & CUSTOM
    VOODOO ROD & CUSTOM
    As a "competent body man fabricator" with 48 years under my Hat; I'd say that you done good Brian.
    Finish it and drive the Hell out of it.
    Have a Great Winter.
    VR&C.
  24. flynbrian48
    flynbrian48
    The handle is keyed to lock, and does. I have make a striker, the Model A one that came with the latch won’t work the way I made the body brace from the rear pan to the floor. I’ll get it tomorrow.
  25. mountainman2
    mountainman2
    ........ posts like this one are the reason that I don't post pictures of my car on here. Being one of the older boomers on here, I became a car nut in the latter half of what we consider to be the "traditional period". I can ***ure you that the majority of cars built in that period were not built by "fairly competent body man fabricators" as judged by today's standards. They were done by teenagers and young adults using their skills and available/affordable tools. I still build that way, sometimes not the prettiest but always safe and functional.
  26. hotrodA
    hotrodA
    FWIW, but you may already know it. Or for those who don’t.
    The latch mechanisms are made in two different thickness’s. One for trunks, and one for rumble lids. The difference is the just in the round part that sticks out from the latch body. It has to do with the stamped relief on the INNER panel according to Kenny at B’ville.
    Unfortunately I can’t remember which is which ( CRS), but I know I got the thinner one from Brookville.
    The thinner one may give you a little noggin clearance when the lid is up. But if you’re a quick learner, one close encounter with the latch will be enough!!:mad:. :eek:
    winduptoy and flynbrian48 like this.
  27. oldiron 440
    oldiron 440
    I’m glad I’ve given you all plenty to cackle about, I looked through some of my old work photos and I couldn’t find what I was looking for but the way I have done something similar is to build with a foam board I got from a local green house down the road. It was easy to glue up and shape then finish it with filler and feather fill. When It was done it would look like it was reddy for paint but I would cast it and make a mold getting a few inches of the inner deck as well. There’s a couple ways to retrieve the mold and then prep and cast the part but that’s the way I have done it for over forty years. I started doing fibergl*** hoods after reading an article in Hotrod in the late seventies. I’ve made hoods, deck lids, bumpers and countless small parts.
    Good luck with your chunk of Bondo and Duro Gl***…
  28. flynbrian48
    flynbrian48
    Exactly. I’m 71, I’ve always built cars on a budget that most guys would laugh at. It hasn’t been until I retired and built this with s****s left over from my DeSoto wagon project that I could spend money on exotic stuff like the chrome suspension for this. Bought from Speedway’s “Garage sale” section for $.50 on the retail dollar.
    There’s a place in this hobby for owner-built cars, and we all have different skill sets and levels of satisfaction.
  29. flynbrian48
    flynbrian48
    It’s a wrap. Latches, locks, unlocks as it should, with parts from early Fords, British sports cars and cabinet parts from the hardware store. Upside down and backwards . To you all who told me I was doing it wrong, whether you think you can, or you think you can’t, you’re right.
  30. patsurf
    patsurf
    even put in a bracket for a 110 v trunk light!-thought of everything!!:p
